Old 03-27-2010, 05:21 PM   #856
JKL1031's Avatar
Originally Posted by Team Ash View Post
If you have the money to spend get lipo, something like 4000/5000mA with the highest "c" rating you can find . They will deliver all the punch you will ever need and also give good run time.
If you are limited by your wallet, like me (and many others) Just get whatever lipo you can afford. I have cheap Yeah Racing 3200 20c lipos. I have had them for about 18 months, never ballanced and I use them just for racing with an Assoc T4 with H/wing 60A and a novak 6.5. I get about 7-9 minutes run time and I won our clubs last open mod truck season with this set up. (mind you one of the batteries is getting a bit dull and will be replaced very soon)
Terry
wwwoooaaa wayy off.
Nothing to do with the batteries if its just cutting out. theres a good chance it is becuse of the transponder uve started using..Check the thread out about the guy who "kited" his car. they found out in there that there is a transponder interference.
JKL1031 is offline   Reply With Quote
Old 03-28-2010, 07:02 PM   #857
PaPeRo's Avatar
Originally Posted by JKL1031 View Post
thanks,,i will probly reconsider after hearing that, but after buying a lipo charger and 2 lipos, it wud come out cheaper.
Another option would be to get the 5900kv TACON motor. It's very smooth off power. You get the same performance as the 5.5T with smoother off power operation. Just keep in mind that the TACON motor is about 50g heavier than the eZRun and comes with 4mm bullets instead of 3.5mm on your ESC.
deans - dodgy electrics amps not sufficient
PaPeRo is offline   Reply With Quote
Old 03-28-2010, 09:21 PM   #858
JKL1031's Avatar
u think i cud push it with the 35A esc?
Old 03-28-2010, 09:33 PM   #859
PaPeRo's Avatar
It wouldn't hurt to try before spending money on a 60A ESC. The ESC has built-in thermal protection so it will shut off if it gets too hot. You'll know if the motor is too much for the ESC or not if it shuts off often.
Old 03-29-2010, 01:36 PM   #860
Trader Rating: 21 (100%+)
Default Thottle ATV trim ?s
Hopefully someone can help me out here....
I picked up a stocker SC10 tx/rx from my buddy to run in my Tamiya M04 with the ezrun 35a / 13T combo. The radio has Throttle ATV settings (both Hi and Lo).
How should I have these set when I go through the programming process? Should I max them out, then go through the calibration/setup process....or should I leave them at Neutral, calibrate the esc, then turn them to the max? Everything thing I've seen and read says it depends on the esc...
Sorry for the newbish questions in advance!
Steve
Steve420 is offline   Reply With Quote
Old 03-30-2010, 11:07 PM   #861
Trader Rating: 22 (100%+)
wwwoooaaa wayy off.
I was answering post 7185130 by kdn so I reckon I got it right.
About the start stop problem. I had a very similar thing happen and mine turned out to be a broken wire on the esc fan. It must have been shorting every now and then and somehow causing intermittent signal.
Is your car slow..Xray it!.......FK05, M18, M18t
RexX
Assoc...T3,T4, B4
Team Ash is offline   Reply With Quote
Old 03-30-2010, 11:49 PM   #862
JKL1031's Avatar
oh ok. yes that will do it too.
Old 03-31-2010, 03:34 AM   #863
WildCard75's Avatar
Ive got a EZrun 60A new in box. I was going to use it for a 1:10 off road truck project but had to use funds to repair current touring car. PM me if your interested.
Cheers,
Dan
TAMIYA TRF-415MSXX MRE07
SoCal
WildCard75 is offline   Reply With Quote
Old 03-31-2010, 08:59 PM   #864
JKL1031's Avatar
.5mm...cud i still squeeze those connectors in?
Old 03-31-2010, 11:14 PM   #865
PaPeRo's Avatar
Nope because the male end is 4mm and female is 3.5mm. If it was backwards ie 4mm female 3.5mm male then it could work.
Old 04-01-2010, 05:51 PM   #866
JKL1031's Avatar
i mentioned a motor noise earlier, i though it was a bearing, but im still getting it when the motor gets warm.
Old 04-04-2010, 04:59 AM   #867
mini696's Avatar
I am looking to run the eZrun 8.5T 60A in my SC10.
Would you recommend this?
D8, GO 5Port
Ve8, RX8 1900, Promatch 5100 4S
SC10, Hobbywing EzRun
mini696 is offline   Reply With Quote
Old 04-04-2010, 05:39 AM   #868
PaPeRo's Avatar
That combo should work fine in a SC truck.
Old 04-04-2010, 02:33 PM   #869
i got an EZrun v2 60a speedo in my TA-05 rain car
and this speedo worked all day in really really wet conditions , it never missed a beat and i am well impressed with the speedo
i was using an LRP 13.5 motor and my settings were max timing , max punch , min neutral zone with a gearing of 4.0 but could do with some more speed so will add 2 teeth to the pinion for the next rain race
no real replacment to the Tekin RS and 13.5 race car i use but i had great fun spashing in the rain and i collected some points for my championship
sidecarphil1 is offline   Reply With Quote
Old 04-05-2010, 06:28 AM   #870
mini696's Avatar
What gearing is recommended when using the 8.5t 60A in a short course (SC10)?
Would a 5.5t be overkill for shortcourse (8th scale track)?
D8, GO 5Port
Tamiya mini cooper sipaboy Electric On-Road 29687 12-10-2017 04:07 AM
Duratrax Evader cheech4 Electric Off-Road 1159 03-25-2015 02:27 AM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
wich brushless system maylemay Electric Off-Road 38 06-09-2009 03:46 PM
Whats a cheap brushless system for a traxxas slash Leroy1234p Electric Off-Road 25 05-17-2009 08:07 PM
Xray copies academygaz Electric On-Road 151 11-03-2008 09:42 PM
