Old 09-02-2003, 12:26 PM   #1
seaball's Avatar
R/C Tech Charter Subscriber
Send a message via Yahoo to seaball
Arrow pullies, pullies and well,...
yeah. anyway, i am looking for some good true pulleys for both my diffs, and for the layshaft. the qualifications are these.
the layshaft is 4mm and Iím looking for plastic here, but not limited to, with the standard 3mm pitch.
- 17 teeth
the diff needs to use 1/8Ē balls and the same pitch as above.
- 38 teeth
does anyone know who makes these? duratrax makes 18/38, but i question the concentricity. does losi go down to 38t?? who else uses 38t? and what about 17??
any help would be appreciated. iíve got some 17 rclab pulleys, but they are eccentric and very poor.
anyone?? i'm not opposed to aluminum layshaft pullies either.
thanks in advance.
lata
*** The Gate II - Home of Mike Wise ***
seaball is offline   Reply With Quote
Old 09-02-2003, 03:53 PM   #2
Ian S's Avatar
Schumacher make a 17 tooth pully, in both plastic and alloy, not sure if it'll fit on a 4mm layshaft tho...
Edit - just measured one and its 4mm so it looks like it should fit.
Ian S is offline   Reply With Quote
Old 09-02-2003, 04:10 PM   #3
robk's Avatar
Trader Rating: 22 (100%+)
Shoulda checked those Atlas pullies before you got rid of them...37t on the diff, 16 on the shaft. Not sure about the rest of your qualifcations.
Old 09-02-2003, 10:18 PM   #4
Default Hey seaball
Why dont you just buy a car that you can go up to the counter or get online and order what you need
Joneser is offline   Reply With Quote
Old 09-03-2003, 06:45 AM   #5
Send a message via ICQ to JesseT
Isn't the smaller Mission pulley 17?
JesseT is offline   Reply With Quote
Old 09-03-2003, 06:53 AM   #6
seaball's Avatar
yup, after i thought about it...i remembered that rw makes those nice machined pullies for the schuie 17 and 20. i may have to do that, but it may require my buying two complete pulley kits.
we'll see.
hey rob,
i've already got the atlas 16's fitted on the layshaft!! rclab with a middle one way baby. i always keep it locked though. but they run perfectly true. my 16/37 is quite good, but i got the idea to omit both f/r tensioners by just increasing both pulley sizes. one tooth on each should to it.
i tried a 16/39 (kxone pulley). fits like a champ, but my internal becomes 2.44! i can't find pinions big enough to rollout very high with cut foams.
thanks for the replies. anyone else??
Yokomo yz 10 diff pullies,belts and top deck or complete car. jamesl Australia Wanted to Buy 0 03-12-2008 12:56 AM
Corally RDX diff pullies jdearhart R/C Items: Wanted to Buy 5 04-29-2007 01:15 PM
X-Ray T1R + pullies, spool, tuning kit RBLove R/C Items: For Sale/Trade 11 07-02-2003 02:06 PM
Mtx-3 With Kawahara pullies. racenut123 R/C Items: For Sale/Trade 8 05-13-2003 11:41 AM
