Old 09-03-2003, 12:19 PM   #31
berger's Avatar
R/C Tech Charter Subscriber
For 2. i use an old pack of 4 cells and run those for about 4 minutes.
berger is offline   Reply With Quote
Old 09-03-2003, 07:26 PM   #32
Speed Demon's Avatar
Default ATLAS MOTOR
Hi.. anybody tried the Team Atlas stock motor??
I am talking about the 23T Solid Purple....
Is it good?? Is it fast??
CUSTOM CRAWLER & ROCK STACKER
Speed Demon is offline   Reply With Quote
Old 09-03-2003, 09:39 PM   #33
Tom
Tom's Avatar
How long should you break in brushes for the following situations?
i use the first heat!
That seems pretty dam high, I gear my monsters about 7.2 and they seem to like it.
have fun doing that with Assassin! You will have to mill a lot of the motor plate, and that would make the rear end very weak. Stick with 1-2mm of the motor plate and yo can get down to around 6.8 and you'll have no probs or just run 2 belts. I have heard of it getting to 8.0, but wouldn't try it.
Tom is offline   Reply With Quote
Old 09-03-2003, 10:17 PM   #34
fatdoggy's Avatar
Sydewynder - Ooops, I ment Rpm...
fatdoggy is offline   Reply With Quote
Old 09-03-2003, 10:44 PM   #35
I have heard that having a bit more spring tension on the Pos sde of youre motor will give you a little more torgue...anyone know or heard of this?
MarlboroRally is offline   Reply With Quote
Old 09-04-2003, 12:55 AM   #36
Roger's Avatar
Yeah, I think thats called " polorized " spings and brushes from Trinity. Or is it the other way around for the positice or negative side ?
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 09-04-2003, 01:04 AM   #37
It's the positive side. Red on +, Green on - for Trinity.
Sydewynder is offline   Reply With Quote
Old 09-04-2003, 01:48 PM   #38
popsracer's Avatar
Default polorized springs
MarlboroRally;
The lighter spring goes on the Negative side and this is done for more RPM. Most of the "Tuned" Stock Motors come with a + Red, - Green setup.
For more torque (like in a TC) a Red/Red spring combo works best in "Epic" Motors.
popsracer is offline   Reply With Quote
Old 09-07-2003, 01:03 AM   #39
fatdoggy's Avatar
Default Re: heat?
Originally posted by audiaudi
Have you guys check the temprature of the motor after run?
Stock motor can reach arround 74~76 degree celcius, but it is normal..
Yokomo guys said it is still ok until it reach 86 degree celcius, if over 86 degrees, it is overgearing...
I check the motor after each run with an infrared temp check, shaft drive car usually have a motor surface temp arround 74~76 degrees, and belt drive car usually 69~71 degrees.
Any input?? (23T stock... see if any different with the 27T)
I checked my temp today after a full run, my Mvp was at 183F = 83.88C.
Old 09-15-2003, 09:49 AM   #40
Scrad's Avatar
Trader Rating: 15 (100%+)
I have a quick question. I checked my motor on my GFX, ran it at 3 Volts and got about 10 Amps. I then rebuilt it and cut the comm, checked it again and only got 9 Amps. I didn't replace the brushed, just cleaned them with a comm stick.
Is it normal to get less Amps after cutting the comm? I just got a comm lathe and wanted to make sure I wasn't doing something wrong.
Scrad is offline   Reply With Quote
Old 09-15-2003, 10:34 AM   #41
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
When you cut the com you changed the diameter of the com. Give the brushes time to reseat themselves and the amp draw should come back.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 09-15-2003, 11:10 AM   #42
Scrad's Avatar
Thanks, that's what I wanted to know.
The BRP Thread, 1/18 stock and mod. national champs sg1 Micro and Mini Scales 176 12-24-2009 02:15 PM
Stock Motor Lot w/Trinity case and Much More Motor Mate Racer4Life R/C Items: For Sale/Trade 2 08-19-2007 09:04 PM
Method to run-in stock to higher turm motor? or a stock tune to a higher turns? micro80 Malaysian R/C Racers 0 06-16-2007 12:40 PM
Stock motor blowout!!! NEW Hurricane bushing reamer / 767 brushes / motor case LOW$ evostyle R/C Items: For Sale/Trade 0 11-27-2006 11:22 PM
Stock motor sale !!!!CO27,P2k Pro, Monsters stock Marcos.J R/C Items: For Sale/Trade 36 06-27-2006 06:26 AM
