KO Propo VFS-2000 ESC >
Old 08-01-2004, 05:24 PM
  #616
=MisFitz= NuKe's Avatar
Originally posted by PizzaDude
Guys,
Get me setup for a 19t on a way big circuit please.
I really need top-end speed.
Which setup can you guys give me.
And which cap(or caps) could I be using at best.
I'm talking European 8th scale circuit here!
Thanks guys.
Hi, try out my Nats setup for 19turn, It was freakin dialed. And try it, then let me know how it runs, and we can tweak it from there. If the track is really big, and you dont really notice the torque my setup has (you should notice the torque on a regular track), then take the ALL, and move all of the frequencies higher to get better run time, or more eff.
Let me know,
Mike
Oh ya, if you cant find it on here, go to Ko's site and download the 19turn Nats setup, that was mine.
=MisFitz= NuKe is offline
Old 08-01-2004, 05:30 PM
  #617
here is my nats setup (the one on Ko's site), if you couldnt find it, or didnt want to download the prog to view it.
or try this
  #618
PizzaDude's Avatar
Misfitz,
Thanks.
I was thinking along the same lines as you.
I'll probably be dialing it up.
I'll keep you posted.
Did you notice any difference between the caps, oe way or another?
Regards,
Pizza
PizzaDude is offline
Old 08-01-2004, 05:32 PM
  #619
PizzaDude's Avatar
I got it the same day Robert said he put it up.
So thanks again.
Old 08-01-2004, 05:48 PM
  #620
Well, I have messed with both the super cap, or what ever it is called, it is like 2500 or 2400 microfarads, and I have also tried two of the 1000 microfarads, or the stock ones together, and cant tell the different. I know the one big one works really well in mod though, and probably in 19turn, I would go with the higher capacity one.
Old 08-14-2004, 02:44 PM
  #621
Hello,
I want to buy a KO esc, which one is the best???
Is there a new one coming soon?
Which one Hara uses?
Thanks guys for your answer
Hugo is offline
Old 08-14-2004, 05:12 PM
  #622
rc_bam226's Avatar
Hugo, the VFS-2000 and VFS-2000 J are the same speedo. The only difference is the connector.
Hara uses the VFS-2000 with a different case. It's called a Hara Twister.
As for the newest one, the VFS-1 Pro, its coming out soon.
rc_bam226 is offline
Old 08-14-2004, 05:19 PM
  #623
Trader Rating: 27 (100%+)
Hi! I am interested in this new one too but i cant find much info on it at all. what is the resistance of it? also, must you use the hand controller to program it as i cant see any buttons or LED on it
cheers!
poop is offline
Old 08-14-2004, 07:26 PM
  #624
ok, well
First: The VFS-2000 and VFS-2000 J are not the same. The VFS-2000 J is designed for a new racer. It stores a certain amout of power for the servo, that along with some others minor things.
Second: The new speedo is coming out in a month or so. Very soon now. You don't really need to see the specs because it is going to blow away everything out .
But seriously, we already talked about the new speedo one or two pages back. BUT!!!! to refresh. It is smaller than the current one, the lowest freq. is a bit higher, but the highest frequency is much much higher, 12,000Hz versus 6,000Hz. And yes, you do have to use a programmer, like the current one. Although you wont be able to use the same programmer because of the more steps in the Freq.
Old 08-14-2004, 08:46 PM
  #625
SalvadoriRacing's Avatar
the new VFS1 will be "THE ESC".......
it's cheaper if compare to the older one, very, very strong, smaller, beautiful =]=]=]=]=]=]=] and the new ultimate schottky seems to be great!!!
SalvadoriRacing is offline
Old 08-14-2004, 08:58 PM
  #626
Trader Rating: 30 (100%+)
Default off the topic
I wanted to ask if anyone has had issues with Ko's service department reliability and speed.I have a 6 month old Helios thats has taken a dump and I need to have it serviced. Anyone know what the turn around is like with them? Otherwise I may be up a creek with tcs nats coming up! Help!
racenut123 is offline
Old 08-14-2004, 09:23 PM
  #627
STLNLST's Avatar
Trader Rating: 29 (100%+)
I'm glad you asked that John.....LOL pm me and I'll get you the info you need to get the ball rolling.
STLNLST is offline
Old 08-14-2004, 09:36 PM
  #628
gcooper's Avatar
The VFS1 seems like its gonna set the standard. Anybody get a price on one yet with the programmer?
Coop
gcooper is offline
Old 08-15-2004, 03:49 AM
  #629
Merciless's Avatar
Default Re: off the topic
When i had to get my VFS2000J repaired, my only problem was convinsing them that a 3 month old speedo should be repaired under warranty(bareing in mind it was the first time i had used the thing and it went wrong, i was feeling very upset when at first when i was confronted with a you'll have to pay answer).
Anyway i think robert had it for 2days before it was in the post back to me which i think is a very good turn around !!
Merciless is offline
Old 08-15-2004, 03:09 PM
  #630
224 dollars on kopropo.com (shopatron)
