KO Propo VFS-2000 ESC >
Old 05-25-2004, 01:56 PM
  #436
V12
V12's Avatar
Originally posted by Hebiki
give me a call on my cell.. so i know what to do with the images. i got some really good pictures for you. i didnt know you were racing Reedy? or just helping with the Ko drivers?
psst... by the way get me Masami and Atsushi's throttle profiles!
Masami is running a VFS-2000 ESC? This is new to me if this is true. As I know he is running for GM-Racing.
V12 is offline
Old 05-25-2004, 03:27 PM
  #437
PizzaDude's Avatar
V12 I agree.
But on the Ko site there is a setup posted as being used by hara and masami?!
PizzaDude is offline
Old 05-25-2004, 03:28 PM
  #438
rc-zombies's Avatar
Originally posted by PizzaDude
V12 I agree.
Masami used KO before switching to GM...that's my guess...
rc-zombies is offline
Old 05-25-2004, 03:38 PM
  #439
V12
V12's Avatar
That makes sense. I remember Masami using Tekin ESC long time ago. But I didn´t know what he was using after that before he switched to GM.
V12 is offline
Old 05-25-2004, 04:26 PM
  #440
Masami had problems with his GM and used the VFS-2000 for last year's All Japan Nationals. This is were the setting came from.
KO PROPO Staff is offline
Old 06-01-2004, 02:34 AM
  #441
ko propo staff
Do you have schottky diode specification? Like how many amps and volts? So, I can use other diode without hurting vfs2000.
hamba is offline
Old 06-01-2004, 08:25 AM
  #442
=MisFitz= NuKe's Avatar
Well, don't have any specs or anything, but those regular round black schottky diodes, that like novak sells, are what the super schottky is made out of, except one super is equal to two of the regular ones. Any hobbyshop should have those regular ones.
=MisFitz= NuKe is offline
Old 06-01-2004, 10:37 AM
  #443
Merciless's Avatar
Hi All,
Can anyone tell me is there a reason why i couldn't put the hyper booster across the wires feeding the motor instead of actually on the motor as i don't have room for it there in my little 12th car ??
At present i have 2 schottky's in the wiring so do i remove them or just add in the hyper booster or do i not use the booster as i can't get it on the motor ?
Please help
Merciless is offline
Old 06-02-2004, 05:56 AM
  #444
Should I also install schottky diode on 540 motor like Johnson or Mabuchi?
hamba is offline
Old 06-02-2004, 09:09 AM
  #445
Hmm, well, the schottky is for dampening that short across the motor when braking, and you need several of them for mod motors, but with a mabuchi, those things are so slow. I would try like 2 or 3 schottkys (which may still be overkill), so one super schottky and one regular. I would rather have too many on there than too few.
Old 06-02-2004, 11:19 AM
  #446
Originally posted by Merciless
Hi All,
Please help
I don't see a problem with putting in-line with the motor wires. I do this on my own cars so that I don't forget to put them on. The Hyper booster would replace one of the super shotki diodes, but you can use both at the same time.
Old 06-02-2004, 11:20 AM
  #447
Definitly.
  #448
Originally posted by KO PROPO Staff
Definitly.
YGPM
True R/C Racing is offline
Old 06-04-2004, 01:11 PM
  #449
ko propo staff,
would it be any effect on performance if i change the factory cable (15 awg) to 13 awg cable? is it good or not? tx.
hamba is offline
Old 06-04-2004, 03:44 PM
  #450
not much performance difference, I run 14 awg, just because with the real low turn mods the thinner wires tend to heat up a bit more, and if I can cool the wire down by going to 14 then why not?!? Also, 14 is much easier to find at any local hobby shop.
