Old 08-11-2008, 08:48 AM   #1
Unhappy Grinding Sound when accelerating...
Hey all,
I am currently on TT01 chassis and Tamiya Super stock motor, when I accelerate, there is some grinding sound coming from the rear wheels, but upon stripping them and re-greasing them doesn't seems to help much, anyone knows what's wrong? I thought it was like some gears within has worned out causing the sounds... but I had this for like at the most 2 months?any idea anyone?
Appreciate any help here...
SebTurbo is offline   Reply With Quote
Old 08-11-2008, 10:49 AM   #2
yokemad's Avatar
relube the motor bushings
yokemad is offline   Reply With Quote
Old 08-11-2008, 11:03 AM   #3
GyroBoost's Avatar
i have the same problem. but i don get wad relubing the bush is
GyroBoost is offline   Reply With Quote
Old 08-11-2008, 11:30 AM   #4
Trader Rating: 38 (100%+)
Are you using the stock spur gear? If so are you using the stock pinion as well? It could be gear mesh. Tamiya uses a metric sized spur/pinion. Other things to check are loose cvd pins (if you are running cvd), bent dog bones, bad gear mesh. Take the dog bones out and see if it still makes the noise. Could be lots of things.
or8ital is offline   Reply With Quote
Old 08-11-2008, 11:55 AM   #5
GyroBoost's Avatar
does do any harm to the chassis if we leave it be?
Old 08-11-2008, 12:16 PM   #6
Dan the Man's Avatar
Trader Rating: 40 (100%+)
Not the chassis
Although you could be grinding away your spur gear, or rear gearbox, or dogbones, or it's the motor.
Hell, have you left a screw floating around in the rear diff cover? I saw that happen on a TT-01 once...
|-•-|Hot Bodies Pro 5|-●-|The "F109X"|-•-|
If you don't have clean bearings, good transmission and a perfect car, trust me when I say this...someone else does.
Dan the Man is offline   Reply With Quote
Old 08-11-2008, 12:18 PM   #7
hairy's Avatar
did you use the correct screws mounting the motor to the bulkhead?
MERLIN RACING
"He once ran a marathon because it was on his way"
Logic is a lost art!
You are defined in life by how you respond to defeat!
hairy is offline   Reply With Quote
Old 08-11-2008, 12:20 PM   #8
GyroBoost's Avatar
this question might be a diff subject but wads the difference between taping the tires to proper drift tires
Old 08-11-2008, 12:26 PM   #9
GyroBoost's Avatar
the grinding only happens when i accelerate
it'll stop when it starts maintaining the speed.
Old 08-11-2008, 12:43 PM   #10
yokemad's Avatar
why don't you go an drop an oil to both side of the motor bushings and check if that works or not!
same think happened to me before if that is the problem you have to replace bushes with the new ones...
Old 08-11-2008, 12:45 PM   #11
GyroBoost's Avatar
i don think its the bushing. i tried my other motor TMAX ST 23T too it had the same problem and its quite new.
Old 08-11-2008, 04:40 PM   #12
yokemad's Avatar
very interesting
Old 08-11-2008, 04:59 PM   #13
Bigshades's Avatar
Trader Rating: 22 (96%+)
Try inspecting the spur/pinion gears. Do they look even, and new? or are they worn out, and "Eaten away"?
Also inspect the differential gears. Do they look alright? or are they dirty.
Dust/Dirt can wear out the plastic gears in a jiffy! so inspect the gears. I noticed that bad gears would grind on acceleration, and be silent off throttle.
Cheers!
Bigshades is offline   Reply With Quote
Old 08-11-2008, 05:53 PM   #14
Are you still using the plastic drive shaft? Try the aluminum drive shaft. If you are still using the plastic drive shaft with any other motor than the silver can, this could be where your noise is coming from. With the plastic drive shaft, it will tend to "bow" out a slap your chassis or motor when reaching certain speeds or rpm. With the silver can motor, it usually does not exceed the rpm's that the plastic drive shaft can handle.
John Hallman is offline   Reply With Quote
Old 08-11-2008, 07:11 PM   #15
Thanks for all your replies! Appreciate it! Yes, I am on aluminium shaft, this TT01 of mine is barely 2 months old from new, but yes, I did meddle with the spur and pinion, and I meant play around with the gearing and thats about it. Car still move fast but its just that irritating sound that makes me feel like something is going to break sooner or later, so I am getting some info from people have this problem before so I could do some pre-emptive checks or any preventive measures before something breaks and damage other parts as well!
Any one can point out where the bush is? And I don't mean George Bush...hehe. I am new to this RC thingy. or mesh or whatever you guys have pointed out.
Thanks, you guys are great!
Brand New Sound Blaster Audigy 2 ZS 7.1 surround sound semore Other Items: For Sale/Trade or Wanted to Buy 7 04-14-2006 11:32 AM
Fastest Accelerating Street Car in the World! Liam_Davies Chat Lounge 17 12-24-2005 02:18 AM
Accelerating straight Jez81 Rookie Zone 9 11-08-2005 09:32 PM
Car boggs down while accelerating. 5iN Rookie Zone 6 08-12-2005 10:20 PM
new here, but my 4-tec is grinding...? t3guy Electric On-Road 12 05-24-2004 01:01 AM
