Old 08-06-2008, 10:36 AM   #16
Catalyst's Avatar
Since my driving has improved I've made it 3 consecutive race days without breaks but there have been some common parts that are probably similar to other TCs...
Most common for me after a run in with the boards:
1. Screws that hold arm mounts bend
2. Front bone blades
3. Castor blocks
4. Wheel bearings
5. Arms
I'm running the hard components (rear hubs, blocks and knuckles) on my asphault setup now (high bite tracks) and the P-Dub front bumper and now I'm just doing regular maintenance on diffs and shocks.
Catalyst is offline   Reply With Quote
Old 08-06-2008, 12:19 PM   #17
Foxxrocket's Avatar
body posts...
Foxxrocket is offline   Reply With Quote
Old 08-06-2008, 12:21 PM   #18
AssocRacer's Avatar
Send a message via AIM to AssocRacer Send a message via Yahoo to AssocRacer
Originally Posted by Foxxrocket View Post
body posts...
how much time do spend on your lid???
Lots O' Planes
AssocRacer is offline   Reply With Quote
Old 08-06-2008, 01:10 PM   #19
Front bone blades (wear and tear); rear uprights due to hitting the pipes.
Pete Thomas is offline   Reply With Quote
Old 08-06-2008, 03:00 PM   #20
J_P
J_P's Avatar
I don't have 5. Wait, try this.
1 Blades
2 Blades
3 Blades
4 Caster Blocks
5 Wheel Bearings
The whole week at the ROAR Nats. The only thing I broke was a steering
knuckle. Only a few arms since I have had the car (about a year?)
JConcepts * Associated * Reedy
J_P is offline   Reply With Quote
Old 08-06-2008, 03:02 PM   #21
Suspended
body posts...
or running it under your mom's Honda parked in the driveway
move over is offline   Reply With Quote
Old 08-06-2008, 03:18 PM   #22
Send a message via Skype™ to revolution31
1) Caster blocks (I finally replaced mine with TC4 ones and havent broken one since)
2) Steering blocks
3) Pulling ball-studs out of the rear-up-rights
Other than those, I have yet to replace any other parts for being "broken"
I have been driving a TC5 since they came out and have two that race weekly.
Here is the parts I have replaced for wear-and-tear in the order of "how often"
1.) Diff balls/rings
2.) Diff out-drives
3.) Ball-Cups
4.) A-Arms
5.) Chassis (asphalt one only)
revolution31 is offline   Reply With Quote
Old 08-06-2008, 09:12 PM   #23
rosko's Avatar
any thing on the car can break but i think the steering knuckles break more than anything else get plenty. the diffs if built right, broken in properly i feel are some of the best on the market easy to adjust per instruction manual. get the aluminun roll center holders and the screws they bend and strip and rear hubs
rosko is offline   Reply With Quote
Old 08-06-2008, 09:14 PM   #24
rosko's Avatar
Ill bend and strip your rear hubs. he he.
Old 08-06-2008, 09:22 PM   #25
Rommel's Avatar
Has anyone seen someone who makes aluminum steering blocks? Diggity makes excellent caster blocks why not make some steering blocks
Rommel is offline   Reply With Quote
Old 08-07-2008, 03:41 PM   #26
robk's Avatar
Trader Rating: 22 (100%+)
The #1 most replaced part should be a new Kydex front bumper. That will solve 95% of the breakage problems, and is a must for carpet, especially foam racing.
Also, for Rommel
http://www.integy.com/cgi-bin/webc.c...=5722&p_catid=
More stuff
http://www.integy.com/cgi-bin/webc.c...ml?p_catid=136
Old 08-07-2008, 06:22 PM   #27
Trader Rating: 16 (94%+)
When I had my TC5, this was what I commonly had to replace.
1. Wheel Bearings
2. C-Hubs
3. Rear Hubs
4. Steering Blocks
5. Plastic Diff Outdrives
kn7671 is offline   Reply With Quote
Old 08-07-2008, 09:29 PM   #28
Rommel's Avatar
Also, for Rommel
More stuff
Have you or someone you know used these? Not sure of Integy quality from reading some forums. They look nice, wonder how they compare to the Diggity caster blocks in quality?
Old 08-07-2008, 09:31 PM   #29
Rommel's Avatar
Thx for the info Robk
Old 08-08-2008, 01:58 AM   #30
S_fender's Avatar
Hello,
I've mine since the beginning of the year, i run 6.5 + 5 cells :
i've the alum diff.
I've replaced :
Bearings because i don't like the original,
Diffs balls (Acer nitride balls) => a must have.
next will be the CVD's + blades.
S_fender is offline   Reply With Quote
How many Gallons do you have on your current race rig and what have you replaced? Furadi Nitro Off-Road 17 07-29-2008 03:21 PM
AMB20 AMBrc transponder batteries replaced $28USD each bigfix Electric Off-Road 0 04-11-2007 01:54 AM
2and fly wheel now has to be replaced classic xl Monster Trucks 13 06-25-2005 08:31 PM
will the m8 finally be replaced? cooliomojo-CEBU Electric On-Road 31 03-11-2005 11:24 PM
