KO Propo VFS-2000 ESC >
Old 07-26-2004, 02:45 PM
  #556
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally posted by =MisFitz= NuKe
It is supposed to be advertised in Japan right now, or very soon
then usually a month afterwards it is released in Japan (probably a month from now) it will come here, so Maybe a month to two months.
a believer now huh?
rod_b.. id run super shotski diode along with the hyperbooster(s).... that way the diode will blow up first before the hyperbooster(s). robert pls correct me if im wrong on this.
from my conversations with robert... everything mike posted is correct.
the new VFS has higher frequencies because in Japan, they run 8 mins, instead of the usual 5 we run here. plus no one ever really dipped down to stage 1 or 2 in the current VFS escs.. i think im one of the few that actually set my escs that low. 500hz instead of the new 900hz that will be on VFS-1
Hebiki is offline
Old 07-26-2004, 02:53 PM
  #557
=MisFitz= NuKe's Avatar
well, you shouldnt really have to ever go that low on the settings...lol
of course everything I posted is correct, I am the non-official Ko guru
and in mod, you dont need the hyper boosters. just enough shottkys, and make sure you dont have your brake set above about 65 percent on the radio...
=MisFitz= NuKe is offline
Old 07-26-2004, 02:54 PM
  #558
HarshGuy's Avatar
Alright, here it is.
hopefully you guys can understand that...
what class was this in?
HarshGuy is offline
Old 07-26-2004, 02:55 PM
  #559
This was my 19turn Nats setup
Old 07-26-2004, 03:08 PM
  #560
Originally posted by RC Old Man
Any one running Trinity big brush mod motors? If so have you had problems buring the brushes? I used a 2300htz accross the board and it helped but did not solve the problem.
Try using a higher frequency say about 3200Hz. This will give you a little more efficiency, save the com and brushes, a give you a little more runtime.
KO PROPO Staff is offline
Old 07-26-2004, 03:10 PM
  #561
Trader Rating: 255 (99%+)
I will! but doesn't higher the freq cause more heat?
I know lower causes more arcing.
Fred Perkins is offline
Old 07-26-2004, 03:15 PM
  #562
well, I dont know about the arcing and all that, but all the higher freq. is doing is, when the speedo gives power to the motor, it does it in pulses, higher freq, means more on/offs per second (Hz, or times per second), which will make it more efficient. but you probably already knew that...
Old 07-26-2004, 03:22 PM
  #563
Hebiki's Avatar
dang i lost my title
Hebiki is offline
Old 07-26-2004, 03:23 PM
  #564
Hebiki's Avatar
hey mike.. i never posted that stuff because i felt robert will get lonely when comes on this thread. he'll never have anything to post! between me and you.. looks like robert never needs to login!
robert u racing tomorrow? i got a very important question to ask you about the Ko Grand Prix.
Hebiki is offline
Old 07-26-2004, 04:25 PM
  #565
Hahaha, hey, I have an idea, lets you and me move to L.A. and take over Ko USA office, lol, but we will keep robert around just because he is cool...
Old 07-26-2004, 04:26 PM
  #566
Scott B's Avatar
Trader Rating: 45 (100%+)
Default Repair Service
Ko propo Staff-
Were do I send in a VFS speedo that I need to have repaired?
I friend was using my car with his batterys and his batterys are switched from mine, and it got wired backwards. About how much does the repair service cost?
Thanks,
Scott B is offline
Old 07-26-2004, 04:36 PM
  #567
Default Re: Repair Service
Originally posted by Scott B
Ko propo Staff-
Thanks,
Scott- If the PC board is not damaged (most likely it is) only the fets will need to be replaced. Each fet is $5.00. A new PC board complete with fets is $60.00. Plus labor and shipping. It all depends on what is damaged. Send it in to KO directly and I will take a look at it. Include contact info.
Old 07-26-2004, 04:37 PM
  #568
But you don't speek Japanese.
Old 07-26-2004, 04:47 PM
  #569
Hmm, I can learn...
I know moshimoshi (hello, right?), that is good enough to answer the phone, then I can give the phone to Naka, lol.
Old 07-26-2004, 04:50 PM
  #570
rod_b's Avatar
Anyone know where I can get the pc adapter for the VFS2000 locally (LA area) or online in the US?
rod_b is offline
