Balancing Lipos on the CORE UDC-20 Charger
so i have the UDC-20 charger... and bought this cable at www.allerc.com
http://www.allerc.com/product_info.p...oducts_id=3702 http://www.allerc.com/images/HP-LB10-CAR2.jpg http://www.redrc.net/wp-content/uplo...erccharger.jpg SURE ENOUGH... when i received it... its the wrong cable. :lol: :lol: the end that plugs into the charger is incorrect. where can i buy a balancing cable that has the correct connector that fits a UDC-20 and a Team Orion lipo pack? Thanks! |
Go to the Nexus racing web site. They have o good article on how you can make your own harness. It's not difficult.
Originally Posted by Granpa
(Post 4729272)
Originally Posted by Hebiki
(Post 4729275)
thanks Granpa...saw this article already.... but just too busy to have to "create" my own cable.
Originally Posted by picco007
(Post 4729340)
With that charger there are some balancing leads that came with it. You need to hook up the end that goes to the 2S port. You will need to cut the too outer wires and attach them to the positive and negative output charge leads then the middle lead from the balancing port you will need to extend that lead maybe using an servo extension wires.
That's what I had to do for a buddy of mines UDC charger and orion lipo......Hope that's what your looking for.... maybe i should rephrase my question to... where can i buy a balancing cable that has the correct connector that fits a UDC-20 and a Team Orion lipo pack? |
Go to www.precisionrc.com and search for wkz2002 - exactly what you want
What you need to do is buy the Hyperion charger that matches the other end of that cable. :-) The AC/DC one is sweet.
Do you not have any plug that goes in that charger? SURELY it came some sort of harness. Its VERY simple to take your Xacto and push the little tabs down on the plug and insert the wires in to your plug. Or, if youre SUPER lazy then just lop the wires off and get you some butt connectors and do it that way. I would hardly call any of these MacGyver tactics. That one you got is for a Hyperion LBA-10. If you cant make your own harness then I dont even know how you soldered bullets on to wires for your speedo?
Originally Posted by jla8874
(Post 4729660)
Do you not have any plug that goes in that charger? SURELY it came some sort of harness. Its VERY simple to take your Exacto and push the little tabs down on the plug and insert the wires in to your plug. Or, if your SUPER lazy then just lop the wires off and get you some butt connectors and do it that way. I would hardly call any of these MacGyver tactics. That one you got is for a Hyperion LBA-10. If you cant make your own harness then I dont even know how you soldered bullets on to wires for your speedo?
Originally Posted by syndr0me
(Post 4729578)
