Old 07-29-2008, 04:38 AM   #121
TheCoolCanFanMan's Avatar
Originally Posted by brit_bulldog View Post
maybe a way forward is to consider longer heats or finals becasue we can, as to date no matter how big your capacity is you always gear and tune your motor to last 5 minutes (at top level)
Maybe if you had to think about a seven or ten minute final like the 1/12th guys it would stop the cars getting stupid quick. Maybe this is the way forward?
Running longer races will never happen in TC, as there will then be not enough time to have 120 TC racers a meeting, if running 3 to 4 rounds, and finals, thats why there are only 80, racers in 1/12 meetings. coz of the 8 mins they run.
Cheers TCCFM
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 07-29-2008, 12:59 PM   #122
Trader Rating: 20 (100%+)
I did'nt want to start a new thread about this so i'll ask my ? here . i just bought two TRAK POWER lipo's to use in my TC4 . Does anyone sell a weight kit so i can make my TC4 the leagel weight for racing ?. Thank's for any help .
hippie is offline   Reply With Quote
Old 07-29-2008, 01:16 PM   #123
slakr's Avatar
Trader Rating: 33 (100%+)
http://www.teamfusionracing.blogspot.com/
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 07-29-2008, 01:20 PM   #124
Originally Posted by slakr View Post
Thank you very much . Is that the only one ?.
Old 07-29-2008, 02:11 PM   #125
slakr's Avatar
There are some different types here...
http://www.nexusracing.com/index.php...b5976da632619e
This one is more for the TC5/belt drive flat chassis cars...
http://www.ppdbillet.com/RC_accessories.html
There is also a guy here on RC tech (JohnyBoy) that does weights similar to the LiPo-Lead, but they are made from stainless steel...
Old 07-29-2008, 02:16 PM   #126
My lipo's weigh 9.4 oz or 268gr . To get them to weigh the same as my 3800's i have to add 5.7oz according to my scale . which weight kit is better ?.
Old 07-29-2008, 03:00 PM   #127
tc3team's Avatar
Originally Posted by Sabin View Post
The only reason that works is because of the shore rating of the current tires and the firmness of the inserts. get a lower tire rating, like 20 and a softer insert and you'll have the same grip with a lighter car. Softer springs and lower oil wt helps aswell.
We ran a spec tyre, the sorex 24... Not that far off a 20. I ran one set of tyres for 4 of the 6 winter series rounds (3 or 4 qualifiers and a 2 leg final) the 2nd set of tyres got used for just 2 runs, I could have done without them tbh, but they just had the edge I were looking for when it all mattered, in the last round. I finished 3rd, part of that was probably being my cells being 2 or 3 seasons old, another reason being unreliability in one round, and a no show in another.
I found that a well setup car with the extra weight gave stability, its not all doom and gloom having that extra weight, and taught me how to hold a defensive line in the infield.
I used one brand new demon green motor (monster based) for all of the series and it still has plenty of go in it now, many meetings after the winter series above.
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 07-29-2008, 04:54 PM   #128
A well set up car seems to be the best for anyone, light weight or not.
If you drive great with a heavier car that's set up to how you like it, then that's all that matters, really.
Part of the reason why like the light weight because it allows me more flexibility, especially when it comes to running on bumpier asphalt lots.
Sabin is offline   Reply With Quote
Old 07-29-2008, 08:32 PM   #129
I decided to get the lipo lead . Thank you for the help you guys gave .
Old 07-30-2008, 05:36 AM   #130
Hi Sabin,
at last someone makes a valid point as when weight is an advantage. I do agree with you here as it is much easier to set up a heavy car on bumby surface.
brit_bulldog is offline   Reply With Quote
Old 07-30-2008, 11:12 AM   #131
trailranger's Avatar
I would at least like to see OPEN MOD go to a dimensinal class with a min/max limits for size, weight, motors, batteries.
Would be something to see if a racer wanted to run a 380BL with a mirco servo and 3000mah 11.1V LiPO. 1100grams and every bit of fast.
trailranger is offline   Reply With Quote
Old 07-30-2008, 11:32 AM   #132
timmay70's Avatar
Hi Sabin,
How is equal competition not a valid reason?
Speed Merchant Rev7, Tekin, TQ Racing (wire), Team Tamale
RC Excitement - Buy where you race, support your local tracks.
ROAR #105242
timmay70 is offline   Reply With Quote
Old 07-30-2008, 11:48 AM   #133
gijoe64's Avatar
Trader Rating: 30 (100%+)
And this is why TC is dying! No compermise and no common sense!
Raymon Robinson
ARC, LRP Go Blue!!
gijoe64 is offline   Reply With Quote
Old 07-30-2008, 11:58 AM   #134
Well said dude maybe we should start up a NEW official body for TC
Have a look at this thread, as this is where im coming from, it is soooooooo easy to do to http://www.rctech.net/forum/showthread.php?t=233745
Old 07-30-2008, 02:35 PM   #135
Thanks. Personally, I have no problem running my lightweight car on a bumpy surface. I have some insanely soft springs, and I run 20wt all around and the car just floats over the surface. Chassis roll is pretty much a non-issue, so I can carve corners nicely and I can drop the ride height down a little more for added stability.
There was this dip on the smackdown track that was so big, almost every car was having trouble with it every time they went over it they bounced off it like a ball or the rear end came loose. not me. I went full throttle through it with no drama.
my light weight lipo touring car alainchan Electric On-Road 186 07-06-2016 11:17 PM
Lipo and NIMH Weight BuggyKing Radio and Electronics 4 05-02-2008 09:56 AM
Next Gen Touring Cars - Will they be designed for Lipo? CouldbeFaster Electric On-Road 39 04-03-2008 05:46 PM
5 cell touring car weight Dave Bowser Electric On-Road 2 08-28-2007 12:25 AM
Touring Class Weight Minimum jcrouse Electric On-Road 4 12-12-2003 10:23 AM
