Tc5 setup, tires?, Brushless Motor?
Hi,
I am trying to keep myself from running to my LHS to get the tc5.
I need some questions answered first.
What are the best foam tires for asphalt?
Do rubber tires work for practice? If so whats the best type/brand.
I will be running at my local track. SV raceway Sun Valley, CA.
I only want to use a brushless system. Whats the best?
I think I like the Mamba max. Which motor should I get? 5700? 6600? or 7700?
I already have 2 11.1 volt 5000 Mah and a 7.4 volt 6000 Mah Maxamps lipo.
Will these work? Do I need any mods to the chassis for these batteries.
I probably will have a million more questions.
Thanks in advance for any help!
to ask YOU a question, if your running foams for asphalt, why would you practice on rubbers?
im my TC5 i have a LRP sphere comp and a novak sensored 13.5
i dont think you need to mod the chassis at all i think?
for rubber tire compounds, try the jaco green premounts
i have no idea what to use for foam
What batttery you using?
Nitro onroad use foams on asphalt. Electric onroad uses rubber tires on asphalt.
SV is a HUGE track. I would buy a mod motor, something in between a 5.5 to a 3.5 BL motor. Try to keep your motor cooler than 160š F.
As far as ESC, the LRP Sphere, Novak GTB and Speedpassion GT would be good ESCs to try out.
For rubber tires, I would use the Sorex brand right now if possible (28-40) if you feel that you lose traction at the end of a 5min run, next time try harder tires. This all depends on track temp also.
what are the numbers on the sorex tires, 28-40, do they represent compound hardness
I use foam too. Try GRP in 35 or 37. It depends off temp.
If you are going to use lipo lrp sphere comp tc spec will be the most and brushless 5.5 to 3.5 will be nice, it depends off small or large track.
I use 6000 maxamps too and need mod in the chassis. you must raise the battery holderfor make room. May be more mod for 11v lipo
rubber setup and foam setup are alot different so you can practice with them but after that you need to change things.
2 pairs of foam are cheaper than 2 pairs of rubber so you donīt need them.
Now you have 3 answers so make 999.997 more.
I went by the track and everyone uses foams.
Who makes the best foam tires?
Hi,
You would be able to see everything first hand
If the track is going by ROAR rules, the mamba's are not on the approved systems list as of yet.
http://roarracing.com/approvals/brushlessmotors.php
