Lipo confusion
Old 08-12-2008, 04:39 AM
  #91
Number09's Avatar
Hi,
I was just wondering if anyone has tested their charger to see how well it balances the packs? The reason I ask is I am yet to balance mine, so I checked with a multi-meter and found one pack was one millivolt out and the other was two millivolts out(.002volts). So obviously no need to balance, but at what point should I? I assume that chargers don't balance down to one millivolt but has anyone actually checked? I have searched but found nothing. I don't want to test it on my nicely balanced packs to find my charger balances them worse than what they are now.
Ben
Number09 is offline
Old 08-12-2008, 08:20 AM
  #92
Company Representative
Danny/SMC's Avatar
Actually our 5000 has a bit better performance than our 4000. Here is the discharge graph of single cell used in our 5000 pack. The cell is a 2500 as our 5000 pack uses two 2500 cells in parallel and then those 2 cells are put in series (2S2P).
Danny/SMC is offline
Old 08-12-2008, 08:41 AM
  #93
Trader Rating: 21 (100%+)
Default Question
Danny,
I'm a club racer and will never see a big race. What pack would you recommend that will fit into a Type R with no modifications?
You were talking about a pack to replace a 4 cell in 12th scale, Can you explain more about this and when do you expect this to happen? Will it be the same size as a 4 cell is now?
lidebt2 is offline
Old 08-12-2008, 09:57 AM
  #94
padailey's Avatar
Ok since this thread has gotten a little contested at times let me preface by saying this is a question. No motives one way or another.
Danny you have stated the importance of capacity in the performance of packs. Why did you use 2500 cells in a 2S2P configuration rather than 5000 cells in a 2S1P configuration for your 5000 mah packs? Is there some benefit one way or another?
padailey is offline
Old 08-12-2008, 10:31 AM
  #95
Danny/SMC's Avatar
Originally Posted by lidebt2 View Post
Danny,
You will be fine with our 4000. I believe it fits with no mods in the Type R but you may want to ask rcracingkid to make sure as he has experience with our packs in a Type R.
The single cell Lipo will be in a hardcase that is very close to the same size as a 4 cell side by side pack. We will have 4 sample packs at the IIC and we hope to have some demo runs on the track.
Old 08-12-2008, 10:35 AM
  #96
Danny/SMC's Avatar
I think it has to do with our supplier not having any high C rate cells ready in the 5000mAh range and possibly the size of a single 5000 cell could not fit the ROAR maximum size. As far as I know this doesn't really help our hurt the pack by having 2 cells in parallel.
Old 08-12-2008, 10:46 AM
  #97
Default 4 cell packs
I have Mike's old packs since he can't use them in Vegas.
Any preview for the general public now? Would like to see if they would work in my oval car.
lidebt2 is offline
Old 08-12-2008, 05:00 PM
  #98
ckoetsch's Avatar
Trader Rating: 18 (100%+)
are there any companys out there that make a weight to place under a lipo pack to help comensate for the weight difference?
ckoetsch is offline
Old 08-12-2008, 05:06 PM
  #99
jdearhart's Avatar
Trader Rating: 15 (100%+)
Yep. Try here.
jdearhart is online now
Old 08-12-2008, 05:38 PM
  #100
How does the 5000 Mah SMC pack fit into an associated B4 or a XXX-CR???
bshack is offline
Old 08-12-2008, 08:58 PM
  #101
adamge's Avatar
Originally Posted by Number09 View Post
Hi,
Ben
Ben, I don't have experience balancing 2s packs. But, I do with 5s packs. With a 5s pack and a respected balancer (Thunder Power), I was seeing anywhere from 12 to 18 mV gap between lowest and highest cell in the pack. With a 2s pack, I imagine you can expect the balancer to get it within 10 mV. I think you're wasting your time balancing a pack that's within 10 mV - unless your charger monitors cell voltages for additional safety.
-Adam
adamge is offline
Old 08-12-2008, 09:35 PM
  #102
Joel Lagace's Avatar
LIKE A GLOVE! You do have to dremel a slot on the chassis battery spine but other then that it slides in, i have not removed my pack since the start of the summer, And with 13.5 i have done back to back bump up B to A main runs without recharging.
Joel Lagace is offline
Old 08-13-2008, 05:25 PM
  #103
Any word on making a saddle pack that will fit in a B44.
Dave Walton is offline
Old 08-13-2008, 05:28 PM
  #104
Danny/SMC's Avatar
At the end of this month were shipping out our new hardcase 4900/25C saddle pack. It will fit in all popular 4wd cars.
Old 08-14-2008, 08:59 PM
  #105
Taylorm's Avatar
Our newest goal is to try and figure out how to get a single cell Lipo to work for 12th scale road course and this could also be adapted to oval if a slower class is required.
..i'm VERY interested in this............one cell Lipo..wouldn't even need a balancer...........will 540 size motors be ran with one cell?.....or smaller motors like in the 1/18th cars?............one cell with 18th size motors would probably= exceptional tire wear as the cars would be VERY light.......
Taylorm is offline
