Old 03-22-2011, 07:03 AM   #976
Driver86's Avatar
Originally Posted by scottc View Post
Driver86
iam thinking if you 60 amp esc will Handel the castle 3800 motor that would be the way to go.
Thanks, I've been thinking about giving the Castle a shot. Anybody have an opinion on a HobbyWing motor?
Traxxas Slash 4x4 Platinum -60A Hobbywing ESC 10t and 17.5t EZRun motors
Traxxas Stampede -60A Hobbywing ESC, EZRun 5400KV motor
Tamiya TB-02 60A Hobbywing ESC, EZRun 5400KV motor
Duratraxx Vendetta SC Hobbywing 25A ESC, Tacon 4300KV motor
Driver86 is offline   Reply With Quote
Old 04-14-2011, 06:55 PM   #977
B4power's Avatar
I've been having trouble with my EZrun esc and Tacon 4420kv. motor. I have this set up in a 4wd buggy with stock gearing. When I first got the esc, I plugged everything and calibrated the esc. Then after a couple minutes, the car went slow. So, I tried to enable the LVC as I run Nimh. Well, after that I had to recalibrate, but the esd doesn't respond correctly when I do that. If I give throttle, the wheels barely turn and I hear a horrible sound. Like if someone was holding all four wheels. What is wrong???
Slash::FT B4::Evader BX::XXX-T-CR::TB-02::TR04::Slash 4x4 Platinum Edition::TT01
B4power is offline   Reply With Quote
Old 05-14-2011, 01:42 PM   #978
Hello to all
Found this site through google after trying to figure out what's wrong with our brushless.
We have got 2 cars with the HobbyWing 60A speed controller and they both have the 5.5t motors.
Mine is fine but lads one has a problem with the fan.
I got an uprated fan from Hong Kong and it has made no difference at all.
It's not a battery problem as we have switched various batteries and there is no difference.
Problem is that the fan doesn't even turn half as fast as the other car
My car the fan is very fast as soon as you turn it on, his fan takes about 15 seconds to get started and is half the speed.
Any ideas? thanks.
Ian78 is offline   Reply With Quote
Old 05-14-2011, 04:01 PM   #979
Originally Posted by Ian78 View Post
Hello to all
Any ideas? thanks.
take the fan off the esc & see how fast it runs
It could be they way its screwed onto the esc twisting the fan case, or it may be rubbing on something.
1101 is offline   Reply With Quote
Old 05-14-2011, 05:27 PM   #980
It moves freely, if you plug a fan into the reciever the speed is also different from one car to the other.
This is using the same fan.
Old 05-15-2011, 06:59 AM   #981
B4power's Avatar
What batteries is your buddy using?
Old 05-17-2011, 12:17 PM   #982
It's ok.
I experimented with the fan and in the end wired it up to the main positive and negative wires on the esc.
Also wired a extra switch just for the fan as it came on as soon as the battery was connected.
The one with the slow fan was a Verison 1 and the one with the fan at the correct speed was a Version 2.
It's all sorted now
Should I fit a small inline fuse just to be safe?
Old 05-20-2011, 03:19 PM   #983
hi all
i am new to the forum and wanting to get a tamiya tt 01 and i want to put a ezrun on it but dont know what ezrun to use pls helpdont know which motor to use for 1/10 on road and what lipo battery should i use?
neilbooth125 is offline   Reply With Quote
Old 05-20-2011, 04:46 PM   #984
JKL1031's Avatar
9t is best versatility.
China Lipos
China Speedos
China Chargers
You aint messin wit my dougie..
JKL1031 is offline   Reply With Quote
Old 05-20-2011, 09:20 PM   #985
Id have to agree. I have 4 of these in different RC cars.
Old 05-21-2011, 04:15 AM   #986
ok thanks guys but what lipo battery should
Old 05-22-2011, 08:37 AM   #987
Need help guys. Got a new Ezrun 25A with the 18T motor. Everytime coming out from reverse, the motor just wont turn. I got blinking green+solid red led.
neoxz is offline   Reply With Quote
Old 05-22-2011, 10:19 AM   #988
JKL1031's Avatar
Gens ace from hobbypartz or a turnigy if ur not a big time racer. Don't know aboutthe reverse problem. Try recalibrating throttle points. The manual should also tell u what that light combination means.
China Lipos
China Speedos
China Chargers
Old 05-22-2011, 10:26 AM   #989
Reverse throttle from transmitter,recalibrate your ESC and switch any 2 motor wires.
Hyper Mini STe (with custom chassis - 10TT) Novak 4.5T 550 motor/150A ESC
Phoenix ST
www.youtube.com/TheAL3xGR
AL3xGR is offline   Reply With Quote
Old 05-22-2011, 10:38 AM   #990
i know this is kinda off the topic but that website www . hobbyking . com their stuff is cheap, are they reliable
Tamiya mini cooper sipaboy Electric On-Road 29687 12-10-2017 04:07 AM
Duratrax Evader cheech4 Electric Off-Road 1159 03-25-2015 02:27 AM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
wich brushless system maylemay Electric Off-Road 38 06-09-2009 03:46 PM
Whats a cheap brushless system for a traxxas slash Leroy1234p Electric Off-Road 25 05-17-2009 08:07 PM
Xray copies academygaz Electric On-Road 151 11-03-2008 09:42 PM
