XXX-S issues
XXX-S issues
first ill start with i know nothing about electric rcs. my problem is i let my brother use my car and he brought it back to me broken... steering works but motor does not. lhs told me to replace speed control so i replaced it but it didnt fix the problem. if anyone can help i would appreciate it
It would help if you posted what your speed control/motor combination was... With so many combinations today, it is hard to give good advice without more information.
However, as noted, if you have a brushed motor, then a problem with the brushes is most likely (brush worn out, 'hung up' in the brush hood, or even a broken brush spring or a bad connection from the ESC to the motor)...
If it's brushless, bad solder connections or a loose sensor plug (if sensored) are possible...
Does the car roll "free" (it could be that the drive train has "locked up" from dirt/rocks, ???)...?
well the car will work if i give it a little push but as soon as i let off the throttle it stops again
the motor is a team trinity P2K2 Pro (thats all i know about it) and the speed control is a dynamite tazer 15t
