Old 09-05-2003, 08:29 AM   #31
TimPotter's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to TimPotter
John. I charge 4.5 amps for my 12th scale
Clean Title & Escrow|p3|TRF|Tamiya|SerpentAmerica|FSEARA|Team Butter|RC 3|Munno |RCTECH #29|EAMotorsports|BMI|Novak|SpeedPassion|RadioPost
TimPotter is offline   Reply With Quote
Old 09-05-2003, 08:56 AM   #32
Accord's Avatar
Send a message via AIM to Accord
Thanks Bryan and Tim. I think i'll charge at 4.5 amps since run time has always been an issue with me in 12th scale .
Accord is offline   Reply With Quote
Old 09-05-2003, 09:00 AM   #33
Balak Racing's Avatar
Send a message via AIM to Balak Racing Send a message via Yahoo to Balak Racing
Yea, the lower the charge rate, the higher the capacity of the cell after the charge. The new GP 3300s are so good, voltage no longer seems to be a concern.
Bryan
Balak Racing is offline   Reply With Quote
Old 09-05-2003, 10:43 AM   #34
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
Originally posted by Balak Racing
I charge both at 6 amps.
For NiCDs - Turboflex on, setting = 7, peak voltage = 0.7 volts
For NimHs - Turboflex off, peak voltage = 0.03 or 0.04 volts
Repeak if desired.
Bryan
Thanks Bryan, I will try those....
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 09-15-2003, 08:15 PM   #35
Kenneth Tan's Avatar
Has anyone tried the motor mode on the GFX with a 12.5A power supply? Will it even work at all? I tried to power a D5 10 single with 1V and my power supply tripped... Any ideas?
Kenneth Tan is offline   Reply With Quote
Old 09-15-2003, 08:48 PM   #36
A mod motor will draw too much power for a 12 volt supply. From the GFX manual:
SUPPLY VOLTS- The GFX will operate from any DC supply within the voltage range of 12 to 16 volts and 20 amp or more capacity. It will operate with less amperage, but the charge current and motor run will be limited to the maximum capacity of the supply. A 15 volt supply is required to charge 8 cells.
Get yourself a 30 Amp Rivergate Power Supply, and you won't ever have this problem.
http://www.rivergatedist.com/
Bryan
Old 09-15-2003, 08:56 PM   #37
Thanks!
LRP Sphere TC ESC switching from nimh race mode to lipo mode mok Radio and Electronics 2 07-22-2008 03:14 AM
what is the difference ppm or hrs mode 793bob Electric Off-Road 2 04-10-2007 09:45 PM
3pk mode aus jd 2703 Australian Racing 6 12-28-2005 02:57 AM
FS: NIB TOP .12 3port turbo motor, NIB RD Logic Turbo II exhaust rossiRocket R/C Items: For Sale/Trade 19 12-06-2005 10:10 AM
Justin Ala Mode RCGaryK Buyer/Seller dispute and Feedback discussion forum 0 06-15-2004 11:31 AM
