Old 03-17-2011, 05:42 PM   #961
Hi guys got a quick question I recently bought an ezrun 5.5 motor and 60a esc I decided to try soldering the motor wires directly to the motor the solder initially sticks but after a minute or two it becomes loose and doesn't stay on the metal contacts am I doing something wrong?would it just be easier attaching bullet connectors to the motor holes and wires any help would be appreciated
Jammin23 is offline   Reply With Quote
Old 03-17-2011, 09:51 PM   #962
Hi, does anyone know if installing the latest software will help improve the response time of a uncensored HB speedo?
Eat more possum!
Lees52 is offline   Reply With Quote
Old 03-18-2011, 01:56 AM   #963
cherry2blost's Avatar
Dry joint !
Clean the tab with a little motor spray to remove any greasy residue then heat the tab first, lay a little solder on it, heat the wire lay a little solder on it, let it flow into the strands, then while hot touch wire to tab and keep heat on until you see the solder 'flow' remove heat hold until hardened then leave to cool. No problems again.
Solder is not a 'glue' it is meant to mix and flow to create a solid joint.
Hope it helps
Cherry
Tamiya TA05 Ver II, Hobbywing 13.5T, KO PROPO PDS-2501 ICS, Eagle Racing 6000 65C LiPo, Hobbywing XTREME STOCK 518/213) Sanwa/Airtronics MT4 2.4G Radio.
www.racersinexile.org.uk | 'Official Certified' UK/Euro Importer for the Hobbywing XERUN Series Equipment We ship the world !!!| Quote code 'cherry' for 10% discount on our Web Store.
cherry2blost is offline   Reply With Quote
Old 03-18-2011, 04:50 AM   #964
Hi, I just had a look at the new HW software and there still isn't any new versions for for a the 60amp EZrun or 35amp either. Our only choices are the same 2 that were aviliable way back when they starting selling EZrun V.2 USB Supported ESC's. We are using the second choice version, its faster.
TBOTubed is offline   Reply With Quote
Old 03-18-2011, 07:37 AM   #965
Here is something else to consider. The leads on the motor wires for alot of brushless motors nowadays is just a continuation of the motor winds. These wires have a thin layer of insulation on them to keep the wires from shorting out in the motor. Make sure that you remove this to get a good solder joint. I don't have any ideas other than lightly sanding as small portion of the end of the wires. A dremel might help.
duanew is offline   Reply With Quote
Old 03-18-2011, 09:04 AM   #966
If it's not the insulation,you need a better iron.I use 80W for motors(use at least 80W and not the pistol-like iron).You use flux,right?Also what soldering iron do you have?
Hyper Mini STe (with custom chassis - 10TT) Novak 4.5T 550 motor/150A ESC
Phoenix ST
www.youtube.com/TheAL3xGR
AL3xGR is offline   Reply With Quote
Old 03-18-2011, 12:09 PM   #967
trickedout's Avatar
Trader Rating: 31 (100%+)
hey i just bought a used ezrun 60a esc/ 3300kv motor and i have a few questions. first i believe the mode or set button on the esc is broke as it doesnt respond, therfor i cannot calibrate the endpoints of full throttle neutral and brake. is there any other way to do it?i mean it all works and i still have throttle neutral and brake and reverse, but just dont know if maybe i could be hurting something? also with it in a hpi blitz with 88t spur and 23t pinion the motor seems to running pretty cool but the esc is getting rather hot, and it even hit thermal cutoff the other day. only ran 1 pack 7.4 lipo 5000 30c through it ... nothing is binding or anything and from what ive read that gearing seems to be close? the esc does not have a fan on it and im wondering where the fan would go and where it would plug in if i had or got one? Thanks! other than that it runs GREAT!
In the middle of some changes
*702 RC Raceway* *WindWater Raceway*
trickedout is offline   Reply With Quote
Old 03-18-2011, 04:04 PM   #968
Thanks for all the advice going to try a few things but first got to get a new soldering iron as I've only got a 25w!
Old 03-18-2011, 04:59 PM   #969
Maplins do a fantastic solder station is about 15 worth every penny it's their own brand blue one I have had a few over the years and is faultless perfect joint each time.
Old 03-18-2011, 06:30 PM   #970
Trader Rating: 217 (100%+)
Got to have a minimum of 40-45 watts. 25w isn't enough.
Andy Koback is offline   Reply With Quote
Old 03-19-2011, 06:00 PM   #971
Thanks peeps for all the help got a new soldering iron today and it works like a dream!
Old 03-20-2011, 11:20 AM   #972
Glad to hear it !!!
Old 03-21-2011, 11:50 AM   #973
Driver86's Avatar
Hey,
I traded a 2WD SC for a 4WD and it looks like my HobbyWing motors aren't going to handle the heavier 4WD truck and drivetrain. I got the 10T and 17.5T that are actually 360 motors in a 540 can and they're getting too hot. I've got the 60A ESC. What motor should I get to pair with the Traxxas Slash 4x4?
Traxxas Slash 4x4 Platinum -60A Hobbywing ESC 10t and 17.5t EZRun motors
Traxxas Stampede -60A Hobbywing ESC, EZRun 5400KV motor
Tamiya TB-02 60A Hobbywing ESC, EZRun 5400KV motor
Duratraxx Vendetta SC Hobbywing 25A ESC, Tacon 4300KV motor
Driver86 is offline   Reply With Quote
Old 03-21-2011, 05:21 PM   #974
RC MARKET's Avatar
you can choice goot or Hakko Temp can up to 380 deg C Soldring Iron
RC MARKET is offline   Reply With Quote
Old 03-21-2011, 06:01 PM   #975
scottc's Avatar
Trader Rating: 21 (100%+)
Driver86
iam thinking if you 60 amp esc will Handel the castle 3800 motor that would be the way to go.
scottc is offline   Reply With Quote
Tamiya mini cooper sipaboy Electric On-Road 29687 12-10-2017 04:07 AM
Duratrax Evader cheech4 Electric Off-Road 1159 03-25-2015 02:27 AM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
wich brushless system maylemay Electric Off-Road 38 06-09-2009 03:46 PM
Whats a cheap brushless system for a traxxas slash Leroy1234p Electric Off-Road 25 05-17-2009 08:07 PM
Xray copies academygaz Electric On-Road 151 11-03-2008 09:42 PM
