Old 09-19-2011, 02:56 AM   #1006
Any gurus could advise.
New to this hobby. Will be fixing up ezrun 10.5T with 60A esc soon. Can anyone share somelight with me how to fix up this?
cheers
wrxmacorona is offline   Reply With Quote
Old 09-20-2011, 10:42 PM   #1007
How would one of these 120 amp speedos compare to a Venom 120? LMK Thanks
impdog is offline   Reply With Quote
Old 09-30-2011, 09:54 PM   #1008
RossoTorro's Avatar
Fake or genuine Hobbywing?
http://www.ebay.com/itm/eZRun-Combo-...item2564c132e3
http://www.ebay.com/itm/eZRun-Combo-...item2eb2952f54
How do we tell or know?
If all ezruns go away on ebay, then supply will be limited and we will be at the hands of greedy local shops....
The reason we use them is because they are cheap and level the playing field!
Personally i don't care if it's fake or not, as long as it's preformance is same as the real deal...
RossoTorro is offline   Reply With Quote
Old 10-01-2011, 01:17 AM   #1009
You should care.. my fake failed after a few runs (rev failed)
Friends fake never worked properly
You cant guarantee the pic on those ebay links is what the will send you. Your fake may not match the photo.
Have a look though the negative feedbacks to see if anyone has complained of fakes.
Another option is these. I have one. Its very good.
http://www.hobbyking.com/hobbyking/s...A_CAR_ESC.html
http://www.hobbyking.com/hobbyking/s...rog_v2_2_.html
http://www.hobbyking.com/hobbyking/s...idProduct=7195
1101 is offline   Reply With Quote
Old 10-02-2011, 02:46 AM   #1010
idbdoug's Avatar
Trader Rating: 33 (100%+)
Has anybody tried Hobbywings XERUN Blue Brushless 120A ESC (1S Lipo Supported) SL286 for 1/12 1-cell racing???
thanks
idbdoug
idbdoug is offline   Reply With Quote
Old 10-16-2011, 07:34 PM   #1011
Wink loser
Originally Posted by cannon View Post
Are you just stupid or a bit slow?
Read the instructions. If the motor runs backward simply reverse two of the wires from the ESC to the motor
i wish youd talk to me like that for misreading something, id slap the shit out of you and that dumb tiger. moron.
brooklynlove is offline   Reply With Quote
Old 10-16-2011, 07:42 PM   #1012
Default hi new to electric...
read most of the post and couldnt find anything on here pertaining to my issue,
just purchased a used car off someone with the 9t 4300kv 35a pro car system set and it has some fan on top of it. not sure if that matters but the car didnt come with any battery or charger, so i am wondering what would the best, price not an issue battery to achieve max power, speed and runtime.
also what would be a good lower priced battery to serve as a back up and would there be a charge suitable for both?
also how does it work the more volt the higher kv? eg 7.2 volt = ?
am i able to use the highest recommended voltage with the max kv ? kv basically equals more run time/capacity/speed?
thank you guys.
Old 10-17-2011, 12:21 PM   #1013
B4power's Avatar
For good LiPo batteries, go on Hobbyking and buy a 2S LiPo with a 20C discharge rate with about 3000-4000 mah for some long runtimes. They are about 20-30$ and very good.
The more Mah=more run time
The more volts=more power
The motor kv signifies the RPM. T
The more kv= the more speed and less torque.
The less kv= more torque and lower speeds.
It usually depends of gearing also.
Slash::FT B4::Evader BX::XXX-T-CR::TB-02::TR04::Slash 4x4 Platinum Edition::TT01
B4power is offline   Reply With Quote
Old 10-18-2011, 11:40 PM   #1014
Scott_Mantis's Avatar
Trader Rating: 15 (100%+)
Default ezrun 2700kv 1/8 combo with 120amp esc
hi guys,
has any one had any experience with the 1/8 2700kv - 120amp esc combo ?? have fitted one in a Revo 3.3 (converted with tekno kit) and i have a 2nd kit for a rc8-t (Tekno v4 kit upgraade)
the problem i have is that it runs for a while, then drops power (looses all speed) like it has hit over temp protection etc, which it hasn't as the esc / motor are stone cold... i have read that it may need a firmware upgrade as this may be causing the problem...
Can any one elaborate how to do a firware upgrade with this combo with just the programming card that comes with the kit?? Or if any one can shed more light on the problem.. Gearing all is fine etc...
cheers!!!!!
Scott_Mantis is offline   Reply With Quote
Old 10-18-2011, 11:45 PM   #1015
hi guys,
cheers!!!!!
Old 10-19-2011, 06:22 AM   #1016
I can't help you out with the power loss issue, but I can tell you that you CAN NOT update the firmware on the ESC with field programming card. You have to purchase the 2-in-1 Advanced Program Box in order to connect the ESC to your computer.
http://www.hobbypartz.com/hobbywing-...ogram-box.html
It appears as though HobbyPartz is still out of stock on this. If you don't mind waiting, you can order the Turnigy unit from Hobbyking. They are the exact same unit.
http://www.hobbyking.com/hobbyking/s...less_ESC_.html
bugman72 is offline   Reply With Quote
Old 10-19-2011, 07:01 AM   #1017
B4power's Avatar
Originally Posted by Scott_Mantis View Post
hi guys,
cheers!!!!!
What batteries are your running? Maybe you did not set the right LVC amount thus the ESC always cuts off.
Old 10-19-2011, 12:06 PM   #1018
I have the SC8 combo that you are talking about. I have used it in an Ofna LX-1e and I now have it it a Nexx 8. I use 2X 2s 5000 Blue packs run at 4s. I have had none of the problems that you have talked about. It screams. Also runtime is pretty good. In a 5 min heat I will only use 1200 - 1500mAh. Maybe try adjusting some of the settings in the esc setup.
duanew is offline   Reply With Quote
Old 11-25-2011, 08:04 PM   #1019
Default ESC cut
Hi, i recentlly change to a xerun 8.5t motor with ezrun 60a esc. i,m having this problem which my esc got cut after a few minutes run.
My car is tt01 gearing 25 55. timing set to 5 and punch set to 6. esc run till cut and motor is hot too but can be touch.
I had my exrun fan replace with a yeah racing high speed fan. but fan is connect directly to the receiver. the old one i had cut away..
I had jus change my pinon from 55 to 58. able to achieve slight longer run time. But with my previous gearing of 25 55 on a 10.5t with max timing and punch, i don't have this problem and able to run till my lipo flat at 7.5v...
Anyone have recommendation? whether to gear up or down.. thought of changing my pinon to 28 and try as my ESC is hot..
Old 03-11-2012, 03:39 AM   #1020
I know this is an old post, but, thinking of getting a ezrun combo for my HPI Cup racer. Thoughts? Not sure about racing it, maybe, maybe not.
dazed1 is offline   Reply With Quote
Tamiya mini cooper sipaboy Electric On-Road 29687 Yesterday 04:07 AM
Duratrax Evader cheech4 Electric Off-Road 1159 03-25-2015 02:27 AM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
wich brushless system maylemay Electric Off-Road 38 06-09-2009 03:46 PM
Whats a cheap brushless system for a traxxas slash Leroy1234p Electric Off-Road 25 05-17-2009 08:07 PM
Xray copies academygaz Electric On-Road 151 11-03-2008 09:42 PM
