Old 10-15-2008, 06:12 PM   #106
Trader Rating: 22 (100%+)
Default Tekmodel
Hey guys just purchased the ezrun Tekmodel 60A version. Is there any real difference in the original and these. I am going to try it in a Losi xxx-t with a Novak 10.5. Do you guys think this will work. This is my first time going brushless. Has the on/off switch got better on these.
ghj1997 is offline   Reply With Quote
Old 10-15-2008, 07:43 PM   #107
lutach's Avatar
Tekmodel is Hobbywing's own brand so it is the original. I haven't had a problem with any of my switches and neither have our sponsored driver whic hused the 60A system in his ZX5.
http://www.youtube.com/watch?v=BikJALhTd8s
http://www.rc-monster.com/forum/showthread.php?t=8651
http://www.cnn.com/2008/HEALTH/conditions/04/01/autism.ireports/index.html (My daughter's video is the last one)
lutach is offline   Reply With Quote
Old 10-15-2008, 08:14 PM   #108
Drifting101's Avatar
So i ran my ezrun for the first time today and a 10t in a 2wd on grass it lands on its roof on acceleration. But i was having battery problems (the built in cut off in the lipo kicks in under high load) so when i get a new battery i will do furthur testing
Also there is a bit of cogging at low speed
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 10-15-2008, 09:03 PM   #109
Finally what does timing do to the motor?
Schumacher
Old 10-16-2008, 08:47 AM   #110
V12
V12's Avatar
A question for all the guys using the 60A version, what is the fastest motor you did use with this ESC? Also what battery, 4cell 5cell 6cell or Lipo?
V12 is offline   Reply With Quote
Old 10-16-2008, 09:40 AM   #111
Lonestar's Avatar
1-10000mah lipos don't exist in "classic 6-pack" size.
2- if you're wheeling that bad, gear up and be smoother on the throttle.
3- setup the cutoff properly, otherwise if your pack voltage falls that much under load it means its IR is way higher than normal, and you can bin your lipo.
Paul
Lonestar is offline   Reply With Quote
Old 10-16-2008, 04:42 PM   #112
Default 60A
need a couple of questions answered. Firts can the ezrun 60A run a Novak 10.5. Next question. Right now I am using a Novak GT7 with a Komodo 19T brushed motor. Is this better than the ezrun system for speed and ease of use.
I had a 19t with GT7 in a assoc. b3 buggy. I fitted the 60A & 9t system for racing last wed. night and it was ballistic. I will never go back to the brushed. I geared it up up to help with wheel spin and it was the fastest buggy there easily. If you want to, it will flip every time you tramp the throttle but use the go juice sparingly and it is awesome.
The speedy didn't even get warm after 6min of racing and the motor was cool enough to hold in your hand comfortably. (without gloves)
Is your car slow..Xray it!.......FK05, M18, M18t
RexX
Assoc...T3,T4, B4
Team Ash is offline   Reply With Quote
Old 10-16-2008, 06:11 PM   #113
nexxus's Avatar
Trader Rating: 302 (100%+)
The motor seems ok in a RC under 1.5kg like ur TC, small buggys etc but in your stadium trucks, Traxxas Slash etc, it just burns up no matter how well you gear it, on a warm day the little rotor in that BL motor just dumps it's guts and heats up like an oven!
They need to bring out a 550 size motor with a decent sized rotor.
A800 / A800X Awesomatix
Don't worry about what I'm doing.
Worry about why you're worried about what I'm doing.
"Ego is the anesthesia that deadens the pain of stupidity."
nexxus is offline   Reply With Quote
Old 10-16-2008, 07:38 PM   #114
cannon's Avatar
Trader Rating: 35 (100%+)
Hobbywing already make a 5.5 , 8.5, 13.5, and 17.5 sensorless motor in 540 size. In fact you can buy them as combos with the 60A ESC
The 9, 10, 12 and 13t motors are a 380 motor and are designed to drive small 1/10 scale and 12th scale cars only
It all comes down to buying a system applicable to your use. You cant expect a 380 motor to drive ST vehicles without having heart attacks
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 10-16-2008, 08:09 PM   #115
Default ezrun
so the 60A is designed to run in 1/10 trucks for off road
Old 10-16-2008, 08:15 PM   #116
cannon's Avatar
The 60A ESC is able to handle the amp draw of the 540 size motors such as the 5.5 and 8.5
Old 10-17-2008, 01:12 AM   #117
Paul
1-Doesnt need to be that (and its like 5mm taller, 7mm longer and 6mm wider) or if it does a 8000mah (soft case) pack will be the 6 cell lenth and width and on an 8.5 your will get 20 mins plus in a 2wd truck
2-I havent added a gram of extra weight so the back is like 5 time heavier the the front
3-Its a faulty cut off in the battery i was watching the voltage on a lipo cell checker and it was still like 7.8 volts when it cut off
Retested my truck on diff batts (4600 nims) fair wheelie and no flip. And if the motor was sensored it still would cut off but weight is about 1.6 kilos
and i forgot to turn the cut-off off and i know that works well at least
Schumacher
Old 10-19-2008, 08:01 AM   #118
dethklok151's Avatar
Trader Rating: 65 (100%+)
this thread is kind of out of my normal veiwing area,but i'll post my experience here.
i have the 35a model in a slash.i am running it with their 13t 380 sized motor geared the same as stock.i havent changed any of the programming,as i dont have the card and havent been able to get it to program manually yet,but i'll keep trying.my only real test so far has been an oval race.yes,oval,slashes are for fun and that is what i was having.with the stock tires,the rear was pretty loose as usual,so i am guessing i didnt have a real high amp draw issue,i only used about 1300 mah of my 2 cell lipo in the first round,races were at least 5 minutes.oval track was pretty short,and i spun out a bit in the first few laps,so i also might not have as hard on the motor as usual. the motor temps whenever i checked were right at 133 degrees.speed and power were better than stock (as they should be),but probably just under a good 19 turn brushed motor,i think.definitely not as fast as some of my other motors(which it should NOT have been ).esc temp was under 100 degrees.
pending its ability to prove that it is durable under bad situations,i like this set-up.its brushless,has some nice programming features(that i havent tried out yet)and provides decent power.my buddy is running the same esc,with their 9t motor in his slash and it has thermalled on him a couple times,could be a gearing issue,and the fact that he has his endpoint turned down to 40%.
i like it,its not too fast(12t)3000kv,and the price was right.
"hey buddy,ya gonna finish marshalling my car or just lay there and bleed?"
Tamiya euro truck on asphalt
dethklok151 is offline   Reply With Quote
Old 10-19-2008, 07:01 PM   #119
nexxus's Avatar
Don't get me wrong if all you are doing is 5-6 minute runs, it's probably fine, but who goes out to a park for a bash and pulls it in after 5? For a 5 minute sprint in a slash it's probably fine, anything more, it'll just keep heating up and by 10 minutes you'll be in 160-170 area, after 15 try 185-190
For those "pushing" the 540 size motors (cannon) please post a picture of these motors side by side the "380" motors and if possible a picture of the rotors side by side.
Old 10-19-2008, 07:13 PM   #120
cannon's Avatar
Nexxus .. I am not pushing anything just stating facts. The heatsink can versions are 380 motors. The heatsink just makes them look the same size as a 540.
The true 540 motors are just that .. a true 540 can and rotor. Of course the little 380 motors are going to heat up. They are not designed for larger vehicles.
I am not going to pull apart motors just to satisfy your curiosity
eZRUN brushless system-3650-motor.jpg   eZRUN brushless system-3650-m-motor.jpg
Tamiya mini cooper sipaboy Electric On-Road 29687 12-10-2017 04:07 AM
Duratrax Evader cheech4 Electric Off-Road 1159 03-25-2015 02:27 AM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
wich brushless system maylemay Electric Off-Road 38 06-09-2009 03:46 PM
Whats a cheap brushless system for a traxxas slash Leroy1234p Electric Off-Road 25 05-17-2009 08:07 PM
Xray copies academygaz Electric On-Road 151 11-03-2008 09:42 PM
