Old 07-21-2008, 07:40 PM   #1
RobS's Avatar
Default Lipo Battery Question
Being new to the Lipo scene, I've got a question for all you Lipo battery experienced guys... I have a Peak Racing 4800 2S2P Lipo pack that has been sitting for about a year. I wasn't the last one to use it so I am not sure how much charge was left in it after its last use. How do I check to see if its still ok to charge?
Rob Say
Action Hobbies Kingsville
"In racing you never really lose. You either win, or learn."
RobS is offline   Reply With Quote
Old 07-21-2008, 07:44 PM   #2
Trader Rating: 19 (100%+)
Send a message via AIM to teammidget lilB
I would just put it on a charger and if its to low it wont chage and will probly say something along the line of "Current to low". Other than that I dont see anything that would make it an issue to charge it.
Bryan
Bryan "Lil B" Ford
U.S. Army @ Camp Humphreys, South Korea
teammidget lilB is offline   Reply With Quote
Old 07-21-2008, 08:00 PM   #3
suking's Avatar
Send a message via MSN to suking Send a message via Yahoo to suking Send a message via Skype™ to suking
Default hard cases li-po battery manufacturer
hi. Robs ....this is easy to check it.
1. check the voltage.simple li-po voltage is 3.7V. after discharge the the is around 3.0V....full charge is 4.0V...
2. if you have a tool for check the capacity will more easy ....
suking is offline   Reply With Quote
Old 07-21-2008, 08:20 PM   #4
espresso1967's Avatar
Trader Rating: 18 (100%+)
What is the toold called to check volts. I may have zapped a lipo myself and need to check voltage.
www.cityofangelstshirts.com
espresso1967 is offline   Reply With Quote
Old 07-21-2008, 08:36 PM   #5
RobS's Avatar
Well I've got the pack taking a charge and its showing ~8.3 volts. I have it set to 4.8 amps for a charge but right now its only taking in 0.25 amps? Is this normal? I'm using the Checkpoint TC-1030 charger with the Checkpoint Pro Balancer in charge thru mode...
Rob Say
Old 07-21-2008, 08:49 PM   #6
trailranger's Avatar
Yes that should be normal.
Your pack will only charge at the 4.8amps you set during the middle of the charge.
On CC/CV or Constant Charge, Constant Voltage the charge starts at a set amperage. In your case 4.8amps then as the pack reach the terminal voltage of 4.2V per cell the amperage is decreased untill it takes 0 amps to maintain 4.2V per cell.
Some chargers slowly increase the amperage if the voltage of the cell is under 3.5V. Then after it will give the full amperage you selected.
trailranger is offline   Reply With Quote
Old 07-21-2008, 09:06 PM   #7
RobS's Avatar
So chargers slowly increase the amperage if the voltage of the cell is under 3.5V. Then after it will give the full amperage you selected.
Ok, thats exactly what I was looking for, thanks! I think I got this all figured out now...lol
Rob Say
Losi Lipo Battery Question Evolrider Radio and Electronics 3 08-04-2008 06:08 PM
esc and lipo battery question jedsled Electric Off-Road 17 03-05-2008 08:18 PM
lipo battery question tedd69 Micro and Mini Scales 6 10-23-2007 12:51 PM
LiPo battery break in question Nitr0Racing06 Electric On-Road 2 06-01-2007 09:29 AM
