Old 09-01-2008, 07:38 PM   #136
tallyrc's Avatar
found this project when looking for dc3v to dc5v.. maybe some of you smart guys can adapt it.. http://ladyada.net/make/mintyboost/index.html
WWW.STORMERHOBBIES.COM helping keep pan cars alive!
Turns out not where, but who your with that really matters... DMB
tallyrc is offline   Reply With Quote
Old 09-01-2008, 08:08 PM   #137
The only problem, possibly, with the step up IC is how much current they can deliver. Is 600 mA enough to run a Spektrum receiver and a high speed servo? Guess I'll have to break out the O-Scope and do some measuring.
Even if it has plenty of amperage capacity, you are still taking power and runtime out of your main battery. A receiver battery will always give you more runtime.
Serpent SRX8 electric
Serpent Cobra 811TE-E
Serpent S120LTR 17.5 1/12th and S100LTR Pro-10
Serpent S411 Eryx 4.0 USGT
Team Serpent America and Desoto Racing
Stealth_RT is offline   Reply With Quote
Old 09-01-2008, 08:26 PM   #138
S.Heath's Avatar
Trader Rating: 21 (100%+)
Send a message via AIM to S.Heath
I appreciate the research and the possibility of someone being able to create a voltage step-up circuit. If it can be done, I'm sure someone in the R/C community will have the know-how and ability to make it happen. At that point we will need to weigh the benefits against the drawbacks. Until that time, there is a proven alternative that is already available... the receiver pack. Only a few years ago, before the appearance of the higher capacity NiMh cells, many modified drivers routinely ran receiver packs to squeeze the runtime of their 4-cell packs to the 8 minute level.
Don't get caught up in overthinking the problem... use the KISS method... (KISS; Keep It Simple, Stupid).
S.Heath is offline   Reply With Quote
Old 09-01-2008, 08:49 PM   #139
trailranger's Avatar
Rightnow keeping it simple will be a RX pack. In the future a 5V IC will be the better choice for space, weight and less fuss.
Will taking 250mah out of 5700 battery to run the RX and servo hurt run time? Highly doubtful, since runs are only 8Min and the motors really can not pull a strong enough average load without overheating. The load would have to average 40Amps or greater to dump in 8min and only single digit windings will do that in 1:12.
Plus by time a 5V 3A IC comes out, the same lipo pack could be 7000mah.
trailranger is offline   Reply With Quote
Old 09-01-2008, 09:46 PM   #140
reenmachine's Avatar
Trader Rating: 26 (100%+)
I've seen receiver packs as light as 20g so I don't see what the fuss is about running one. The flexibility in placing it for ballast would probably be welcome.
I'm running a Tekin RS ESC in my touring car and have the Hotwire programming interface. It looks like this would be a great ESC for 12th scale BL/lipo as it has lipo cutoffs for 1S, 2S, and 3S packs. You can also choose from 5 throttle profiles (and create custom ones soon) and change drag brake, current limit, etc., all of which may be key in such a lightweight platform.
Pete Waydo
2010 Big Fat Turkey Race Mini Cooper AAA Main Champion
*** currently in stasis ***
reenmachine is offline   Reply With Quote
Old 09-02-2008, 07:18 PM   #141
Company Representative
Danny/SMC's Avatar
Finally back from Vegas. Jacks post pretty much sums it up for now. We will be sending some packs out to various people to play with in the coming weeks but we did order 300 packs as I think this will be the way to go and if the 12th scale guys don't adopt it right away we have had allot of interest from the oval guys.
One of the problems is the speed controls have built cutoff in the 3.2v range and maybe different from manufacturer to manufacturer. This seems to create a problem with the low turn motors. We will test 13.5 and up to see if the same issue will occur.
I spoke to the Novak guys at the race and making a converter is possible and they could possibly include it in future speed controls.
As this is something new it may require a bit different electronic setup but with a bit of time I'm sure it will be figured out. The interest so far is very positive and I think this will be the way to go.
As we have more test results we will let you guys know.
Danny/SMC is offline   Reply With Quote
Old 09-02-2008, 07:52 PM   #142
KHoff7's Avatar
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 09-02-2008, 08:50 PM   #143
See, that's what I'm talkin' about. An ESC that internally steps up the rx voltage -- reverse BEC if you will. If the 1S lipo technology shows promise, the industry will respond and accommodate, jst like they did with lipo technology in the first place.
FWIW, my Tekin RS ESC lipo cutoff can be set as low as 3.0V.
Pete Waydo
Old 09-03-2008, 07:39 AM   #144
I can't wait to be able to order a pack to try. Even if it's only in practice.
For some reason, the 12th guys seem to be a little slow to change so it might take a little bit to get people to make the switch. The same thing happened with brushless at first.
Fred_B is offline   Reply With Quote
Old 09-05-2008, 07:16 AM   #145
slakr's Avatar
Trader Rating: 33 (100%+)
BUMP
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 09-05-2008, 05:18 PM   #146
Bigshades's Avatar
Trader Rating: 22 (96%+)
I did a little update on my project...
I re-wired everything, and it is a little neater than i originally had it. It still looks like a mess, but it works. If you look closely at the attached picture, you can see 2 AAA cells connected in series with the Lipo, powering the BEC.
Enjoy!
Bigshades is offline   Reply With Quote
Old 09-05-2008, 06:16 PM   #147
RCSteve93's Avatar
I'll test... the durability of the case. I can't wait for it to come out.
rm -rf /windows
RCSteve93 is offline   Reply With Quote
Old 09-06-2008, 06:57 PM   #148
I'm ready to test this booger out. Keep the updates coming.
69mkitmine is offline   Reply With Quote
Old 09-10-2008, 12:40 PM   #149
Ty
Ty's Avatar
Trader Rating: 29 (100%+)
Danny,
What will the single cell pack weigh (in grams) compared to a 4 cell pack of the current EnerG cells?
Thanks,
Ty
Ty is offline   Reply With Quote
Old 09-10-2008, 04:48 PM   #150
Danny/SMC's Avatar
I'm not sure of the exact weight but it's close to 2 sub-c cells.
After fitting the pack in different cars and talking to some of the racers and manufacurers we will most likely go with a 2 cell pack which will make the pack thinner. The capacity will be in the 3800-4000 range which is more than enough for the stock classes and may require some milder motors for the mod classes which will be a good thing as the cars are to fast.
CE SINGLE CELL HOLDER rogtsaamokin R/C Items: For Sale/Trade 3 09-11-2006 10:03 PM
Single Cell evaluation andrewdoherty Electric On-Road 2 09-09-2006 07:58 PM
CE Single cell holder II Fast R/C Items: For Sale/Trade 10 03-31-2006 04:31 PM
NiMah batteries//single cell as well dasgruvn Rookie Zone 6 09-13-2003 09:17 PM
Single cell label..??? Speed Demon Electric On-Road 4 02-28-2003 08:11 AM
