Old 09-04-2003, 01:38 PM   #31
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default extreme settings?
i got a question... during the June 8 TCS.. i programmed my VFS to all "1" for all 32 stages of the esc. i was running a monster pro in an F201 that had the high speed gear set (FDR of about. 5.96)
is there anything bad with doing this? (i knew i was in danger of burning the motor) but i did manage to finish 2nd in the D-main in my first ever TCS (not bad for a first time F201 driver).
actually ... i did BURN the motor.. but besides the motor ... is there anything else that can get damaged? batteries? the esc itself? i think the FDR had something to do with the burned motor, and not the programming on the esc. the car was PUNCHY AS HECK tho since i ran 1.179 GP3300s on it.
lastly... is anyone running the booster along with the capacitor that was provided with the esc? are there disadvantages or advantages to running one over the other? and what happens if i run both?
let me know.. thanks!
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 09-04-2003, 01:54 PM   #32
Erik R.'s Avatar
Default Re: VFS-2000
Originally posted by KO PROPO Staff
Discoloration in the com and brushes is a result of too low a setting in the drive frequyency, worng timing, or wrong brush set up.
Modified motors:
The rule for modified motors is not to go below 2000Hz or a FREQ setting of 17. Doing so will give you more power, but you run the risk of overheating and damaging the ESC.
If 17 was the minimum setting for mod, then 1 might be too low for stock. If your speed control was hot after that run then you should go higher on the setting for sure. Besides running the frequency that low means your sacrificing a little top end. At SoCal Raceway I have mine set at a maximum of 19 for my Monster Stock motor and SoCal is a tighter track than Tamiya. The other problem you’ll probably run in to is that when your motor gets hot enough to burn the brushes your going to notice a “fade” in the motor’s performance. This happens with any electric motor that overheats.
Erik R. is offline   Reply With Quote
Old 09-04-2003, 02:33 PM   #33
Wink
Thank you
bambaa is offline   Reply With Quote
Old 09-04-2003, 03:07 PM   #34
Setting your VFS at a frequency of 1 does have its draw backs (runtime, brush wear, and excessive heat). You do get the punch but you pay the cost. It all comes down to personal preference. That makes this ESC unique. Now for mod, I would never recommend going this low. You would run into overheating the motor and the ESC and other problems.
Erik R., you have seen what the VFS can do to 3300 cells in a five minute race using a stock motor. Many people don't beleive me when I say that this ESC can do this to a stock motor.
It all comes down to tuning. Think of it as another gear ratio that you are working with.
KO PROPO Staff is offline   Reply With Quote
Old 09-04-2003, 05:04 PM   #35
Erik R.'s Avatar
Yeah, I've run the VFS with a lower frequncy once with 3300's in stock. By the last minute my car started to dump. It wasn't dumping bad, but it was noticable.
Old 09-04-2003, 06:23 PM   #36
hobbipro's Avatar
Trader Rating: 21 (100%+)
Default Question for KO staff member
I reciently purchased the Tamiya version of your VFS2000. I did not get the super shotki with it, but a standard shotki. The esc seems to work flawlessly, is this super shotki something I should add, or will the standard one be sufficient. BTW I run stock class, and this esc will never see a motor hotter than a 19T mod.
hobbipro is offline   Reply With Quote
Old 09-04-2003, 06:30 PM   #37
Default Re: Question for KO staff member
hobbipro,
I would run two shotki diodes to be safe if you do not have the super shotki diode. When you run the two shotki diodes, stack them on top of each other.
Old 09-04-2003, 07:27 PM   #38
Kenneth Tan's Avatar
Is it possible to share the TRF program?
Kenneth Tan is offline   Reply With Quote
Old 09-04-2003, 07:31 PM   #39
Kenneth Tan,
If you have it you could share it.
Old 09-04-2003, 07:47 PM   #40
I mean can anyone share the TRF program?
Old 09-04-2003, 08:22 PM   #41
Barry White's Avatar
Stock (out of the box TRF program):
10-10-10-11-12-13-13-13-14-15-16-17-18-19-20-20-20-20-20-20-20-20-21-22-22-22-22-22-22-22-22-22.
Other TRF programs found on the Tamiya site.
http://www.tamiya.com/japan/products/49254trf2002esc/:
Stock (23T), High Speed:
15-15-15-15-15-16-17-18-19-20-21-22-23-24-25-25-25-25-25-25-25-26-27-28-29-30-31-32-32-32-32-32.
Stock (23T), Technical:
11-11-11-12-13-14-15-15-15-16-17-18-18-18-18-18-18-18-19-20-21-22-23-24-25-26-27-28-28-28-28-28.
Mod., High Speed:
17-18-19-20-21-22-23-24-25-26-27-28-29-30-31-32-32-32-32-32-32-32-32-32-32-32-32-32-32-32-32-32.
Mod., Technical:
17-17-17-17-17-17-17-17-17-17-17-18-19-20-21-22-23-24-25-26-27-28-29-30-31-32-32-32-32-32-32-32.
Sport Tuned, High Speed:
7-7-7-7-7-7-7-7-7-8-9-10-11-12-13-14-15-15-15-15-16-17-18-19-20-21-22-23-24-25-26-27.
Sport Tuned, Technical:
7-7-7-7-7-7-7-7-7-8-9-10-11-12-13-14-15-15-15-15-15-15-15-15-15-15-15-15-15-16-16-16.
RS 540, High Speed:
5-5-5-5-5-5-5-5-5-5-5-6-7-8-9-10-11-12-13-14-15-16-17-18-19-20-21-22-23-24-25-26.
RS 540, Technical:
5-5-5-5-5-5-5-5-5-5-5-5-5-5-5-5-5-6-7-8-9-10-11-12-13-14-15-16-17-18-19-20.
KO PROPO Staff:
Could you share the stock KO program and the ones on your site like this becouse my PC can't open the files.
Thanks,
Barry White is offline   Reply With Quote
Old 09-04-2003, 08:27 PM   #42
Thanks!
Old 09-04-2003, 08:29 PM   #43
Erik R.'s Avatar
The stock setting for the Ko VFS is all 17.
Old 09-05-2003, 05:06 AM   #44
icon's Avatar
Send a message via AIM to icon
guys, is the tamiya TRF2002 ESC still available or do i have to go with the KO equivalent?
chuck
icon is offline   Reply With Quote
Old 09-05-2003, 09:13 AM   #45
If you go for the Tamiya one there is an other difference. You have no 7.2V fet servo lead.
ko propo vfs-2000 esc nitro kid R/C Items: For Sale/Trade 1 03-29-2008 12:29 PM
KO Propo VFS 2000 ESC Help simba350 Australian Racing 3 11-08-2007 11:34 PM
~F/S Ko Propo Mars R/Ko Propo VFS 2000 Pro/BMI FK05~ RandomTask R/C Items: For Sale/Trade 5 06-21-2006 10:18 PM
Ko Propo ESC, VFS 2000/VFS-1 Thraex R/C Items: Wanted to Buy 0 03-13-2005 02:21 PM
KO Propo VFS-2000 ESC AGR#7 Electric On-Road 9 01-06-2003 11:35 AM
