Old 07-16-2008, 04:53 PM   #1
Default Tamiya F103 gearing?
I decided to run again my Tamiya F103's. Problem: I do not know which gearing is ideal for this car. Being a direct drive car, the ration is 1:1. I use 64 pitch gears.
For 27 turn, it looks like a ratio of high 5 is good, from what I read. This would mean that with the optional 104 spur, I can use a 19 or 20 tooth pinion. For a 27 turn, I would go 2 teeth higher.
Could anybody confirm to me that this is the right approach?
Thanks!
usaserres is offline   Reply With Quote
Old 01-31-2009, 11:06 PM   #2
silverhkswrx's Avatar
Send a message via AIM to silverhkswrx Send a message via Skype™ to silverhkswrx
Thanks!
which f103 are you running? can you measure the diameter of the 104t spur? i ordered a set and it seems to be large from the pix.
i have a brushless 3300 and am at 4.375 now.
SpeedPassion 17.5R powered TRF417X
My son owns: Team Associated RC18R2
(RC18B2 converted to a RC18R)
http://www.tamiya.com/english/rc/manuals.htm
silverhkswrx is offline   Reply With Quote
Old 01-31-2009, 11:57 PM   #3
mild seven's Avatar
Trader Rating: 63 (100%+)
Send a message via MSN to mild seven
Thanks!
if you use a 21t pinion that would be about right. that gives u a ratio of 4.9.
mild seven is offline   Reply With Quote
Old 02-01-2009, 08:10 AM   #4
i also noticed the tamiya gears are MUCH larger than the regular 48 or 64 pitch gears. however there is a gap between the outside of the driveshaft annd the inside of the gear. there is a shim that fits the 64 pitch, you know if there is one that will fit the 48p?
F103RM-11 64Pitch POM Gear Ring from 3 racing.
looking for a Tamiya F103 GT level-4 R/C Items: Wanted to Buy 6 05-22-2008 04:56 PM
Tamiya F103 LM Hpimichael Electric On-Road 18 08-02-2007 06:14 PM
WTB: Tamiya buggy & Tamiya f103 stuff rays_tt Australia Wanted to Buy 2 04-20-2006 07:10 AM
Tamiya F103 or F103 Parts MM-F1 R/C Items: Wanted to Buy 4 04-24-2004 04:14 PM
Tamiya F103 Mike F R/C Items: For Sale/Trade 1 01-20-2003 09:16 AM
