Old 03-06-2010, 12:13 PM   #826
JKL1031's Avatar
thanks i changed it some days ago. all has been installed well. you can check it out here. http://www.rctech.net/forum/7096387-post785.html
sidenote: other companies program boxes seem to be pretty similar.
JKL1031 is offline   Reply With Quote
Old 03-06-2010, 01:47 PM   #827
Billetboy's Avatar
Trader Rating: 49 (100%+)
Can someone with firsthand knowledge tell me the power difference between the 9t(4300 380 size) motor vs. the Ezrun sensored 540 motor? It only seems logically that the 540 is more powerful, so no assumptions or guesses please. Cuz I already made the same assumption when picking a motor for my SCRT10, probably the heaviest of the offroad 1/10 vehicles. I ran a Novak Ballistic 8.5(5000kv) and it runs hot after 5 minutes. Another guy at the track has the 9t 380 size motor in the same vehicle, running 4 teeth taller pinion then me an it comes off after 15 minutes at 140-150 degrees.
I would prefer to run sensored, that is why I ask if the sensored motor of similar KV to the 9t make the same or more power than the 9t 380 motor. if it doesn't, then I am going to get the 9t.
Thanks in advance
David
***Losi 8T 2.0/O.S. Speed II/2060/Hitec 7945***
***Agama/Orion MTE 5 port/2013/Hitec 7945***
***Losi 8/Orion CRF Alpha MTE/2013/Hitec 7945***
Billetboy is offline   Reply With Quote
Old 03-06-2010, 03:07 PM   #828
JKL1031's Avatar
i cudnt tell you myself.
Today i went out for a few runs. i played with the timing from 0 to 22.5% and i cant really tell a real difference. is there supposed to be a noticeable difference or not?
Old 03-07-2010, 03:44 AM   #829
PaPeRo's Avatar
You'd only notice an increase in top speed.
deans - dodgy electrics amps not sufficient
PaPeRo is offline   Reply With Quote
Old 03-07-2010, 03:48 AM   #830
The higher your timing, the lower your low-rpm torque.
The higher your timing, the higher your rpm.
I tried all of the values and there is a difference.
I suggest you to set your DDR punch with your timing. When you put a high timing, try a high DDR punch to have a better low-rpm torque.
Durango DEX 210 MM / Reedy Sonic 6.5 / HW V2.1 120A 1S
Durango DEX 210 RM / Savox 6.5 / HW V2.1 120A 1S
Durango DESC 210R / Reedy Sonic 10.5 / SpeedPassion Cirtix Stock Club Race
Tamiya F103GT / Reedy Sonic 10.5 / HW V2.1 120A 1S
FG Sportline 2008 (Formule France package) / Zenoah G230RC
DaTaz is offline   Reply With Quote
Old 03-07-2010, 10:35 AM   #831
JKL1031's Avatar
ok ill try that next time first thing. possibly my pack was discharging at the same time i began to mess with it.
Old 03-07-2010, 10:50 AM   #832
JKL1031's Avatar
Originally Posted by Billetboy View Post
Can someone with firsthand knowledge tell me the power difference between the 9t(4300 380 size) motor vs. the Ezrun sensored 540 motor? ....
Thanks in advance
David
this is something i ran across while looking for an answer tomy own question; from castle's site.
"A high power capable brushless motor in electrical engineering and physics terms, has unlimited torque. We live in “the real world” so technically for us that’s not totally true, but – a brushed motor has a torque level that due to its design has an upper limit, regardless of how much power is being applied to it. That limit is low enough that you can see it clearly on an average track On the other hand, a high power brushless motor’s limit to torque in an RC vehicle is not within the bounds of the motor itself so much, but rather falls on the ability of the battery to deliver current to it. We generally don’t describe these motors in terms of “one has more torque than the other”, but rather “the 7700Kv motor is faster and draws more current than a 5700Kv motor in the same vehicle”. It draws more current, because it’s making the car go faster and doing more work than the 5700 motor is. As long as the batteries used are very good at supplying current without an excess of voltage depression (low internal resistance is good) both motors will appear to have the same torque, even though one is much faster than the other. Battery technology is constantly improving, and the first thing you’ll notice when you use a very good battery pack (or perhaps trying a Lipo pack for the first time) with these systems is a more “punchy” feel when you accelerate. The faster you set up the car to go at full throttle, the more reliant you are on good batteries to flow that current into the motor and maintain acceleration performance. So think of torque as a function of battery capability only.
maybe that helps..
Old 03-07-2010, 06:47 PM   #833
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
Originally Posted by TBOTubed View Post
Hi SG1
We also run a fixed gearing, speedo and motor class(HW EZRUN 60amp,HW 17.5, any brand lipo up to 5000mha, 4.2FDR). When first did testing, comparing 4 different cars,Tamiyas, Losi, XRAY, all with different internal ratios, all different wieghts, they showed no noticable difference in top end speed down the straight. The big difference was seen after several laps due to car set-up, free drivetrains and driver ability(dam that last one!) So if your getting left behind I might suggest set the punch control to the setting that makes the car comfortable to drive, insure that your car is as free as it can be or free-er, try different set-ups and practice,practice,practice
I'm using it in a 1/18 car running oval. The car runs approx. .2-.3 sec per lap faster with a speedcontroller that has higher timing. I think at this point it's just a timing issue.
**Team Scream**Parma/PSE**TQ Wire**Roche**Pemberton**BSR**Graupner/GM**SXT**
sg1 is offline   Reply With Quote
Old 03-08-2010, 01:54 AM   #834
Is it possible to run a 17.5 sensored motor with this speedy.
sean nolan is offline   Reply With Quote
Old 03-11-2010, 08:27 PM   #835
JKL1031's Avatar
the ESC is sensorless. unless the sensorless motor can run without being plugged? i dont know too much about sensored.
Can someone tell me where the braking force comes from? is this extra power being drawn from the battery or what? Im asking if i shud do without drag break if its just extra energy being used.
Old 03-14-2010, 12:06 AM   #836
JKL1031's Avatar
so,,my on/off switch broke at the lever knob.
Old 03-19-2010, 03:58 AM   #837
mjamesf's Avatar
Default HobbyWing EzRun ESC Temperature Overheat problem
Hi I am having Temperature overheat problems with my Hobby Wing EzRun ESC for two months now. Below are all the information of my car:
Tamiya TA05 (Belt Driven)
HobbyWing EzRun brushless ESC 60A (with Fan)
HobbyWing EzRun 5.5T Brushless Motor
5000mah 25C 2S Lipo Battery
Spur Gear 70T
Pinion Gear (25T, 24T, 22T, 18T, 17T) I've Tried all these
After approximately 2-3mins the esc temp will go above 50 degrees Celsius and the overheat protection will activate then cut-off the power.
I definitely cannot turn off the overheat protection coz it will burn my esc.
Need Help, thanks.
"RC is Contagious"
mjamesf is offline   Reply With Quote
Old 03-19-2010, 08:33 PM   #838
PaPeRo's Avatar
Are you running that setup in hot weather? If not it shouldn't be overheating unless you have some major binding somwhere. If you have another car try it in another car. Does your car roll easily without power?
Oh btw the ESC isn't supposed to thermal at 50C. The thermal cutoff is around 65C. Is the fan on the ESC working?
Old 03-20-2010, 06:35 PM   #839
I have had the same problem 3 min in shuts down,but i looked into it and its not the speedy the motor is the cause im not running motor fans, that wouldnt help.Try motor fans man.
Old 03-20-2010, 08:27 PM   #840
PaPeRo's Avatar
There is no way for the ESC to shut down the system due to motor overheating. If the motor overheats it will still operate until it eventually burns up and melts the plastic/rubber coating around the rotor.
There is definitely something wrong with your gearing if your motor overheats and melts.
Are you running a separate temp probe or did you use a temp gun to see how hot the motor got?
Tamiya mini cooper sipaboy Electric On-Road 29687 12-10-2017 04:07 AM
Duratrax Evader cheech4 Electric Off-Road 1159 03-25-2015 02:27 AM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
wich brushless system maylemay Electric Off-Road 38 06-09-2009 03:46 PM
Whats a cheap brushless system for a traxxas slash Leroy1234p Electric Off-Road 25 05-17-2009 08:07 PM
Xray copies academygaz Electric On-Road 151 11-03-2008 09:42 PM
