Old 08-27-2003, 01:43 AM   #1
cox
Trader Rating: 2 (75%+)
gearing for dummies pls help
Guys,
im new at electic 1/10 touring cars i really want to know how to compute which pinion i should use. im using yokomo 4mtc-sd-ssg im racing stok motor for now i havent change my stock spur which is 70t, can you please help me with the easiest formula to compute the right gear thanks in advancce...
cox is offline   Reply With Quote
Old 08-27-2003, 05:42 AM   #2
Send a message via AIM to zachzachz
To get your final outdrive ratio (which is the overall ratio of your gears) you simply do some math:
spur/pinion times your cars gear box ratio which should be in your manual.
like with my car I'm using a 88t spur and a 24t pinion so my formula would look like this:
88/24 x 1.83= 6.71
The 1.83 is my cars gear box ratio. You generally want to keep your final outdrive ratio around or above 7, dont go less otherwise you'll probably cook your motor.
Hope that helps
zachzachz is offline   Reply With Quote
Old 08-27-2003, 06:31 AM   #3
Regional Moderator
R/C Tech Charter Subscriber
http://www.arroyoc.com/index.cfm?fus...utilities.gear
Ko Racer is offline   Reply With Quote
Old 08-27-2003, 06:48 AM   #4
CRASH's Avatar
Trader Rating: 26 (100%+)
Post Ko Racer
Great web site link.
Thanks,
CRASH is offline   Reply With Quote
Old 08-27-2003, 08:55 PM   #5
cox
Talking thanks you all
thanks a lot for the help ill now i know. appreciate it..
Old 08-27-2003, 09:16 PM   #6
Tag
Tag's Avatar
Trader Rating: 31 (100%+)
for your particular car ( SD ) here' s the calculaiton spur/pinion X 2.35 ..
* Serpent 966 TE Novarossi 35+21, Airtronics M12 *
Tag is offline   Reply With Quote
Set ups for Dummies sosidge Electric On-Road 2 11-21-2007 10:54 AM
tc4 for dummies bignotch Rookie Zone 2 01-25-2006 04:07 PM
Gearing for Dummies. [HELP] DustinR Electric On-Road 5 08-13-2005 03:10 PM
painting for dummies pigpen22 Painting, Designs, Graphics and Photography 5 12-29-2004 06:18 AM
Painting for Dummies Round_Guy Painting, Designs, Graphics and Photography 2 07-13-2003 11:34 AM
