Old 08-08-2008, 12:35 PM   #16
CCH1978's Avatar
Trader Rating: 27 (100%+)
Originally Posted by Three View Post
CCH1978:
Greetings and welcome to the world of "TCS race legal Minis". Most of the faster Minis in Memphis use either a Sid prepared motor or a "Doc" prepared silver can motor. If you like to try one, see me at the next MSRA electric race at Hobbytown (I'm the one with the red #3 Mini). I'll let you try a "Doc" prepared Red Dot motor.
From my dyno I show an increase of about 3-4,000 rpm with a prepared zapped motor. I have been using the same motor for about 4 months now without a decrease in performance.
And this is not an illegal mod as the motor is not taken apart.
PM me if you need more info.
OH NOW I KNOW WHO YOU ARE THE GUY WITH THE FAST RED MINI....WELL I WAS TRYING TO BE SNEAKY AND GET SOMETHING FASTER WITHOUT EVERYONE KNOWING, BUT I GUESS THE SECRETS OUT....
MINI REVO Mamba Max Pro NEU POWERED
THE BEATINGS WILL CONTINUE UNTIL THE MORALE IMPROVES
BEAST MODE (ON) OFF
CCH1978 is offline   Reply With Quote
Old 08-08-2008, 12:36 PM   #17
nitro psyco's Avatar
Trader Rating: 30 (94%+)
Thumbs up
what is the life of a zapped motor ? ive seen the speeds they produce but is it cost effective to run zapped motors
TEAM COPPERHEAD R/C RACING-MSRA-RACING.COM
TA05 T/C LRP SPHERE HACKER 17.5&13.5
TA05 VINTAGE NOVAK HAVOC 21.5
SLASH BOX STOCK-
NITRO TC3 ROSSI .12
nitro psyco is offline   Reply With Quote
Old 08-08-2008, 02:22 PM   #18
Three's Avatar
Busted !!!!!!
Electric good..........
Three is offline   Reply With Quote
Old 08-08-2008, 02:32 PM   #19
Low_E's Avatar
Send a message via MSN to Low_E
Originally Posted by rccardr View Post
Best thing to do with a tuned motor in a Mini is to run a Novak 5 volt fan right off of the battery at 7.2 volts. It pushes a lot of air, lasts a season or two, and we just Shoo Goo 'em to the chassis right above the motor.
I'm from Europe and I have never seen any product called ShooGoo over here. I guess it is a kind of adhesive? Could someone explain me the properties of this kind of (glue?)
thx.
thou shall think twice or trice before hitting thee SEND-button
Low_E is offline   Reply With Quote
Old 08-08-2008, 02:47 PM   #20
wingracer's Avatar
Trader Rating: 24 (100%+)
It's just a clear silicone adhesive. It's called shoegoo or shoogoo because baseball pitchers would coat the toe of their right shoe (for right handers, left shoe for lefties) with it. They drag their toe on the follow through and wear out the toes. It makes a wonderful flexible adhesive for various parts.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 08-08-2008, 05:08 PM   #21
thx.
It's a silicone adhesive. Any silicone adhesive can be used to attach the fans. However, if you are into neat looking brackets, 3Racing makes a good one that's simple to install. I've used both methods. If you are going to use the silicone adhesive method, suggest you use the 25 mm fan.
Granpa is offline   Reply With Quote
Pros/Cons on AE 18R Huffpie Micro and Mini Scales 5 12-07-2008 07:11 PM
pros and cons MMS2 Rookie Zone 13 11-11-2007 04:30 AM
pros and cons _nick_ Electric Off-Road 6 02-28-2006 08:03 AM
pros and cons of XXX-S & TC3 jiggamacdaddy Electric On-Road 15 04-30-2003 10:09 AM
pros and cons on the v-one rr fuse01 Singapore R/C Racers 16 04-05-2002 01:39 AM
