KO Propo VFS-2000 ESC >
Old 10-28-2003, 10:45 AM
  #76
Originally posted by Barry White
KO PROPO staff.
I saw that KO have to different sizes of caps.
Are there any other differences?
Why do these have a 35V rating. Isn't 10V enough becouse this only makes them bigger I think.
Barry White,
Typically, we use two of the regular power up condensors for modified due to voltage drop. This new super power up condensor will eliminate the need for two caps.
KO PROPO Staff is offline
Old 10-28-2003, 10:46 AM
  #77
Originally posted by rookie80
Does anyone have the twister (hara's ESC) out of the box setting?
thanks in advance..
rookie80,
Hara's ESC out of the box setting is the same as the VFS-2000.
Old 10-28-2003, 01:28 PM
  #78
Trader Rating: 30 (100%+)
Is it neccasry to run a reciever pack like Hara and Dosek do with there vfs2000's?I love my speedo but wonder if this speedos bec is set so it will allow the radio to always control steering.Anyone have problems at all?
racenut123 is offline
Old 10-28-2003, 03:45 PM
  #79
racenut123,
They run the receiver pack because the servos will not opperate at the specs that they like them to due to only being 4-cells.
Old 10-28-2003, 06:16 PM
  #80
rookie80's Avatar
Originally posted by KO PROPO Staff
rookie80,
thank you for the prompt reply
rookie80 is offline
Old 10-28-2003, 06:27 PM
  #81
I have seen them in there sedans not 12th scales.
Old 10-28-2003, 06:30 PM
  #82
Team EAM
Trader Rating: 79 (100%+)
I got a Twister a few weeks ago...I must say I like it much better than the Futaba MC800 I was using. KO is smoothe and more adjustable.
ea
EAMotorsports is offline
Old 10-28-2003, 06:35 PM
  #83
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
most of the 12 scale guys use the vfs 2000...in Japan....
very nice speed-O
JDM_DOHC_SiR is offline
Old 10-28-2003, 07:11 PM
  #84
I have no complaints with it.Just wondering why.
Old 10-28-2003, 08:31 PM
  #85
Default Drive frequency
Hello.I run motor mod 7x2.Should be set drive frequency?Thank you.
bambaa is offline
Old 10-29-2003, 07:22 AM
  #86
fai
Regional Moderator
fai's Avatar
very nice speed-O
Dave: I'm happy to say that I just got myself a VFS a few days ago at Tokyo! Can't wait to test it! So, do you suggest getting the pc link kit or just keeping running with default 2kHz? Thanks!
fai is offline
Old 10-29-2003, 07:25 AM
  #87
Hi Fai..!! Long time no see
the stock one works rather well..but I do have a pretty nice program for 23T
-Dave
Old 10-29-2003, 08:43 AM
  #88
Registered User
Suradaj's Avatar
I run the TAMIYA version of this(pretty much the same thing)and it runs great. I did change the setting for different tracks and you can tell major difference. I have the PC interface and the hand held unit but, the hand held unit is much easier for me since I don't have a laptop for the PC version to take to the track.
I had lot's of help at the TAMIYA TCS and NATIONALS. Thanks to Mr. Morris and Mr. Nakagawa from KO PROPO USA for everything~!
Suradaj is offline
Old 10-29-2003, 11:00 PM
  #89
fai
Regional Moderator
fai's Avatar
-Dave
Thanks!
fai is offline
Old 11-10-2003, 09:32 AM
  #90
berger's Avatar
Can you pickup the settings adaptor seperatly, and if so how much is it?
berger is offline
