SMC 5700mAh 25C Single Cell Lipo >
Old 11-23-2008, 09:02 PM
  #346
Company Representative
Danny/SMC's Avatar
We decided to cut back on the capacity as it would as we were asked by some of the best 12th scale mod racers to do so as this would mean they would have to throttle drive again or use slower motors as the current speeds are out of control. There is plenty of capacity with a 4000 plus it also keeps the price lower.
Danny/SMC is offline
  #347
Originally Posted by Clegg
what happened to the 5700 mAh?
Great question!!! Those are the ones I ordered. wtfuwd?
Gotta admit tho.. $50 is a damn good price for 4kmAh
half the volts half the price et?
John St.Amant is offline
Old 11-29-2008, 09:19 AM
  #348
Trader Rating: 118 (100%+)
Does the Novak #1715 4-cell GTB work with this battery?
Chris Furman is offline
Old 11-29-2008, 09:50 AM
  #349
sportpak's Avatar
Trader Rating: 26 (100%+)
So far the GTB seems to work the best. The discussion on this battery has moved to the other thread.
sportpak is offline
Old 11-29-2008, 10:27 AM
  #350
Make sure u get the one specifically designed for spread spectrum tech., andu will need either a booster or a flight pack.
Old 02-13-2009, 11:18 PM
  #351
Trader Rating: 6 (88%+)
Originally Posted by 360rcspeedway
Also, another interesting note. I have been testing a device for novak, a voltage booster of some sort. It plugs into the battery port of your reciever and has leads that hook to your battery. It also has a switch for on/off. You basically use it like a receiver pack. It outputs roughly 5.5v for the receiver/servo.
-Donny
Can anyone direct me to this?
steve671 is offline
Old 02-14-2009, 02:25 AM
  #352
R/C Tech Elite Member
hanulec's Avatar
Trader Rating: 28 (100%+)
the novak booster is not available yet. use this thread instead:
http://www.rctech.net/forum/electric...case-pack.html
hanulec is offline
Old 05-14-2009, 03:03 AM
  #353
silverfrancis's Avatar
I was wondering if it was possible to put the voltage booster between the battery and esc. Is this even possible. I am thinking about buying the yeah racing esc and brainless brushless motor as it is cheap. However it says that it only supports 2-3 cell lipo. Is it still possible to run 1 cell lipo.
Thanks in advance
silverfrancis is offline
