KO Propo VFS-2000 ESC
#121
Originally posted by nnick
Hello,
In Novemeber 2002 when I participated to HPI worlds I purchased 1 VFS2000 and 1 VFS2000J.
The only differences I could/can understand are that the J version isn't carbon and has cables!
1. Is this J version same as the one I have?
2. Are there any more serious difference between the two VFS2000 and VFS2000J?
Nick
Hello,
Nick
robert from Ko told me that the only difference between the 2k and 2kJ is that the 2kJ leaves a little bit of battery so when you dump, you'll have some steering left. i made the mistake of running my batteries down at tamiya raceway all the way down...and my car wouldnt turn, it would just go crawl straight. robert correct me if im wrong on that one.
#122
where can I download vfs2000 manual?
#124
Hello,
Nick
Hello,
Nick
The difference between the normal and J version is the BEC system in the ESC. The normal version will allow you to fully run down the battery pack. The J version will limit the power to the motor once the voltage drops to about 2A. Then the power is prioritized to the steering.
Also, the normal version comes with 12GA wire and a super shotki diode. The J version comes with 15GA wire pre-assembled and a normal shotki diode.
The J version was designed as more of a semi-professional product, for those that found it sort of difficult to dial the VFS in. The normal version is more of a professional version for those that are comfortable utilizing all of there battery pack.
#125
Originally posted by Hebiki
nick
nick
You are correct.
#126
The manual is available online at the following location:
go to the kopropo site. There, click on support and then on manuals. You will find a list of manuals that are available for download for free.
#128
Originally posted by proudwinner
zombie, horizon has them for $177.
http://horizon.hobbyshopnow.com/prod...?prod=HBS90000
I never get to open anything for Christmas..
#130
luckiest guy on the planet...
Originally posted by rc-zombies
Anybody know where I can get the Hara Twister online for a good price?... HB/Ricky's Rc Car sell them for $220.00
lmk thanks.
Happy Holidays!
lmk thanks.
Happy Holidays!
#131
Re: luckiest guy on the planet...
rc... if you have time.. scour the different hobby shops in your area. i bought my hara twister for $130. it was sitting in case at my LHS.. all dusty surrounded by GT7s, Quantum Comps and others. looks like no one knew what it was. as soon as i saw it, i did a double take on the price.. then bought it without hesitation. so if i were you... just go hunting, you never know what you might find.
If I get the handheld programmer it about $65.00+
decisions....decisions...
#132
KO staff : I had download but it's not vfs2000 manual, it's vfs setting manual???? Please advise.
#133
repair
Can anyone pls tell me where can I send my VFS for repair? I just brough it a few days ago and I accidentally connect the positive to the negative to the batt for less then a few seconds. The esc still worked fine until the next day I try it again, I found that there was no brake. I disconnect everything and put it on again and this time, the motor kept turning without need to switch on the esc. Anyone know what is the estimated repair fee I must pay? Btw I m from Singapore
#134
Ko Propo Staff: I'm not use plug on my batt, I solder it to the esc wire, when I repeak, I always solder batt to esc wire then repeak , this will damage this esc or not? But with my old esc, it has no problem.
#135
KO Propo Staff,
Will even an instance of wrong battery polarity on the VFS-2000 damage it? What happened was that I connected a corally plug to one end of the pack and merely touched the other plug to the other end of the pack, then my car suddenly jerked backwards... The esc still worked fine during a race, but after Alucard's experience, i am worried that my esc is going down soon. Is there any tell tale signs that my ESC is damaged? Anyway that I can check without sending it for repair? Thanks.
Kenneth
Kenneth
