Old 08-31-2003, 04:29 PM   #1
ajg
Registered User
ajg's Avatar
Default Custom chassis
Can I make a chassis for my tc3 out of these carbon fiber sheets?
http://www.macqc.com/raceplates/newProducts.htm
I would use a dremel to cut out two pieces, the shape of the chassis and glue them together to make an almost 3mm chassis.
Would I be able to use the flex pieces for it?
ajg is offline   Reply With Quote
Old 08-31-2003, 05:26 PM   #2
Send a message via AIM to zachzachz
I dont see why not but you'd have to make it exactly the same as the tc3 chassis, screw holes in the exact spot and all. It doesn't sound like it would be easy.
zachzachz is offline   Reply With Quote
Old 08-31-2003, 05:33 PM   #3
Jason's Avatar
Cutting it out by hand wouldn't look very good. You won't be able to make straight lines. Plus you don't want to breathe all those graphite particles.
Jason
Jason is offline   Reply With Quote
Old 08-31-2003, 06:22 PM   #4
yeah graphite and skin dont mix, it will itch like hell. I know from expireince, I broke one of my hockey sticks and was trying to get the rest of the blade out and I touched the graphite a lot and it gave me an uncomfortable itch the rest of the day.
Old 09-01-2003, 12:38 AM   #5
ajg
Registered User
ajg's Avatar
For cutting it I could put my old chassis on the carbon fiber and cut out the shape. And for the holes I would have my old chassis still tape or sitting on the new one so I could just drill the hole through the old ones into the new chassis (not ruening the old holes but making the new ones the exact same size). That seems like it would work well, don't you guys think so?
Also where can I get a 12x12 inch piece of carbon fiber 1.5 to 3mm thick (.0625 to .125 inches thick)?
And where can I get a dremel or demel type tool for cheap?
Thanks!
Old 09-01-2003, 01:27 AM   #6
NMRCDude's Avatar
Send a message via AIM to NMRCDude
Well, it depends on what your going to cut it with. You cant just break out the hack saw and start from there.
NMRCDude is offline   Reply With Quote
Old 09-01-2003, 10:12 AM   #7
ajg
Registered User
ajg's Avatar
I would use a dremel.
Old 09-01-2003, 04:25 PM   #8
Claydoh's Avatar
Send a message via AIM to Claydoh
Make sure you wear a dust mask. Huffing that dust will take years off your life.
Claydoh is offline   Reply With Quote
Old 09-01-2003, 04:55 PM   #9
Trader Rating: 56 (100%+)
Default Carbon
Cutting carbon is not for the weak of pocket. I purchased a 12x12 sheet before, traced out a design and started to go at it with my dremel...quickly ate through multiple cutting wheels, got all itchy and sneezed black dust from the carbon and to boot, my chassis was a half ass looking pos. After alot of finisghing and grinding, it looked half decent. FOr the time and money I spent on making it, I would have been better off buying a pre made setup...
Now, a year later and a year smarter, I have someone else cut the stuff for me....it's not the easiest stuff to work with.
dynamic_e is offline   Reply With Quote
Old 09-01-2003, 05:52 PM   #10
Another quite large problem I forsee...... The motor mount, nobody sells it seperate and it would cost almost as much as a prefabed C/F chassis set-up to have a one-off machined......
The flex stuff would be very, very inappropriate to work with also, it is made to bend around curves quite easily, and that isn't the best formula for an RC chassis!!
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 09-01-2003, 05:54 PM   #11
you would be better off spending the money for a Scroll saw used for woodworking...it will be 100 times more accurate and easier to use...and not nearly as much dust...they also have diff blades for finer or coarse cuts..just My opinion.
MarlboroRally is offline   Reply With Quote
Old 09-01-2003, 05:58 PM   #12
Jason's Avatar
Just save your time and effort and buy a chassis.
http://www.rctech.net/forum/attachme...&postid=489538
This is a really cool looking conversion for the TC3. Not sure of the price or where to get it at.
Jason
Old 09-02-2003, 10:13 PM   #13
BuddhaTech's Avatar
ajg,
I wouldn't use that CF for a for even a skid plate! It's mearly a cosmetic piece and, not structural quality. It will not be cost-effective to manufacture your own chassis. It would be a great learning experience though. You should get some good quality CF and start with shock towers or battery braces...small stuff.
I can't stress the safety issues enough when dealling with CF. Here is a link to an MSDS for carbon fiber. Keep in mind that this is for only the carbon...not the resins and other chemicals used to bond the layers together. This link from the OHSA gives some info on the resins used in the layup of CF. The rest of the also provides some great info on the manufacture of CF and other advanced composites.
Hope this helps!
Mike Evans
____________________________________
Buddha Tech Race Services ~ Build-Prep-Tune
buddhatechraceservices @ gmail . com
BuddhaTech is offline   Reply With Quote
Old 09-03-2003, 03:35 PM   #14
ajg
Registered User
ajg's Avatar
Old 09-04-2003, 04:16 PM   #15
speedxl's Avatar
R/C Tech Charter Subscriber
save time and mony dont try to reinvent the wheel there are plenty of choices out there unless you have enough money to produce a car and do the r&d to make it competitive and when races to sell a thousand of them. save the trouble and buy a kit itll be cheaper in the long run
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Custom One of a Kind Chassis for RDX J.Gonzalez R/C Items: For Sale/Trade 9 10-18-2005 04:06 PM
custom cut aluminum chassis romster R/C Items: Wanted to Buy 0 06-20-2005 09:28 PM
Custom BMI chassis kit for TC-3 Joe B R/C Items: For Sale/Trade 10 02-23-2005 01:02 AM
FS:Custom TC3 FT chassis. TexRacer R/C Items: For Sale/Trade 2 01-27-2005 09:27 AM
Custom milled xxx-s chassis Altrodesigns R/C Items: For Sale/Trade 41 05-25-2004 07:48 PM
