Old 04-19-2004, 04:05 AM   #286
Originally posted by rc-zombies
Do not try It!!!
the KO PC cable has an internal circuit board in it.....
Chances are this is just a TTL to RS232 circuit based around a MAX232 or similar. This sort of thing is quite common on any microcontroller -> PC connection. I've seen these on PDAs, cable modems, GPS receivers , and so on.
Once again, I have never seen the cable so I'm only guessing and any experimentation is at your own risk.
firetooth is offline   Reply With Quote
Old 04-21-2004, 01:27 AM   #287
Merciless's Avatar
Send a message via ICQ to Merciless
Guys i just sold my NOVAK GT7 to try out the newer 2000j version of this speedo but was it a good move ???
Merciless is offline   Reply With Quote
Old 04-21-2004, 11:28 AM   #288
John_S's Avatar
Id say so!! The vfs is far more tweakable than the gt7 in my opinion that is. Hey guys do you have any good stock/19turn setups you could share with us? Or are the ones from Kos website sufficient enough?
John_S is offline   Reply With Quote
Old 04-21-2004, 11:35 AM   #289
Hebiki's Avatar
Trader Rating: 26 (100%+)
good choice in picking up the VFS-2000j. the "J" leaves a little bit of the battery left so you get some steering just in case your batteries dump, you can steer your car out of trouble.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 04-21-2004, 11:37 AM   #290
Hebiki's Avatar
pick up one of the programs from the Ko site.. those are great starting points that Ko drivers (Hara, Hirosaka, etc) use in their esc's. So you cant go wrong there.
what i did was, i grabbed the stock program and dropped it a few. so my initial throttle punch is increased. i usually have the first four stages at 8.. or even 6 depending on how much punch i want. and i always increase the top end also if there is a long straight away.
Hebiki Design Works
Old 04-21-2004, 07:10 PM   #291
Default PINK CAR
Chris-
It's that pink car again! Curse that car. Going to RCX? If so, see ya there.
KO PROPO Staff is offline   Reply With Quote
Old 04-21-2004, 07:25 PM   #292
Hebiki's Avatar
Default Re: PINK CAR
Originally posted by KO PROPO Staff
Chris-
DUUUUDE!
where have you been man? racing is not fun when your not around. i might go on saturday.. or go to tamiya. not sure yet. if i get the parts for the 415.. then ill go. most likely i wont get the parts in time tho.. so ill just go to rcx and bother you!
when are u gonna race again? you should join us at the parking lot races man. dont worry about power, ill hook you up.
Hebiki Design Works
Old 04-23-2004, 03:12 PM   #293
PizzaDude's Avatar
When I'm not sure which setup has been put into the VFS, is there a way to go back to the factorysettings?
PizzaDude is offline   Reply With Quote
Old 04-23-2004, 03:28 PM   #294
Francis M.'s Avatar
someone told me the stock settings are 17 all the way through
the power range.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 04-23-2004, 03:36 PM   #295
Hebiki's Avatar
the power range.
yup
Hebiki Design Works
Old 04-23-2004, 04:25 PM   #296
PizzaDude's Avatar
I was thinking more along the lines of resetting it.
Like f.i. with the GM esc's just holding the button for a few sec's and it's back at the factory settings.
You see, I'm not sure my vfs programmer is working correctly...that's why I'm asking.
Old 04-24-2004, 06:41 AM   #297
utieh's Avatar
Does someone have a direct link to the setting page on KO USA website?
I can't find this page from the home page anymore...
Does KO Japan has them too?
Thanks.
Gilles
utieh is offline   Reply With Quote
Old 04-24-2004, 06:55 AM   #298
utieh's Avatar
I'm looking for a tight asphalt mod set up
thanks
Old 04-24-2004, 07:12 AM   #299
Wency_TA03R-PRO's Avatar
Cool
OK and back again to this topic the VFS2000....
Do I need to unhook the red servo wire from the esc when using a seperate receiver pack?
regards,
Pizza
Sure thing dude!!!..
Wency_TA03R-PRO is offline   Reply With Quote
Old 04-24-2004, 07:17 AM   #300
Thumbs up
I agree with what hebiki stated above...
ko propo vfs-2000 esc nitro kid R/C Items: For Sale/Trade 1 03-29-2008 12:29 PM
KO Propo VFS 2000 ESC Help simba350 Australian Racing 3 11-08-2007 11:34 PM
~F/S Ko Propo Mars R/Ko Propo VFS 2000 Pro/BMI FK05~ RandomTask R/C Items: For Sale/Trade 5 06-21-2006 10:18 PM
Ko Propo ESC, VFS 2000/VFS-1 Thraex R/C Items: Wanted to Buy 0 03-13-2005 02:21 PM
KO Propo VFS-2000 ESC AGR#7 Electric On-Road 9 01-06-2003 11:35 AM
