Old 06-16-2004, 01:26 PM   #481
rcsabah's Avatar
any one have the best setting for high speed track 12 motor
esc setting
rcsabah is offline   Reply With Quote
Old 06-16-2004, 02:20 PM   #482
=MisFitz= NuKe's Avatar
Send a message via AIM to =MisFitz= NuKe Send a message via Yahoo to =MisFitz= NuKe
Originally posted by KO PROPO Staff
Is that all that you want? You gotta raise your prices, I almost feel guilty!
hahaha, ok...hey how about that speedo I sent you...you can pm me about it if you rather...
=MisFitz= NuKe is offline   Reply With Quote
Old 06-22-2004, 08:03 AM   #483
prodrive's Avatar
Default to ko propo staff
prodrive-
The ESC will handle any turn motor, but you will have to set it and use the correct amount of super shotki diodes. The super shotki diodes have the power of two regular shotki diodes. To get the full potential from the ESC you will need to program it. If you need more runtime, go higher in frequency. Take a look at the website at http://www.kopropo.com/vfs_help_center.htm There we have 23T motor settings and other settings. You can also download the PC interface program off of the website under downloads to check out the program.
since your last reply, fortunately i came across vfs setting adapter and bought it. of course i opted for the handheld unit cause i dont like to bring my laptop everytime we go to the track. since this was a big investment for me, and since then i have also acquired tbevo3 surikarn edition, and i need another esc. so i am now considering to buy kopropo's vfs j version. my question is: is the j version exactly the same as trf 2002 esc that i am currently using? is there any disadvantages using j version instead of the other? is the manual exactly the same between j version, trf 2002 esc, and the non j version? could i use keyence's power cables to replace the preinstalled wires? thanks for your help
prodrive is offline   Reply With Quote
Old 06-22-2004, 10:37 AM   #484
Default Re: to ko propo staff
You can still use the PC program to save an look at all of your settings. The J version is the same as the TRF version, but the J has the 7.2V lead. The only disadvantage is that you can not run the battery pack all the way down, but you should not have to with setting changes.
KO PROPO Staff is offline   Reply With Quote
Old 06-22-2004, 10:39 AM   #485
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default Re: Re: to ko propo staff
are you gonna be at socal tonight? need to give you an entry for the Ko Grand Prix.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 06-22-2004, 11:42 AM   #486
Hebiki-
I will try to make it. R U?
Old 06-22-2004, 11:44 AM   #487
Hebiki's Avatar
Hebiki-
will be there. wanna do some experimenting with my VFS.. try out different settings. probably the last time ill be racing at socal tho.. you know my situation
Hebiki Design Works
Old 06-22-2004, 12:10 PM   #488
I'll try to be there, about 80% sure.
Old 06-22-2004, 11:10 PM   #489
prodrive's Avatar
what do you mean by 7.2v lead?????? i can only run 6 cell??? can i use ko's fet servo? can i add an extra receiver pack? how much is all the way down? and what setting changes???
Old 06-22-2004, 11:21 PM   #490
I am pretty sure Robert is talking about the 7.2v lead for the super fast servos that require that plug-in, and with the J version it keeps enough power so that you can still control the servo, and have power to the reciever. With the regular 2000 if you bring the packs power ALL the way down, at a certain point the car will just stop working, no power to the motor, and none to the reciever, which means you will have a VERY slow run-away
Old 06-23-2004, 03:21 AM   #491
prodrive's Avatar
Default masami's esc
which version does masami use??? j version or regular version
atsushi hara uses which one for his rev motor
Old 06-23-2004, 04:28 AM   #492
tornado
Guest
Posts: n/a
Default Re: masami's esc
masami don't use that ko anymore.....the latest i've seen was GM SX9 and now he may be using SX12!
Old 06-23-2004, 11:33 AM   #493
prodrive-
Just like what =Misfitz= Nuke said, but the car will not run away. It will just be dead.
Old 06-23-2004, 11:36 AM   #494
Default Re: Re: masami's esc
Masami used the VFS-2000 for the Reedy Race this year.
Hara uses the Twister which is the same as the VFS-2000 J.
Old 06-24-2004, 06:25 AM   #495
prodrive's Avatar
Default to ko staff
thanks for the info and the tips it really help me out
ko propo vfs-2000 esc nitro kid R/C Items: For Sale/Trade 1 03-29-2008 12:29 PM
KO Propo VFS 2000 ESC Help simba350 Australian Racing 3 11-08-2007 11:34 PM
~F/S Ko Propo Mars R/Ko Propo VFS 2000 Pro/BMI FK05~ RandomTask R/C Items: For Sale/Trade 5 06-21-2006 10:18 PM
Ko Propo ESC, VFS 2000/VFS-1 Thraex R/C Items: Wanted to Buy 0 03-13-2005 02:21 PM
KO Propo VFS-2000 ESC AGR#7 Electric On-Road 9 01-06-2003 11:35 AM
