Old 12-31-2008, 09:50 PM   #316
nexxus's Avatar
Trader Rating: 302 (100%+)
Haven't had any cogging here running a VXL motor off the 60A esc.
A800 / A800X Awesomatix
Don't worry about what I'm doing.
Worry about why you're worried about what I'm doing.
"Ego is the anesthesia that deadens the pain of stupidity."
nexxus is offline   Reply With Quote
Old 01-01-2009, 12:55 AM   #317
C Reedy's Avatar
Well i have a novak 6.5r and i run it on nimh's while my cousin and uncle have the EZ-Run 60 amp with EZ-Run 8.5t motors and lipos and their's go way faster and have much more punch than mine. I think they are of very good quality for such a low priced system.
C Reedy is offline   Reply With Quote
Old 01-01-2009, 01:55 AM   #318
aussierevo's Avatar
Trader Rating: 14 (100%+)
i recently purchased the 60 amp 5.5 t combo for my TA05 with nimh batt's and haven't experienced the cogging at all with mine.....my only issue with the system has that it has shown up all my flaw's in car setup and driving skill....the thing just goes hard..........a lot of fun for a cheap and useful system.
In relation to FDR, there is a heap of info on other forum's, but this link does provide an explanation,
http://www.robinsonracing.com/tips.html
and you can always go to www.gearchart.com to help you calculate FDR for your car.
Speed Passion F1.
Hobbywing ESC and Motor, SMC Batteries
Meakin Park Club Member
Team ARGO RC - Like us on Facebook
aussierevo is offline   Reply With Quote
Old 01-02-2009, 03:43 PM   #319
JSR
Trader Rating: 18 (100%+)
Originally Posted by george2411 View Post
Hi again.
i have some notes regarding the dbx brushless.
So:
1) The motor tends to overheat while the esc stays a little warm but not too hot. (with the 35a esc stays cooler but the 35a overheats)
2) I read somewhere that if you want your brushless motor to run cooler you must disable the drag brake and reduse the punch.Is this true?
3) And one last thing. The 60a Esc gives more power to the motor than the 35A esc? Is it possible that with the 60A the car is faster in performance?
Please help........
George -
1. I believe your overheating problems comes from the motor. It's a 380-size motor trying to pull a 1/10+ size truck (I put "+" because it's a fairly large 1/10). The smaller motor is straining to pull it, causing it to pull more current and thus heat more.
2. yes, going conservative on the settings will run cooler, but again your motor is overheating because it's too small. Get the 540-size x.5T motors and you should be fine.
3. If the ESC is not hot, you're probably not maxing the constant current capability, but the peak currents during on-off throttle and hard accleration may be limited. The 60A ESC would be a good precaution for youe setup.
Now I have a question for you. I'm looking to do a BL DST in the future also. What motor mount did you use and did you have to do any drilling, etc?
Thanks.
JSR is offline   Reply With Quote
Old 01-03-2009, 08:10 PM   #320
dameetz's Avatar
Default Still looking for some answers
I have ezrun 60A with 5.5T. Questions: 1) I m using 4PK radio with digital servo, can i use the HRS mode with this ESC? 2) Is the 5.5T has bonded or sintered magnet rotor? If not can i replace it with some aftermarket sintered magnet rotor? What will be advantage of having Sintered rotor magnet? 3) I m using 7.4v 2 cell Lipo batt, whats the volt cut off to be set with the esc? 4) The ESC instruction say i can use it with 5.5t motor and above, so in the future can i use it with an LRP X11 5.5T Motor(it has higher kV rating as the hobbywing 5.5t motor)? Thanks in advance for the answers.
dameetz is offline   Reply With Quote
Old 01-04-2009, 12:43 AM   #321
Drifting101's Avatar
1) That is a servo mode not motor mode so it dont matter
2) I beleive it is bonded and no you cant replace it
3) i like 3.2 per cell or if you want more security try 3.4 per cell
4) I believe so
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 01-04-2009, 07:24 AM   #322
dameetz's Avatar
Thanks for the info. I wonder whats the advantage of sintered magnet over the bonded one?
Old 01-05-2009, 01:40 AM   #323
cannon's Avatar
Trader Rating: 35 (100%+)
For all Hobbywing fans , I just received an updated pricelist from the company and they have incresaed prices by over 10%.
Still a cheap ESC but a 10% increase in these times .. smart thinking
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 01-05-2009, 10:40 AM   #324
RC MARKET's Avatar
http://rcmarket.com.hk/index.php?cPa...&filter_id=110
RC MARKET is offline   Reply With Quote
Old 01-06-2009, 06:06 AM   #325
nexxus's Avatar
Watch those fans guys! Reports of an Ezy-Run actually melting because the fan stopped (95 degree celcius thermal cut out is a tad high!)
http://www.tamiyaclub.com/forum/inde...00&qpid=305175
Old 01-07-2009, 01:01 AM   #326
sporadicidiocy's Avatar
Aye, the fan that came with is kinda crappy, wanted to replace with a 12V 30mm but they're kinda costly for what they are.. seen them at $6-12 average online
So, I replaced it with a 12V 40mm fan from an old northbridge chipset cooler that costs me nothing.. works like a charm, much cooler too.
90% Sakura Zero: Reventon S V3.0 10.5T
Sakura Ultimate: GTB2 17.5T
F104 Pro: SXX V2 Trackstar 21.5T
F103 Chevronmodels 6-wheel conversion
sporadicidiocy is offline   Reply With Quote
Old 01-07-2009, 02:42 AM   #327
hi everyone . . . im very new to the r/c world, so pls dun flame me if im
stupid . Got myself the eZrun combo 60A & 5.5t . . . its runs like hell
but the problem is after running bout 10 mins, the batt im using is 4600niMh
7.2v . . . the batt got so hot that the connectors melted, meaning the
male/female connectors from the esc to the batt . . . it actually fused
together to the plastic connectors. If im not mistaken, izzit bcs of the
current draw that is too HIGH? Out of the 10 mins, most of it goes to full
throttle. Btw im just running a HSP monster truck . . . yes its lousy,
good for newbies like me.
dahermit23 is offline   Reply With Quote
Old 01-07-2009, 02:52 AM   #328
cannon's Avatar
Let me guess .... standard Tamiya style plug that came on the ESC?
They are rubbish. Poor power transfer and inefficient . Will overheat easily
Old 01-07-2009, 02:53 AM   #329
What connectors are you using?
If it's tamiya.. then there's your problem.
The resistance on them is just too high, which generates heat.
Try to get some Deans Ultra-T connectors, they'll save you tons of trouble.
Old 01-07-2009, 02:54 AM   #330
yes . . . thats the one 'tamiya' style connectors, well any advice, just replaced them and im not running it yet . . . anyways my truck gearing got problem after smashing sideways against a wall. Oh ya, the batt also gets very hot too, any problems with the ezrun running with nimh which i expect draws too much from the bat which causes heating . . . should i go for lipo . . . in manual states lipo '2s: use stock fan, 3s:change high v fan . . . wats the meaning of the 2s and 3s???
Tamiya mini cooper sipaboy Electric On-Road 29687 12-10-2017 04:07 AM
Duratrax Evader cheech4 Electric Off-Road 1159 03-25-2015 02:27 AM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
wich brushless system maylemay Electric Off-Road 38 06-09-2009 03:46 PM
Whats a cheap brushless system for a traxxas slash Leroy1234p Electric Off-Road 25 05-17-2009 08:07 PM
Xray copies academygaz Electric On-Road 151 11-03-2008 09:42 PM
