Internal shock limiters >
Old 07-13-2008, 03:42 PM
Default Internal shock limiters
Can someone please explain the theory behind them. When would you want to use them and what are the effects.
Guffinator is offline
Old 07-13-2008, 04:38 PM
jonas_h's Avatar
with this method you can limit the droop. but it only make sense if your car has no droop limiters in the wishbone.
jonas_h is offline
Old 07-13-2008, 06:32 PM
some say, shocks work better if the pistons dont bottom out all the way, but tamiya trf shocks have short shafts with not much space under the pistons. Other shocks Ive seen(yokomo associated etc) have internal spacers. i personally dont feel much difference, but im no pro.
slomo is offline
Old 07-16-2008, 07:19 PM
No more input here?
Old 07-16-2008, 07:21 PM
geeunit1014's Avatar
jonas_h pretty much summed it up. an internal limiter has the same effect as droop screws on the chassis, execpt droop screws are much easier to adjust
geeunit1014 is offline
Old 07-16-2008, 07:57 PM
Still Bill's Avatar
I used internal limiters on my Losi cars a few years ago. Was a pain to make adjustments via trial and error. Much prefer using droop screws.
Still Bill is offline
