Old 06-20-2009, 04:38 AM   #526
Conrad's Avatar
Does anyone have a picture of any of the ezrun systems in there 1/12th pan car? Just wondering how well they fit given the esc, heatsink, fan are quite tall and 1/12th shells are a bit low in the middle
Conrad is offline   Reply With Quote
Old 06-22-2009, 08:00 AM   #527
redzone's Avatar
in the instructions for my mamba max, it says not to extend the esc - motor wires as it will no longer run properly. can anyone tell me if i can extend the wires on my ezrun 60a esc? i cant fit it into my TA03F properly if i cant extend them...
79 mk1 Sand Scorcher, 09 Buggy Champ, TB01 Lancer Evo 7, TL01 Lancer Evo 6, TA02 Castrol Celica, TA02SW Taisan Porsche, TA02W Castrol Supra, TA03F Starion drifter, M06pro Gemini coupe, Tamiya Dyna Storm 5.5t, Stadium Blitzer, Bear Hawk, Baja FAV, Egress!
redzone is offline   Reply With Quote
Old 06-22-2009, 08:34 PM   #528
Will the EZRUN ESC run a brushed motor?? if so How??
dirttrackdemon9 is offline   Reply With Quote
Old 06-22-2009, 09:04 PM   #529
cannon's Avatar
Trader Rating: 35 (100%+)
NO
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 06-25-2009, 04:21 PM   #530
Tizer's Avatar
i went back like ten pages in this topic but couldn't find anything about my problem.
i have a 35A esc with a 9t motor (the 380 type), and the esc has died a bit. the dragbrake is on the whole time, so when i don't push the throttle the car immediatly brakes hard. also the reverse doesn't work.
the programcard doesn't work on it anymore. i can change the settings with the programcard, but nothing happens. the dragbrake stays and the reverse still doesn't work. i've tried another programcard from someone else but that doesn't work either.
i have run 2 days with this setup now, and the esc doesn't die... is it fixable? a friend of mine had the same problem, his esc just went up in smoke when he tried to set it up differently but mine still 'works'
Tizer is offline   Reply With Quote
Old 06-25-2009, 04:58 PM   #531
Trader Rating: 23 (100%+)
Send a message via Yahoo to JATOdriver
try reseting the neutral position on your Tx mine did the same on my off road truck and i looked at my Tx and the neutral position was set wrong and the esc wast pickiing up neutral or reverse
JATOdriver is offline   Reply With Quote
Old 06-29-2009, 02:07 PM   #532
aittam's Avatar
Hello,
I've just purchased an EzRun 60A Version 2.0 brushless ESC + program card Version 2.0 + 8.5T brushless motor combo.
I have a problem configuring the EzRun esc with the program card that was included in the package: i cannot access and modify item 11 (Motor Rotation) and item 12 (Lipo Cells).
When i connect the program card to the esc i can only access items from 1 to 10.
This is what i do everytime i need to program the esc:
1) disconnect the battery from the ESC
2) disconnect the trio wire that goes from the esc to the receiver.
3) connect the trio wire to the program card
4) connect the battery to the esc
5) turn on the esc
6) start programming.
Any help would be much appreciated.
Regards.
Mattia.
http://rcmanici.blogspot.com
aittam is offline   Reply With Quote
Old 06-29-2009, 07:46 PM   #533
beemerfan's Avatar
Trader Rating: 34 (100%+)
I have the 60A EZRun and I extended all three motor wires by about 2.5 inches. I haven't had any issues with it.
beemerfan is offline   Reply With Quote
Old 06-29-2009, 07:57 PM   #534
NEVADAGARY's Avatar
I bought a 35A one about 6 months ago and finally put it into my Slash oval racer and I am impressed. All the guys I race with laughed and gave me the rasberries until they saw how it performed. Really quick and responsive and hardly any heat. For the price it's amazing.
Gary D.
NEVADAGARY is offline   Reply With Quote
Old 06-29-2009, 10:45 PM   #535
Hi there.
My 9T/35A just arrived. I'm impressed. Better motor connectors than on my LRP
& the programming card is such a good idea.
What is the 'dragbrake' & how does it differ from normal brake??
1101 is offline   Reply With Quote
Old 06-29-2009, 10:52 PM   #536
beemerfan's Avatar
Drag brake is the amount of brake that is applied automatically when your transmitter throttle is at neutral. By setting drag brake, your car brakes automatically at the preset amount so you don't have to push the throttle trigger forward and you get a consistent amount of braking.
Old 06-29-2009, 11:04 PM   #537
I had it in my 1/12 CRC but I sold it some time ago. You will need to remove the fan to make it fit under a normal 1/12 body. I run 1800mah 2S lipo with a 8.5T motor and the ESC is ice cold after 15min run. It may get slightly warm if you use the 35A esc. But both will work without a fan for 1/12.
http://www.gpm-parts.com
gpm-parts.com is offline   Reply With Quote
Old 06-30-2009, 03:58 AM   #538
Fast XXXS's Avatar
Trader Rating: 49 (100%+)
Ok quick question, but i think it may have got answered with the post above, anyway can i get away with running a 8.5T 4000kv 540 size motor with a 35A esc in a stadium truck? geared safely ofcoarse.
Fast XXXS is offline   Reply With Quote
Old 06-30-2009, 05:00 AM   #539
Benzaah's Avatar
Trader Rating: 21 (96%+)
From testing that Ive done If its sensorless you'll be fine if its sensored you'll be hating it. These small speedies are cheap and run heaps of basher type motors as long as they are sensorless. Try a team Losi motor. Its what ive got in my xxx cr in a 4800kv motor and it's ballistic. But i ran it with a 17.5 and a 13.5 sensored motor previously and it was a useless piece of crap. My 2c.
Adelaide RC - XRAY Xb216de & Xb416
Walter Rc Hobby - Serpent 4X
Nosram - R1wurks - Sanwa - Hudy - Muchmore
Benzaah is offline   Reply With Quote
Old 06-30-2009, 06:20 AM   #540
Fast XXXS's Avatar
Ok cool thanks, just what i wanted to hear. So are you running a 35A speedy?
Tamiya mini cooper sipaboy Electric On-Road 29687 12-10-2017 04:07 AM
Duratrax Evader cheech4 Electric Off-Road 1159 03-25-2015 02:27 AM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
wich brushless system maylemay Electric Off-Road 38 06-09-2009 03:46 PM
Whats a cheap brushless system for a traxxas slash Leroy1234p Electric Off-Road 25 05-17-2009 08:07 PM
Xray copies academygaz Electric On-Road 151 11-03-2008 09:42 PM
