Old 09-25-2008, 08:44 PM   #61
Suspended
Trader Rating: 4 (75%+)
i like that body i just picked mine up today... i hope to have it painted this weekend
qcstrokr is offline   Reply With Quote
Old 09-25-2008, 08:44 PM   #62
artwork's Avatar
Trader Rating: 62 (100%+)
Here is mine already to cut out and run...probably will try it next week!
Sanwa | R1 Wurks | Avid | 2mm Designs
artwork is offline   Reply With Quote
Old 09-25-2008, 08:46 PM   #63
Suspended
nice job! it looks real good
Old 09-25-2008, 08:53 PM   #64
KoBe24's Avatar
Trader Rating: 26 (100%+)
Here's mine just finished it yesterday.
KoBe24 is offline   Reply With Quote
Old 09-28-2008, 06:17 PM   #65
yyhayyim's Avatar
Had a good day of testing with the new R9-R body today at my home track. This was my first time running the R9R and all I can say is WOW!!!
I ran the body on my Mi3.5 and ran the new Jaco blues, and 10.5BL motor. Ran the car with Schumacher blue springs up front(16lbs), and whites in the rear(14lbs), 2.5 rear toe, and the mounted the wing on the rear hole on the wing mount. Car was really good...I was able to run my fastest lap times with 10.5 and Jaco blues with the new R9R.
Yohan Hayyim [Associated RC10B4.1]
"Release the Kraken"
yyhayyim is offline   Reply With Quote
Old 09-29-2008, 11:40 AM   #66
baf1's Avatar
Default r9r
it is the fastest body ive ran....
1983.TC3,XXXS,MI3,JRXS,DB12R,TC5R,JRXSR,PRO4,CYCLONE,SC8,SC10,009,HPI BLITZ,LOSI 8,b4.1,b44,serpent impluse,serpent impact 2wd,serpent impact m2 4wd.HotBodiesD8.RC 8.2 .SC 10#2.sc10 4x4.b4 2wd buggy.scte4x4 losi.techno dno8 conversion.Techno Rc8.2. Amsoil.Vp.TeamManager Fuel throttle motor sports.G's . JUICE RACING LLC.COM AND ON FACEBOOK. THE JUICE RACING.
baf1 is offline   Reply With Quote
Old 09-29-2008, 11:50 AM   #67
JCarr's Avatar
Follow up to my testing. Figured out that apparently after a few laps the tires would get sticky and the car would lean so hard into the corner the body would drag and cause the spinning. I trimmed the body up and all is good. It just seems really rock stable to me but can transition really quick. I know the other guys that have been trying this body are probably on top of this sort of thing but, if you were having a problem with the rear being loose make sure the body wasn't dragging. I actually have made no set up changes to my car and the body feels great.
Gorilla Size Racing
R10 USGT, TRF416 USGT, DB10R, TA05R VTA, R40, RS4 3SS, RS4 super, Savage, Hellfire.
Youthful enthusiasm only rules until old age and common sense exert themselves
JCarr is offline   Reply With Quote
Old 09-29-2008, 12:38 PM   #68
Trader Rating: 21 (100%+)
Ran it in practice sunday on my cyclone."green" carpet,small size track.Worked very well.Pretty smooth.M
lotus1 is offline   Reply With Quote
Old 09-29-2008, 09:12 PM   #69
Regional Moderator
mrrcguy's Avatar
Trader Rating: 25 (100%+)
I too have found my fastest lap times with this body. Faster by three tenths in fact.
mrrcguy is offline   Reply With Quote
Old 10-01-2008, 12:11 PM   #70
Foxxrocket's Avatar
Can't wait to race this new body!
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 10-06-2008, 04:38 AM   #71
leaner's Avatar
Have raced with my new shell on a new TA05r straight out the box for 2 weeks at my local track and think its fantastic!
The track is tight and low grip concrete and I have struggled in the past to get a balance between understeer into corners and oversteer coming out.
With the R9R shel the front grip is amazing and I have only found a lack of rear grip under braking into the hairpin which actually helps!
leaner is offline   Reply With Quote
Old 10-06-2008, 04:41 AM   #72
RCSteve93's Avatar
Contrary to my first post in here... I saw one yesterday and it looked hooked up in 13.5 rubber on carpet.
RCSteve93 is offline   Reply With Quote
Old 10-06-2008, 02:38 PM   #73
act2007's Avatar
Trader Rating: 46 (100%+)
Here's mine for now! Actually, I'm looking for a pre-painted R9-R, if
you know somebody please send me a pm, thanks!
act2007 is offline   Reply With Quote
Old 10-06-2008, 09:02 PM   #74
STLNLST's Avatar
Changing my set up slightly and will be giving the body another shot again this weekend. I'm going to test it against the speed 6. This will be on a parking lot sprayed with VHT.
STLNLST is offline   Reply With Quote
Old 10-08-2008, 04:21 PM   #75
Scottmisfits's Avatar
I tried it again last night changing my set up very slightly. I went longer on the rear camber link. This settled it down quite a bit. I am going to try a higher roll center in the rear as well. And maybe take the rear sway bar off if the roll center thing doesn't work. The first thing I am going to try is stiffer front springs again and maybe some softer rear oil.
This was using the box stock settings for the TC5R as a starting point.
Scottmisfits is offline   Reply With Quote
NEW! PROTOform "MULSANNE LMP" 200mm PanCar Body daleepp Electric On-Road 111 10-29-2015 05:11 AM
5 brand new Protoform DNA "light weight" RBLove R/C Items: For Sale/Trade 3 05-31-2008 09:59 PM
"""NEW""" Collari .21 3 port buggy motor lc21-b3 goneRVing R/C Items: For Sale/Trade 7 12-20-2006 06:25 PM
""" XRAY FK05 """ excellent cond/super clean/stock evostyle R/C Items: For Sale/Trade 9 06-29-2006 10:04 PM
New Body from Protoform "NEMESIS" Bon Ramat Electric On-Road 45 06-30-2004 04:38 PM
