Old 12-15-2009, 01:31 AM   #721
Akudou's Avatar
You mean your 50% ion EPA or your remote trigger? If your EPA was set to 140% then i would advise you to bring it down on to a 100. 140% on the trigger would cost your esc and motor lifetime to cut down. Yes it makes a difference of heat generated during full throttle since more combustion of punch is created from the throttle control. I only full throttle when i wanna pull away from my opponents and during long slides, other than that i only pull the trigger a little since im having a high torque FDR
Originally Posted by mezan View Post
I only used 50% out of 140% of the motor power. Does this makes a difference of the heat generated during full throttle?
I only full throttle when I'm on a long curve.
Akudou is offline   Reply With Quote
Old 12-15-2009, 02:09 AM   #722
YES! The EPA I mean. I will try to see if there's any difference on the heat generated with heat sink installed. I need to change my heat sink fan too, since my current fan came with the heat sink seems to be no used.
Other settings that I could do to keep my motor temp down is? excluding timing, as mine is at 0 now. Is that advisable?
mezan is offline   Reply With Quote
Old 12-15-2009, 02:53 AM   #723
tom_chang79's Avatar
Lower your FDR a tad bit by lowering the pinion by a tooth or two... Don't lower it too much where you end up revving the motor all the time to go faster, excessive RPM can lead to heat also...
Does your chassis have a air pickup underneath the motor? If not, you can punch or cut some holes in the body and some holes out the rear to let air in...
Extrusions and fins as a heatsink for the motor is only effective if there is moving air. You can mount those fin with a fan on it for some forced air on the heatsink.
When fans are mounted on extrusion or fins, the direction of air should be towards the fins, you want the fan to blow into the fins, not pull air out of the fins.
RIP TAP RC
tom_chang79 is offline   Reply With Quote
Old 12-15-2009, 04:38 AM   #724
Akudou's Avatar
Always give your EPA some space, thats why i keep mine to a 100 but i dont trigger it to the max unless im losing grip of my car when taking a corner too wide. When you get a fan for the heat sink, make sure its a strong one etc. 0.025v or was it 0.25v.. 0 timing is fine as you need accelaration of torque from your motor unless if you want it on high speed then you can play around with the timing.
Old 12-15-2009, 05:29 AM   #725
To lower down my FDR, I thought I had to increase my pinion tooth?
Yes. My chassis has it.
I will take note of the air direction and install correctly.
I will take note of the EPA settings. I'm still new to drifting, thus need to practice my controlling (throttle & steering).
As of the fan, I will be changing to Yeah Racing tornado fan or something better. The current ones doesn't feel a thing.
Old 12-18-2009, 06:08 PM   #726
Ok guys.
I still have no success in lowering down my motor temperature.
Currently at 38/104.
Tried 29/104, 31/104, 35/104 with no success.
Any help here?
Old 12-19-2009, 04:57 AM   #727
cyanyde's Avatar
Ok guys.
Any help here?
Sounds like you're over revving. The 9T comes with a 14mm(if I'm not wrong) rotor which is very torquey and loves heavier gearing. Try FDR of 4.5 +- a couple of pinions. Be sure to check temperature every minute when doing this.
/Adrian.
RC FB Pages Subscribed:
facebook.com/EPBuggy
facebook.com/AllStarChampionship
cyanyde is offline   Reply With Quote
Old 12-19-2009, 05:06 AM   #728
Oops, I meant to say "Lower your gearing by increasing the FDR..."
RIP TAP RC
Old 12-19-2009, 05:34 AM   #729
So I assume I've to up my gearing to be ard 48/104 ?
Old 12-19-2009, 09:13 AM   #730
Suspended
Trader Rating: 30 (97%+)
Originally Posted by cheebs View Post
anyone? i am not getting any anwser from hobbywing. i only got two test runs from it. it's going to cost me 30$ to ship it its 60$ to buy another ( don't think i will do that but i don't know yet most everyone else seems to be getting better results) advise please
still no anwser from hobbywing its like they don't wanna honor thier product. any advice here?
cheebs is offline   Reply With Quote
Old 12-19-2009, 10:41 AM   #731
cyanyde's Avatar
Thereabout...
/Adrian.
Old 12-21-2009, 01:30 AM   #732
Thereabout...
I've change my heat sink fan to YR tornado fan. Everything seems better now with 31/104 gearing. Tried 38/104, motor gets hotter than 31/104.
Thanks everyone for the help!
Old 12-21-2009, 01:50 AM   #733
It's getting hot probably from your application, drifting right?
I've used the same gear ratio, roughly high 11s on my DF-03MS buggy, which had a 4600Kv (540-sized) Castle.
I replaced the motor in that buggy with the same gearing, but used the 9T (380 rotor 540 sized) Hobbywing, and it ran much cooler than the 4600Kv Castle...
It's odd that yours is heating up so bad... Did you check the bearing to make sure it's not seized up and that the motor is not fighting the bearing to spin?
RIP TAP RC
Old 12-21-2009, 08:01 AM   #734
mjamesf's Avatar
Default I have lot's of questions
Hi I'm newbie in EP Touring. I just bought the Ezrun 5.5T BL ESC 60A Combo.
My car is TA-05 4WD Belt Driven. I'm focusing more on Touring but I also drift just for fun and very seldom. My Pinion gear is 22T Spur gear 70T. My Battery is Nosram 3300mah NIMH but I'm changing to Li-po in a few weeks. My shell is HPI Nissan 350Z Greddy.
Just want to ask some questions:
1) What's FDR?
2) What's the formula to get the gear ratio? In tamiya manual its [(Spur/Pinion)x2.25] but I compare to others looks like their formula is different.
3) How to get internal gear ratio?
4) What's Total Gear Ratio & Final Gear Ratio? (Why is there so many types of gear ratio)
5) What's the suggested Temperature for my Motor, ESC, & Battery so I will know if i'm overheating my electronics.
6)What's the suggested gear ratio if I want to get the maximum speed from my Brushless System? (Please state Pinion & Spur gear Teeth No.)
7)What's the suggested Li-po battery & specs to use with my BL System?
8) If I want to change gear ratio is it important to change both pinion & spur gear or I can just always stick to 1 pinion/spur and just always change the other to adjust.
Please can someone answer all the items
"RC is Contagious"
mjamesf is offline   Reply With Quote
Old 12-29-2009, 09:07 AM   #735
drs92's Avatar
Trader Rating: 36 (100%+)
Send a message via AIM to drs92
Hey guys Im running indoor, bout small/medium sized track. I have a 8.5t 60a ezrun combo and was going to run it in my sc-10. But I just bought a lazer too for indoor and was wondering if I should put the 8.5t in that or buy the 5.5t combo? If I put the 8.5t combo in the lazer what combo for the sc-10? 13.5? 9t? Will the 8.5t be fast enough in the lazer? I NEED HELP PLEASE
TLR 22B
drs92 is offline   Reply With Quote
Tamiya mini cooper sipaboy Electric On-Road 29687 Today 04:07 AM
Duratrax Evader cheech4 Electric Off-Road 1159 03-25-2015 02:27 AM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
wich brushless system maylemay Electric Off-Road 38 06-09-2009 03:46 PM
Whats a cheap brushless system for a traxxas slash Leroy1234p Electric Off-Road 25 05-17-2009 08:07 PM
Xray copies academygaz Electric On-Road 151 11-03-2008 09:42 PM
