Old 09-07-2003, 02:49 AM   #1
IH
IH's Avatar
Default CS-27 on carpet
What insert/rim combination do you use when running the CS-27 on carpet? Do you tend to use hard or soft rims...
Thanks,
IH
IH is offline   Reply With Quote
Old 09-07-2003, 03:08 AM   #2
Roger's Avatar
I use the stock insert that comes with the tire. Everybody I know uses the same thing with the take-off CS-22's and CS-27's. The stock inserts are the best.
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 09-07-2003, 03:28 AM   #3
Super Moderator
Grizzbob's Avatar
Yeah, I like the stock inserts too, though I do add one thing before I glue them. I like to take some strapping tape(like what's used for taping batteries into a pan car chassis) & put a layer inside the tire before I put the insert in & mount it up. The tape seems to fill the little gap between the tire & insert, so the insert doesn't bunch up much at all(seems good to make 'em last a bit longer).....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 09-07-2003, 07:21 AM   #4
PizzaDude's Avatar
Which non-smelling tractioncompound do you think is best for the CS 27 on carpet?
PizzaDude is offline   Reply With Quote
Old 09-07-2003, 08:10 AM   #5
Suspended
Trader Rating: 28 (100%+)
Jack the gripper is pretty good.There maybe something better.
racenut123 is offline   Reply With Quote
Old 09-07-2003, 09:57 AM   #6
Depends on the guy that running the track. At HobbyWorld in Gilroy, Ca. only "Jack the Gripper" is used only. STRC in Stockton only uses "TQ Orange". You should ask what brand to use on their track, every track will use different brand of traction compound.
milf is offline   Reply With Quote
Old 09-07-2003, 02:50 PM   #7
Super Moderator
Grizzbob's Avatar
Yeah, even though it's not quite odorless, I do like TQ Blue(it's made specifically for sedan tires), it's not nearly as nasty smelling as Paragon, & it actually seems to work better than Paragon in most conditions......
Bob Seay
Go Pokes!!!
Old 09-08-2003, 01:53 PM   #8
TC3
TC3's Avatar
the best inserts are : orion JB blue or JB yellow
TC3 is offline   Reply With Quote
Old 09-08-2003, 03:58 PM   #9
Roger's Avatar
Jack the gripper
Old 09-08-2003, 04:02 PM   #10
speedxl's Avatar
R/C Tech Charter Subscriber
jack the ripper is what we ve using on carpet here in florida and you can also use tq orange it works too. you might want to try wd-40 as well (i know it sounds wierd) its an old schooltrick and its what we ran at the national in colorado.
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Old 09-08-2003, 04:38 PM   #11
Regional Moderator
Where do you find TQ Blue?
volav is offline   Reply With Quote
Old 09-08-2003, 06:09 PM   #12
Super Moderator
Grizzbob's Avatar
Any major hobby shop that carries any traction compound should have some or be able to get it for you.....
Bob Seay
Go Pokes!!!
Will rubber carpet overtake Foam carpet in the future??? dawgmeat Electric On-Road 166 09-21-2007 11:59 PM
Nice carpet 190mm carpet body coastaltony R/C Items: For Sale/Trade 3 09-20-2007 05:50 AM
FS:RDX Carpet and rubber spec, T-Fource, Mi2EC Carpet spec rayhuang R/C Items: For Sale/Trade 28 12-01-2006 10:30 AM
Carpet Knife 3.1 "red"--just in time for carpet season!! Scottrik R/C Items: For Sale/Trade 10 09-27-2006 04:02 PM
BMI carpet T2 carpet ready dawgmeat R/C Items: For Sale/Trade 5 09-02-2006 08:17 AM
