eZRUN brushless system >
Old 12-06-2008, 04:31 PM
  #301
Super Moderator
nexxus's Avatar
Trader Rating: 306 (100%+)
Originally Posted by LOSI123 View Post
Anyone tried the ezrun 9turn /35amp esc combo on a 1/10th 2wd stadium truck (Evader ST) would the esc handle it?
The Evader's transmission won't though, I tried the Brushless route on the Evaders, was lucky to get through a pack without having to replace a spur.
It's kind of like turbocharging a Kia Rio. Cute idea, but don't spend your hard earned $$ doing up what is essentially a budget basher.
nexxus is offline
Old 12-06-2008, 07:14 PM
  #302
Trader Rating: 22 (100%+)
Default evader
My son ran a 12 turn brushed motor in his Evader and had no problems. Was the spur melting or was it stripping out. I would say go for it. I have the Tekmodel 60A with a 10.5 Novak in a xxx-t and love it. Great way to go for the money. I am thinkng about going to 8.5.
ghj1997 is offline
Old 12-06-2008, 09:12 PM
  #303
LOSI123's Avatar
Trader Rating: 63 (100%+)
my ? is more would the 35amp esc handle a hobbywing 9turn in that application.
LOSI123 is offline
Old 12-07-2008, 02:53 AM
  #304
Drifting101's Avatar
The esc is rated down to a 9t so yes
Drifting101 is offline
Old 12-07-2008, 03:29 AM
  #305
Super Moderator
nexxus's Avatar
The Evader is fine with the rpm, I have had a 9 single in and was ok, it's the TORQUE of the brushless motor that causes the issues.
nexxus is offline
Old 12-12-2008, 12:02 AM
  #306
Hi again.
i have some notes regarding the dbx brushless.
So:
1) The motor tends to overheat while the esc stays a little warm but not too hot. (with the 35a esc stays cooler but the 35a overheats)
2) I read somewhere that if you want your brushless motor to run cooler you must disable the drag brake and reduse the punch.Is this true?
3) And one last thing. The 60a Esc gives more power to the motor than the 35A esc? Is it possible that with the 60A the car is faster in performance?
Please help........
george2411 is offline
Old 12-13-2008, 11:02 AM
  #307
vlozity's Avatar
i moved the eZrun system to my Cyclone drifter, 100t stock spur with 36T pinions and worked like a charm. slammed lightly into a wall during practice and my novak velociti 6.5 stopped working ... weird. i'm back to using the blue 9T (380) motor which wasn't bad at all in the indoor track (asphalt), heat never was an issue as when it was installed on my TA03 drifter.
vlozity is offline
Old 12-16-2008, 06:13 AM
  #308
maximebeauvais's Avatar
Trader Rating: 7 (89%+)
Houston, we have a problem
I bought the ezrun 35A ESC with a 13T brushless motor.
I have installed the combo in my 1/12 and guess what. When I press the throttle at full speed it kind of stop but if I release just a little bit the throttle it goes back at full speed.
Also, If I do a complete stop and press the throttle full, it does like a stop/go, stop/go, stop/go...etc and like I said, if I remove the throttle just a little bit, it goes ok.
One of the racer at my track had the same problem but he don't remember what he did to fix the problem
Any idea?
PS: I tried all different programmation with no help.
maximebeauvais is offline
Old 12-17-2008, 01:15 AM
  #309
Sounds like you didn't set the end points properly
Old 12-17-2008, 03:23 PM
  #310
mike williams's Avatar
Trader Rating: 45 (100%+)
do you guys think that the 60a, 5.5t combo will work well with a T4 with foams tires for indoor carpet racing???
let me know as i would like to order asap!!
\Thanks
mike williams is offline
Old 12-17-2008, 03:27 PM
  #311
Yes it will
Old 12-17-2008, 08:18 PM
  #312
Trader Rating: 19 (100%+)
hey guys!!! i was referred here from the electric offroad forum. was considering one of these esc/motor combos from yeah racing for my T4. just getting into electric from nitro so not too hip on all the specs and what not. which combo would you recommend i try in order to keep up in a stock truck class where most are running the 13.5 novak brushless setup? thanks in advance!!!!
nitro0619 is offline
Old 12-17-2008, 08:38 PM
  #313
Super Moderator
nexxus's Avatar
I'd get the 60A controller and a Trinity 13.5 which is race legal and can be run as a sensorless motor.
The ESC's seem really good the motors, not so much.
I am running a 60A ESC with a Traxxas VXL motor in my DF-03RA and it absolutely hammers on 2s Lipo, I figure the 3s would be insane.
nexxus is offline
Old 12-31-2008, 07:25 PM
  #314
dameetz's Avatar
Hi everone, i m a newbie when it comes to electric. I have read the whole of this page and decided to get the ezrun 60a with 5.5t as my first brushless system. I have few q's though. 1) Is there any version of 60a other than v1.1? I m under impression that the v1.1 has cogging issue at start up. 2) What is the difference btwn Bonded and Sintered rotor? Is the hobbywing 5.5t bonded or sintered? If its bonded can i replace it with other brand sintered rotor which available separately? 3) I ll be using it with 2 cells Lipo batts, whats the cutout voltage for it to be set? 4) Can somebody care to explain FDR means and how do you actually calculate it? I ll be using it in an Xpress mini MRR2 by the way. Thanks.
dameetz is offline
Old 12-31-2008, 08:38 PM
  #315
Bugle's Avatar
I just got a 60A v1.1 with 17.5t and the cogging isn't that bad if you nail the throttle, once the cars rolling it can smoothly run at low speeds. Supposedly the cogging isn't as much of a problem with lower turn motors but I haven't tried yet.
Bugle is offline
