KO Propo VFS-2000 ESC
#106
VFS
Yes, all the way 32 steps basically linear at that setting. I run two caps in parallel. I run a reciever pack to power the radio gear and personall. Yes I ran it like in stock, I never plan on running stock so the car stays the same. Although I did run the boster with the Diode. Hope this answers you Q'sss.
Later CD
Later CD
#107
vfs
Chris , you run the booster and the shotkey diode on the motor together, this is the diode you are talking about, the shotkey? where do you find any room for that much stuff?? The booster is huge!! I was wondering if it could be run inline on the wires instead of directly on the motor, or would this cause the speedo to go poof!
thanks rogt
thanks rogt
#108
VFS
You know I have no problem fitting anything in a sedan and talk about big check out a Novak!!!!!! You can run the stuff in line with the wires but it is best on the motor! I have only used the booster in stock I always run 7 or 8 turn mods. Best of luck CD
#109
Re: vfs
thanks rogt
thanks rogt
You can run the diode or the hyper booster in-line, but ideally it should be on the motor. The closer you can get this to the motor, the more eff. and less noise you will have from your motor. If you are worried about blowing up the hyper booster (it's not cheap, i know), place the super shotki diode that came with the VFS in parallel. The open eyelits on the super shotki will allow you to solder the Hyper Booster through it. Make sure to leave room so that you can still solder the Hyper booster up. This should prevent the sudden misfortune of you Hyper Booster.
#110
Hey Chris haven't seen you since outdoor nats. What setting did you use in Cleveland for 1/12? Also I have been told that if you don't have a switch for the reciever pack you can just use the one on the esc by removing the positive wire going to the reciever. Thanks bro.
#111
Ko propo staff: It is possible to use both hyper booster and shotki diode in same time? shotki that you recommend is #45556 or #45513?
#112
anyone know which online shop carry Atsushi Hara Twister?
#113
You can use the super shotki diode long with hyper booster. The super shotki diode is part #45513.
#114
Robert, saw you are online.. saved myself a phone call...lol
Do you know if my package has left yet or if it has when it might be here?
Thanks for the update- TTYL
BTW- looking forward to trying out the Hyper Booster!! Ron says it makes a big difference on good stock motor car.
#115
Robert, any word on the "J" series 2000's coming in. Would like to
have it by the Novak race in Jan. if possible. Do I need to turn Blackketter loose on you? LOL
#116
#118
Your package did leave, I beleive on Friday. Expect a delay from the holiday shipping service. Looks like even US Priority mail (usually 2-3 days) takes about 6 now.
#119
Originally posted by KO PROPO Staff
Jason,
Jason,
#120
Shop Owner
Hello,
In Novemeber 2002 when I participated to HPI worlds I purchased 1 VFS2000 and 1 VFS2000J.
The only differences I could/can understand are that the J version isn't carbon and has cables!
1. Is this J version same as the one I have?
2. Are there any more serious difference between the two VFS2000 and VFS2000J?
Nick
Nick
