KO Propo VFS-2000 ESC >
Old 12-29-2003, 10:48 AM
  #136
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default Re: Re: luckiest guy on the planet...
Originally posted by rc-zombies
Yea...I will have to do that right after the holidays...Now I'm debating whether to get the Twister for around $170+/- or order one from HK for $190.00+/- with the handheld programmer.... the Twister would look great on Pro4.
If I get the handheld programmer it about $65.00+
decisions....decisions...
if you have a laptop.. just get the software for it. easier to set b/c its more visual and you can save more profiles.
what would be the shipping for the esc/programmer package from HK? i havent seen that combo here cheaper than $260. so it would be hell of a lot cheaper.
Hebiki is offline
Old 12-29-2003, 10:52 AM
  #137
rc-zombies's Avatar
Default Re: Re: Re: luckiest guy on the planet...
Hobby Mania in HK has it for $190.00
http://www.hobbymania.com.hk/eng/more.asp?id=484
I'm estimating that shipping would cost around $10-15usd to the US.
rc-zombies is offline
Old 12-29-2003, 11:33 PM
  #138
TFR
TFR's Avatar
Ko Staff,
Can I use my KR-302F with non-digital servos if I turn the switch to normal responds mode?
TFR is offline
Old 12-30-2003, 07:57 AM
  #139
=MisFitz= NuKe's Avatar
Altough I am not Robert or Naka, yes you can. I run the new 302 with analogs in my 1/8th scale and works just fine.
=MisFitz= NuKe is offline
Old 12-30-2003, 08:00 AM
  #140
Also, if you check in your manual, you will see something on which "Channel: Select" you should be on. I believe it is page 66. It basically has a chart showing you different variations of receivers and servos and speedos, and then shows you the way you program the radio for each.
Old 12-30-2003, 09:32 AM
  #141
Originally posted by TFR
Ko Staff,
TFR,
Mike is correct in his statement. You can run analog servos with the KR-302F receiver if you change the tx to the correct setting.
KO PROPO Staff is offline
Old 12-30-2003, 09:40 AM
  #142
JasonC's Avatar
Trader Rating: 120 (100%+)
Robert, i sent you a pm. hope you got it this time.
JasonC is offline
Old 01-10-2004, 06:47 PM
  #143
Default Super Shotki Diode
Hi,
I just bought a secondhand VFS2000 speedo but it never came with a Shotki diode. Can I use normal 5amp diodes from my LHS - if I install 2 onto the motor ? I am running 27turn stock on my Yokomo SD with GP3300 cells.
Raymond.
rjk74-yok-racer is offline
Old 01-10-2004, 10:31 PM
  #144
rc-zombies's Avatar
Default Re: Super Shotki Diode
Originally posted by rjk74-yok-racer
Hi,
Raymond.
You can also use the Novak super diode
Old 01-11-2004, 11:46 AM
  #145
yeah, with stock you arent pulling near the amps that you do with mod, so you should be ok with 2 normal diodes. you might want to try 3 though. the thing that hirts the speedo is going from full throttle to full brake.
Old 01-11-2004, 01:24 PM
  #146
and for you guys running the VFS-2000 or 2000J, I will post my speedo set-up that I have gone the fastest with so far.
Old 01-11-2004, 08:23 PM
  #147
Can anyone tell me how to set up vfs2000 please? (for throtle and brake setting)
Kingcrab is offline
Old 01-11-2004, 09:13 PM
  #148
alright, this is for you guys running the 2000 or 2000J in a 12th scale car.
this is my current set-up that I have gone the fastest with, still testing though,
used on med. high bite asphalt, 120x65, 10x2 Reedy Pt, 100 Spur and 22 Pinion
Old 01-12-2004, 11:01 AM
  #149
rc-zombies's Avatar
Just received my Hara Twister today...
I see it only came with a 35v 1000uF capacitor...
is it safe to use the Novak 10v 4500uF or even 10,000uF on the ESC.? I assume yes... or is the stock cap work just fine.
Old 01-12-2004, 11:19 AM
  #150
Trader Rating: 30 (100%+)
I run 2 lrp big blue capacitors.Runs just fine.punchy!
racenut123 is offline
