ProMaster & ProMaster2 >
Old 09-04-2003, 07:39 PM
GTO2's Avatar
Default ProMaster & ProMaster2
Can someone tell me what are the major differences (if there's any) between the two?
How does it compare with CE?
Thanks!
GTO2 is offline
Old 09-04-2003, 10:08 PM
The Robi with the Promaster or Promaster II software....is a great setup.
I prefer the Robi......not nearly as loud as the CE...and you test the motor at the voltage you actually race at.
The CE would be my second choice....and, IMHO.....there are no other choices out there.....I HAVE owned ALL of the dyno's.
The CS & the Fantom will ALWAYS show the motor with the highest rpm as the best motor......and the Fantom only tests at 5 volts.
The difference in the software......is better. Go with the Pro II software.......unless you are using a win 95/98 loaded laptop........the Promaster I software works better in DOS mode.
acloco is offline
Old 09-04-2003, 10:32 PM
popsracer's Avatar
GTO2;
I spent several months scanning the Message boards before deciding on the Robitronic Pro Master II Dyno.
As far as I know, the Dyno is still shipped with the DOS software. This means if you have a PC with Windows XP, no Print function (and a few minor annoyances).
I have tried the Demo version of the newer Windows based software and it works very nice. But, Robi wants an extra $60 usd for the full version.
As to the differences between the Pro Master and Pro Master II Dyno's. The II version will allow you test Motors below 10 turns. Other than that they are the same.
popsracer is offline
Old 09-04-2003, 10:40 PM
GTO2's Avatar
thanks pops, so if I were to run the Demo s/w I would be able to run the ProMaster to check motor below 10T? Or I should update the EPROM as well?
Another question, do you have to 'callibrate' it ever? Thanks again.
GTO2 is offline
Old 09-04-2003, 10:42 PM
GTO2's Avatar
err, I am planning to use it with Win98 laptop...does the ProII won't work with it? thanks.
GTO2 is offline
Old 09-05-2003, 10:38 AM
popsracer's Avatar
The Motor limit is in the "Hardware", not the software.
"Software", The program shipped with the Dyno is DOS based.
Never had to, or heard of anyone having to Calibrate their Robi Dyno's (Motor Checker). I believe this is done each time you set-up a Motor for testing.
Here is the link to Robitronic Racing
Old 09-05-2003, 01:44 PM
Super Moderator
Grizzbob's Avatar
Right, aside from aligning the flywheel to the sensor(when you mount up a motor for testing), the only adjustments that might be needed is if you get a new flywheel to use(& the manual has instructions for resetting things for a different flywheel than what came with the dyno). And pops is also right about the motor limit, the older ones(& mine is one of those made before they updated to test sub-10 turn motors) can't stand up to the load that a serious sub-10 turn motor can place on it, so they will shut down early to protect themselves. The update I think both changes the firmware on the main circuit board & also the FETs that handle the current going through it, so it can safely test those hotter motors.....
Grizzbob is offline
Old 09-05-2003, 01:55 PM
StephenSobottka's Avatar
grizz, did i ever tell u thanx for dynoing motors for me?? if not thanx!
StephenSobottka is offline
Old 09-05-2003, 04:52 PM
Super Moderator
Grizzbob's Avatar
No prob, anytime(& we're already making plans to be back in Janurary for the Novak race)......
Grizzbob is offline
Old 09-05-2003, 08:49 PM
Thats sweet!! foams and rubber if u havent heard
Pit buddies again??? I'm down, we had a good system of how we arranged all of our junk lol.
Old 09-05-2003, 11:09 PM
Super Moderator
Grizzbob's Avatar
Sounds good to me, I think I may stick with rubber, though I'm not 100% decided on it(same for the others who've been up with me, we're thinking about it & trying to get ahold of some foam setups). But I had the most fun last time with those handouts, so I suspect I'll be in for more(& of course my little Robi will be tagging along)......
Grizzbob is offline
Old 09-05-2003, 11:15 PM
Brian McGreevy's Avatar
Hey Bob since me and sobottka will be pitting together also, me being on the other side of him, mind if i use the robi too?
Brian McGreevy is offline
Old 09-07-2003, 01:57 AM
GTO2's Avatar
popsracer & Grizzbob:
Yo guys,
thanks for the answers, appreciate it.
GTO2 is offline
Old 09-08-2003, 01:17 AM
GTO2's Avatar
Anyone knows why the dyno can only be powered by lead acid batts ? thanks.
GTO2 is offline
Old 09-08-2003, 09:13 AM
popsracer's Avatar
Simple reason: Amp Draw.
I use a fully charged Automotive Battery when I do my testing. (I only test Stock Motors)
