Old 08-26-2003, 02:22 PM   #1
Default Hudy????
I was wondering if hudy setup boards can be used to set up the TB Evo3???
Are they generic to use with any make of cars?
What are people experience with hudy?
Wheres the best place to buy one?
dmlk is offline   Reply With Quote
Old 08-26-2003, 03:08 PM   #2
Send a message via AIM to ZER01
The hudy setup board is just a flat board. You are talking about the hudy setup system. Hudy makes differant versions of the system to accomodate differant scales and classes, if you are getting the one for the 1/10th scale touring cars, it will work on all the 1/10th cars out there but the axle holes are drilled for metric axles so you will have to bore out the hole so it will fit american sized axles if your car is standard/american.
ZER01 is offline   Reply With Quote
Old 08-26-2003, 04:51 PM   #3
Yup.. I meant the hudy setup system.
I have a tamyia so I guess I will not have to bore out any holes?
What setup boards do you guys use?
Best place to buy them i.e websites address???
Old 08-26-2003, 04:52 PM   #4
Yes the tamiya axles will be okay. As far as setup boards I use the hudy setup board without vinyl grid sheet.
Old 08-27-2003, 09:30 AM   #5
Randy Caster's Avatar
Trader Rating: 46 (100%+)
I recommend the ultimate setup system, should work on any 1/10 sedan with metric axles. It will include everything you'll need to make your car dialed
Old 08-27-2003, 07:00 PM   #6
Default setup systems
I love all my hudy tools, tire truer, comm lathe, etc.....but....go with the integy setup system!!! It is much easier to read because it is blue/purple aluminum with white lines painted. I know of 3 people that traded their hudy's in for the integy because they could read them better!!!
Joneser is offline   Reply With Quote
Old 08-27-2003, 08:10 PM   #7
hierog's Avatar
I haven't checked out the integy setup yet. I was pretty sold on the Hudy system because of a friend. Either way, it sure will be nice to get the car dialed in!
hierog is offline   Reply With Quote
hudy advance comm lathe with hudy diamond bit flysti Australia For Sale/Trade 8 06-04-2006 04:27 AM
Hudy Tire Truer / Hudy Lathe / Hudy Diamond Bits koabich R/C Items: For Sale/Trade 6 05-04-2006 06:39 PM
hudy advance comm lathe with hudy diamond bit flysti Australia For Sale/Trade 2 03-28-2006 05:41 AM
Hudy Hudy Power 12V Tire Truer #102006 Dolce R/C Items: For Sale/Trade 1 12-28-2005 09:32 AM
Integy, Hudy setup. Hudy truer. Airtronics servo. 1/12th foams Scott Fisher R/C Items: For Sale/Trade 10 10-27-2005 08:35 PM
