Old 08-16-2008, 02:47 PM   #1
Trader Rating: 24 (100%+)
Default Motor Cooling Fan Blowing Direction
Hi, should I install the cooling fan so that the air is blowing from the motor, or to the motor?
Thanks in advance.
bluejays is offline   Reply With Quote
Old 08-16-2008, 03:06 PM   #2
a_main_attendee's Avatar
Location: Colorado, USA, The land of the free and the home of the brave!
Thanks in advance.
definately blow the air towards the motor. Applications that require a fan to blow air away from the object are usually sealed devices that require a "vacuum" in order to introduce colder, higher pressure air into the low pressure area. This isn't the case in an Rc car where motor components and areas arn't neccesarily sealed, therefore the colder air can be introduced by means of air passing over the heated object, not by means of a vacuum to introduce higher pressure air into a specified area.
sorry if this didn't make much sense, i typed it fairly quick.
Support your local tracks!--|--e-teamhobbyplex.com--|--corrc.org--|
NNFaN Paints - Add some pride to YOUR ride.
a_main_attendee is offline   Reply With Quote
Old 08-16-2008, 03:11 PM   #3
Thanks for your help!
Old 08-16-2008, 06:13 PM   #4
When I try to run it with the fan blowing on the motor, it gets really slow. Someone told me that the magnet of the motor gets in the way of the magnetic field of the fan. ???
redbones is offline   Reply With Quote
Old 08-16-2008, 07:22 PM   #5
ta_man's Avatar
Trader Rating: 151 (100%+)
I've had that happen to me.
Two solutions:
1) Move the fan a little further away from the motor.
2) Get some steel shim stock and make a magnetic shield over the fan motor.
I've done both.
ta_man is offline   Reply With Quote
Old 08-16-2008, 07:41 PM   #6
Mooshu Beef's Avatar
A main, that was beautifully explained
Try turning the orientation of the fan. When I mounted my motor differently (rotated it) the fan worked again.
I am a man of few words.
Mooshu Beef is offline   Reply With Quote
Old 08-16-2008, 07:42 PM   #7
katfish317's Avatar
I used to use a heat sink with a fan mounted too it, when you were under hard acceleration the fan would almost stop due to the magnetic field of the motor, I got rid of it and have had no priblems since.
katfish317 is offline   Reply With Quote
Comm Cutting Motor Direction f1larry Electric On-Road 3 01-24-2006 11:00 AM
JRXS for sale; comes with GTX, metal gear servo, 3700 batt, motor cooling fans, motor Euge R/C Items: For Sale/Trade 16 10-12-2005 05:07 PM
Which Direction is the "normal" direction bvoltz Rookie Zone 8 07-26-2005 01:08 PM
motor cooling fan RCNitroDude999 R/C Items: Wanted to Buy 2 02-08-2005 05:28 PM
EP: Fan for motor cooling KJ Malaysian R/C Racers 148 11-19-2003 06:10 PM
