LRP Shere TC-Spec Brushed Motor Wiring Question?
I just bought the LRP Shere TC-Spec speedo for my X-Ray 007 EU. I run in the 27T Stock and 19T Spec classes at the local raceway. I know that I should have bought just a LRP Quantum speedo since I real only run brushed motors. But I like playing around with my 4.5 brushless when it is open track time.
http://aedownloads.com/downloads/ite...s/lrp80750.jpg My question is = in the manual it says I still need to run 3 wires to a brushed motor. This presents a problem since I need to be able to switch motors quickly between classes. With my old speedo I just had a deans plug on the motor, but now I need to run 3 wires to the motor. So I need to know what others have done to get around this. Or if I could just wire the 2 neg wires to the same prong on the deans plug? Thanks for your help. http://photos-c.ak.facebook.com/phot...37946_8467.jpg |
The 2 to one deans idea sounds fine. As long as its wired like the diagram it will work, just put the connector in between. The good thing with the lrp is that you don't have to do anything to the speedo to switch from brushed to brushless.
The auto switching is nice.
Originally Posted by Heathen
(Post 4728122)
I have just always soldered the two wires to the negaive post and one to the positive and had no problems at all! It works great!!!
Originally Posted by katfish317
(Post 4728951)
If you are going to have wire on the motor then go to your LHS and go to the airplane side and get some of the high end bullet plugs and put them on.
what is a good starting setting for the punch and brake adjustments?
Originally Posted by ckoetsch
(Post 4733694)
It really depepnds on what type of motor you use with it. I have run both brushed and brushless, with a brushed I used punch 6 and brake off, with brushless(17.5) I use punch two or three, and brake set at five
Since this topic concerns the Sphere I'll ask here. Does the ESC have a built in LiPo cutoff or will I need to buy one?
your manual should be able to tell you.
Originally Posted by Hide
(Post 4736814)
