Old 04-16-2009, 01:59 PM   #481
Originally Posted by joe of loath View Post
It's a 380, but it's the same size as a 540, if that makes sense
A little. But 380 and 540 are different sizes. So confusing :P
So it has the torque of a 380 motor? But it's the size of a 540 motor?
So can I still run this baby for drifting?
grategenin is offline   Reply With Quote
Old 04-17-2009, 01:29 AM   #482
Would a better explanation be its a 380 SIZE motor made to look & fit like a 540 (??)
1101 is offline   Reply With Quote
Old 04-17-2009, 02:45 AM   #483
Drifting101's Avatar
Yer kinda
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 04-17-2009, 04:51 AM   #484
joe of loath's Avatar
It's a 380 motor in a 540 sized can. The heatsink fins add width, and there's a lump on the end to add length.
It'll be fine for drifting.
HPI E-Firestorm - Tamiya TA05 racer (carbon chassis, 10.5 brushless etc) - LRP Blast S10 BX - Revo 2.5r truggy conversion (in progress)
joe of loath is offline   Reply With Quote
Old 04-17-2009, 07:32 AM   #485
im fairly new to onroad electric racing im running a mini with 35amp 13t brushless motor and i was wonder if i would damage the esc if i use my 3pk abs function,cheers
ARC R10/2015 - HOBBYWING - PROAMPS - ORCA
BRCCC
elche_83 is offline   Reply With Quote
Old 04-17-2009, 01:54 PM   #486
Can I run a 7.2v battery without bogging?
Old 04-17-2009, 05:08 PM   #487
Yes, If you read the instructions they say up 11.1V is safe
Schumacher
Old 04-22-2009, 07:25 AM   #488
redzone's Avatar
Originally Posted by TBOTubed View Post
Hey Redzone-with the motor disconnected from the ESC use your ohm meter to check continuity between all 3 terminals to one another one at a time, there should be continuity between everyone(no resistance), There should No continuity between any of the 3 terminals and the outside case of the motor or shaft. With a volt meter hooked up between any 2 of the terminals, give the shaft a quick spin with your fingers,it should produce a bit of voltage, do this to every one.
Now, with the motor and esc hooked up like normal in your car,get out your volt meter, the negitive lead goes to the negitive of the battery,the positive you attach to one of the three terminals on the motor,turn on transmitter and esc with battery hooked up like normal, apply very light throttle, you should be able to read voltage, Maybe about 1 volt less than your battery voltage eg. 6.9 volts. Do this for every termial. If you increase the throttle to much you will get a lower reading because of the sampling rate of the digital volt meter. See how you get on.
Kistner -cant find any info on a CC Esc
ooooooooooook, finally got to doing this.. motor checks out fine, esc seems to do what you said above ok, cant get a real good test on it though as everything heats up so quickly i dont want to melt anything. its definitely not my spektrum receiver as i checked it on another set. i think its the esc myself...
79 mk1 Sand Scorcher, 09 Buggy Champ, TB01 Lancer Evo 7, TL01 Lancer Evo 6, TA02 Castrol Celica, TA02SW Taisan Porsche, TA02W Castrol Supra, TA03F Starion drifter, M06pro Gemini coupe, Tamiya Dyna Storm 5.5t, Stadium Blitzer, Bear Hawk, Baja FAV, Egress!
redzone is offline   Reply With Quote
Old 04-22-2009, 03:19 PM   #489
Default Which motor
So after some reading im gonna get the 60 amp esc, with either the 8.5t or 13.5t motor. Its going in a redcat volcano (truck). Im not sure how much it weighs but its under 5 pounds, maybe like 4 with the battery. Its a 1/10th scale 4wd. I know some guy put a 8.5 in a slash and it was good. But would the 8.5 not have enought torque, or should i just go with the 13.5?
Edit: 4 pounds is 1800 grams, and people said that the 380 sized motor will push a 1500 gram car pretty good, so im thinking that a 1800 gram truck with the 540 motor at 8.5 turns would be ok.
chevyderek72 is offline   Reply With Quote
Old 04-22-2009, 03:59 PM   #490
redzone's Avatar
the 8.5 combo will be perfect. plenty of torque. just make sure you gear it properly. i only killed mine through stupidity (hit a puddle)
Old 04-22-2009, 04:27 PM   #491
any recommendations on how to gear a 5.5t motor on a quite large track (outdoor) ?
Hatebreed is offline   Reply With Quote
Old 04-25-2009, 04:18 AM   #492
How do you open the motors? I feel um... challenged trying get it open
Schumacher
Old 04-25-2009, 01:07 PM   #493
Default fan
Im just picked up some 8.4v batteries, and i was wondering how to change the fan so it can do the 7 cell batteries. I thought i read somewhere that you can re-wire it or something. What do you have to do for that? Do i just buy a new fan, or what?
Old 04-25-2009, 07:10 PM   #494
evanwest94's Avatar
Send a message via AIM to evanwest94
Can you use a 3.0t motor with the ezrun ESC?
evanwest94 is offline   Reply With Quote
Old 04-27-2009, 07:07 AM   #495
redzone's Avatar
you can replace the original fan with a higher rated one for use with higher than 7.4 volts, just unsolder/resolder where they go on originally.
and they say not to go lower than 5.5 with the 60A and 9T with the 35A esc.
Tamiya mini cooper sipaboy Electric On-Road 29687 12-10-2017 04:07 AM
Duratrax Evader cheech4 Electric Off-Road 1159 03-25-2015 02:27 AM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
wich brushless system maylemay Electric Off-Road 38 06-09-2009 03:46 PM
Whats a cheap brushless system for a traxxas slash Leroy1234p Electric Off-Road 25 05-17-2009 08:07 PM
Xray copies academygaz Electric On-Road 151 11-03-2008 09:42 PM
