Danny at SMC please help
Danny I'm wanting to run 2 of the SMC 5000 packs in my electric 1/8 scale. I'm using the Novak Maxx system and needing to know how to run the two packs together. Please let me know as I would like to run this weekend.
Dustin Malicoat
Team GFRP
Dustin Malicoat
Team GFRP
The Evicerator
Hi Dustin,
The HV ESC comes with two battery connectors pre-installed from the factory... simply connect one battery to each connector and you should be good to go.
The Evicerator
As it stands it connects the two separate battery packs in series... so you get 4S voltage.... no special wiring needed for 2 2S packs
If you want to run a single 4S pack the ESC needs to be rewired...and the instructions reflect the modifications needed
This has been discussed at length (mainly by me) in the off-road section in the thread on Novak 1/8th conversions.
I run two SMC 5000 packs in my Losi 8ight, but I am using a Mamba max and have them connected in series so they get drawn down at the same rate. I found out about the different drawdown with the Novak from my first conversion with a Novak HV 6.5.
