Muchmore Power Supply Fuse >
Old 07-22-2008, 06:29 PM
gt3angel's Avatar
Default Muchmore Power Supply Fuse
Hello I have a Muchmore World Ed.(black case not the 2). Does anyone know where I can buy the fuse for it. Thanks.
gt3angel is offline
Old 07-22-2008, 07:43 PM
odpurple's Avatar
The fuse is a 20 amp automotive fuse, the kind with two spade connecters on it (called atl) You can buy them at pretty much any auto parts store
odpurple is offline
Old 07-22-2008, 07:55 PM
gt3angel's Avatar
Thanks for the info and your OD12 looks great.
gt3angel is offline
Old 07-23-2008, 05:02 AM
BigPapa's Avatar
Default fuse
It comes with 2 amps one regular and the other a circular tube amp, what specifications do know about the circular amp?
BigPapa is offline
Old 07-23-2008, 11:19 AM
odpurple's Avatar
I've never had to replace the glass fuse. It is a 5mm x 20mm Midget catagory fuse, rated 5 amps at 250v
odpurple is offline
Old 07-23-2008, 11:21 AM
odpurple's Avatar
You're welcome, and thanks, Dood
odpurple is offline
Old 07-23-2008, 02:29 PM
BigPapa's Avatar
Thumbs up 5mm x 20mm fuse
hey where can you get the 5mm x 20mm fuse? reply to me
BigPapa is offline
Old 07-23-2008, 03:32 PM
gt3angel's Avatar
Big Papa they have the fuses at Advanced Auto Parts. Hit you up later.
gt3angel is offline
Old 07-24-2008, 10:43 AM
odpurple's Avatar
The glass fuse has no automotive applications that I know of, so it may be easier to find at an electronics supply store.
odpurple is offline
Old 08-31-2008, 01:26 AM
Jspeed's Avatar
BigPapa,
Want to go to Homestead to race with us?
Check your PM
Jeff
Jspeed is offline
Old 08-31-2008, 07:18 AM
scootr117's Avatar
Autos built up to the 80's all used glass fuses. There are special application glass fuses {slow blow type} that are Radioshack items....try the auto parts store. You may get lucky
scootr117 is offline
