Old 07-27-2008, 12:31 AM   #16
a_main_attendee's Avatar
Location: Colorado, USA, The land of the free and the home of the brave!
losi xcelorin sensored can handle 3s, its cheap, has lipo cutoff, dsm optimised, and did i say it was cheap?
smoother than butter on ice as well
Support your local tracks!--|--e-teamhobbyplex.com--|--corrc.org--|
NNFaN Paints - Add some pride to YOUR ride.
a_main_attendee is offline   Reply With Quote
Old 07-27-2008, 01:02 AM   #17
alainchan's Avatar
Originally Posted by LOSI123 View Post
do you know if it has the correct li-po cutoff voltage setting for 3 cell 11.1 volt (around 9 volt)
after run 6 min, each cell around 3.4V
alainchan is offline   Reply With Quote
Old 07-29-2008, 02:36 AM   #18
chowchowchow's Avatar
we have a test race last week.
1) 3 lipo + 10.5T ( 1200 g )
2) 2 lipo (28C) + 4.0T ( 1380g)
3) 5 cell nimh ( SMC ) + 3.5T ( 1400g )
4) 6 cell GP3700 + 3.5T (1500 g)
almost the same speed on each corner area , but "3 lipo " has more punch on the straight road and no sign on power drop during 4-5 minutes.
** more handling @ 5cells
** too heavy on 6cell touring
** easy to charge battery and playable = 2 lipo (2S1P)
** 3 lipo - no tires wear and the CVD will be long long lasting ...etc
hope can change the size and weight for the hard case lipo battery .
chowchowchow is offline   Reply With Quote
Old 07-29-2008, 04:11 AM   #19
Nice set up,
Just be careful as those flight lipo have no protective case if you crash.
Definetly not race legal in UK
brit_bulldog is offline   Reply With Quote
Old 07-29-2008, 09:30 PM   #20
What servo is that? And what's the torque in metric?
hermanchauw is offline   Reply With Quote
Old 07-30-2008, 11:59 AM   #21
alainchan's Avatar
KOPROPO
PDS-951 ICS
12,600 No.30048
<ミニタイプ/ハイスピード・トルクタイプ/6.0V/1/12 E Pレーシングカー>
●トルク/7.8Kg-cm ●スピード/0.09S/60 ●使用電圧/6.0V ●サイズ/3 6 30. 7 15mm●重量/29.0g ●アルミファイナルギア、メタルギア、樹脂ギア●ダブルベアリング、NEWコアレスモーター、金メッキコネ クター●ミニサーボではありえなかったトルクを実現。ハイグリップコースでも路面に負けることなく理想のラ イン取りが可能●ICSでセットアップ可能
Old 11-08-2010, 12:31 PM   #22
wtcc's Avatar
Good to see, that I am not the only one who likes to see more light TC's on track! Of course alainchan you were first
Now that the TC6 hopefully reaches me this week, I transformed my TC5 from a LRP-HPI-Challenge-Car back in a Lightweight-Version. But now I take it seriously!
I threw out every "normal" electric component and replaced it with lighter and smaller ones. Here is a list:
* Motor: MZ A380-500
* ESC: Quark 33A ProCar
* Servo: Power HD-1810MG
* Receiver: LRP C3-RX 2.4Ghz F.H.S.S
* Battery: SLS 2200mAh 45C APL
* Body: HB 09x LW
* Tires: Keil ZR-040 TC-Foam-Tires
As lightweight fan I added TiR CVD's (I think the last ones in germany) and some titanium screws. Still to come are titanium hinge pins and ball studs.
* Weight Chassis: 537 Gramm
* Weight RTR with body: 829 Gramm
First test drive happens this friday. The A380-500 Outrunner showed already with a car weight of 1081 grams the performance of 9,5t and 13,5t motors (something in between). Now it has 250 grams less weight to accelerate I am excited how it will perform and how long the battery will last...
wtcc is offline   Reply With Quote
Old 02-27-2011, 12:14 PM   #23
Thumbs down what????????
I cant see this being true my tc6 weighs this full electronics no battery you saying this car is 260 grams less then a tc6 with out battery. That is a full 12oz can of soda difference what you do tare the battery weight first.
jabird85 is offline   Reply With Quote
Old 02-27-2011, 01:32 PM   #24
wtcc's Avatar
In fact I even pushed the weight below the 800 grams!
If you can't believe it then check the weights of the components I use.
Without electronics a TC5 weights around:
So if you use Lunsford titanium parts and non-standard-electronics you are able to reduce the overall weight this way. If I had used an aluminium pinion and would have CNCed a custom TC chassis I am sure it is possible to get below 750 grams.
Old 02-27-2011, 02:57 PM   #25
Default well i see yours
u dont even barly have a chassis i was wonding about origial post pic that says 1067 i just think its bs i dont see 300 grams in smaller battery and his is full frame whats stock weight of xray what ever one that is
my light weight lipo touring car-img_1088.jpg   my light weight lipo touring car-img_1090.jpg   my light weight lipo touring car-img_1089.jpg   my light weight lipo touring car-img_1091.jpg
Old 02-27-2011, 03:14 PM   #26
wtcc's Avatar
My standard TC6 with LRP electronics and 295gr. battery has an RTR weight of around 1270gr. without weights. So if his TC has an similar weight then it is possible. My softcase 2s Lipo (shown in the pics above) has a weight of 132gr. His mini battery is maybe similar.
Maybe he also uses aluminum screws or maybe titanium. This would bring another 30gr.
Old 02-27-2011, 03:38 PM   #27
housey's Avatar
WTCC, that is awesome mate, really like that.
The future of RC TC in some years maybe.................
Chris Swallow - Team Yokomo - GM Racing - Ko Propo
Donny Racing - http://donnyracing.yolasite.com/forum.php
Poweeeeerrrrr!
housey is offline   Reply With Quote
Old 02-28-2011, 03:33 AM   #28
Originally Posted by trailranger View Post
To name a few.
Tekin RS PRO
SPEEDPASSION
Lol get a MMP and go 6cell 10.5!
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 02-16-2016, 01:40 PM   #29
wtcc's Avatar
Started a new lightweight tc project today.
Base is my spare TC6.2 chassis (471g).
Components will be:
Servo - TP MG92B 16g
Esc - LRP Nexxt 4X 21g
Motor - LRP Vector Micro 370 76g with pinion (too heavy )
Battery - Hacker 2S 1800mAh 25C 104g
Receiver - LRP C3 6g
Tires - Sorex 24 95g
Body - Pf Dodge Dart Lw 90g
Unfortunately chassis and motor are already very heavy. The motor adds up 20g more than my last lw-project outrunner and the chassis Idk, but I think the modded TC5-chassis was lighter...
Today I made the servo mount and a servoarm conversion. The original servo mount was much to big. I removed it and build a new one from two brackets.
Next will be a new motormount.
/// CAUTION: Rogue robot \\\
Old 02-16-2016, 05:56 PM   #30
heretic's Avatar
NICE
BTW You want a Blitz 0,5mm body. They come in at 65 painted. Icing on the cake: they are much tougher than Protoforms, even though they are thinner.
I love wedge bodies. I love dish wheels.
heretic is offline   Reply With Quote
Lowering the weight of Touring Cars that use lipo TheCoolCanFanMan Electric On-Road 141 02-27-2016 11:48 PM
Light weight screws tandman Electric On-Road 9 01-14-2008 01:03 AM
Light weight MIP cvd's and out drives. MadRacer Australia For Sale/Trade 1 09-12-2007 01:21 AM
LOOKING FOR LIGHT WEIGHT TRANNY GEARS FOR ASSOCIATED playinrc Electric Off-Road 9 11-10-2005 01:10 AM
Evo IV light weight suspension kit Danpatinod R/C Items: Wanted to Buy 1 03-24-2005 08:41 PM
