Old 01-08-2002, 08:55 AM   #1
Default I Need Some Help
Alright here is the deal...........
RS4 Sport 2 Touring made into rally
Rally Shocks
Inner Body
Orion 11x2
rally tires
I places second in sportsman class(miscelanious stuff ..beginners basically)...I need my R/C to handle better and take the jumps better OFF-Road...I have had fun with a dremel tool and curently have a ride height of about 2 to 2 and 1/2 inches......anything you think i could do to make it better????
integrashowcar is offline   Reply With Quote
Old 01-08-2002, 09:30 AM   #2
come on guys please help me.i hate being second best
Old 01-08-2002, 10:44 AM   #3
sosidge's Avatar
be more specific about the eaxct handling problem - is it trouble riding the bumps, is it nose down or nose up in jumps?
Anyway, if you've modified your car to have 2 inches ground clearance, it's probably not running right, because the suspension arms must be at an absurd angle, and the driveshafts won't like it.
Off-road, a 250mm wide buggy will always handle better than a rally car.
Old 01-08-2002, 07:00 PM   #4
well the nose goes too far down on the landing......the suspension isnt really too far at an angle....about 30 or 40 degrees....its not too bad though......i just need help on landings really
Old 01-08-2002, 08:26 PM   #5
here are pics
http://integrashowcar.freewebspace.com
Old 01-09-2002, 04:22 AM   #6
Caddzilla's Avatar
Send a message via ICQ to Caddzilla Send a message via AIM to Caddzilla Send a message via Yahoo to Caddzilla
Try putting the HPI green rally springs in the front and keep the blacks in the back. That should help keep the nose up a little. What shock oil are you using? I use 50wt in mine, with the green springs up front and it seems to do the trick for me.
Caddzilla is offline   Reply With Quote
Old 01-09-2002, 06:53 AM   #7
i think it is 25.i had 45 but it wasn't smooth enough for jumps.
Old 01-09-2002, 07:00 AM   #8
sosidge's Avatar
Yep, stiffer front springs will give the car a more "nose-up" attitude in the jumps.
Old 01-09-2002, 07:33 AM   #9
anything else.........should i get anything graphite........could i put bigger tires?
Old 01-09-2002, 07:38 AM   #10
can i egt a GOLF body for my car?
