trinity komodo dragon motor installation help
can someone help me find out where im suppose to solder on the motor leads?
the instructions supplied with the motor dont go into any detail. ive only used motors with 2 tabs. 2 tabs, 2 wires, easy enough- but this motor has 4 tabs, what the heck ? |
It may have 4 tabs but 2 of them are on each side of + and -. So you can solder your positive wire to either of the 2 positive side tabs and the negative wire to either of the 2 negative side tabs.
There is a circuit board on the top of the motor and on it you should see a positve sign(+) and the other side should be blank you solder the positive wire on the positive side either tab will do and then the negative wire on the other side preferably across from the tab you soldered other wire on. Hoped this helped
thanks very much for the fast replies! ive been trying all day on another forum to get an answer and nobody replied. rctech rules! thanks fellas
i just bought the same motor today and had the same problem. i had no clue where to solder the wires. i googled it and this thread came up. solved my problem. rctech does rule. thank you.
